painless harness can i remove wires
ok im switchig to tpi using the sd harness from painless.ca i remove wires i dont need right from the connector at the ecm???got lotsa stuff i dont need.thanks eric
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I would imagine that if its not needed, then you can cut it off just about anywere you want.
just some of the stuff i would like to delete.lockup control,speedsensor,vats,i know there is a couple more but cant think now.this is going in a older car that has no puter.
