95 lt1 scan tool
Old 12-09-2003, 10:04 PM
thatsme's Avatar
95 lt1 scan tool
I have my lt1 in and running now its time to wire up the obd port and see how many reasons the check engine light is on for. What kind of scan tool do I need to get for this year motor. It doesn't appear to be obd II compliant but the plug is the obdII style and not an aldl plug. Can i wire up an aldl connector and use an older scan tool or will an obdII tool communicate with it, or is there a special tool for this year. I know there are plenty of guys with 95 motors; let me know what you did.
Old 12-10-2003, 11:47 AM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Depends whether it is obd 1 or obd 2. I think 95 is obd 1. Either way you can use something like autotap and hook it up to a laptop for scanning.
Old 12-10-2003, 01:41 PM
TexasLT1's Avatar
Car: '92 RS
I use a Scantool they have at Autozone, I can't think of the brand at the moment. It has different modules and cables you can get for it to connect it to just about any vehicle. I think it ran about $80 and you can check codes, record a data sample, and watch the readings real time. It's a good scanner.
Also, I use the thirdgen dataport connector rewired for OBD1 use.
Old 12-10-2003, 02:21 PM
Drastius's Avatar
Car: 1985 Camaro Z28
Engine: Caprice LT1
I use an AKM cable, a laptop and freescan. Works ok I guess.
Old 12-10-2003, 06:02 PM
TexasLT1's Avatar
Car: '92 RS
where can you get freescan at?
Old 12-10-2003, 06:49 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
The cable I have will do 93-95 LT-1's . I bought it from mastach in Poland.
click here
Old 12-12-2003, 12:04 PM
HesterZ28's Avatar
Car: 97 30th Z28
Engine: lt1
Transmission: 4l60e
I use a gm Tech2 scanner
92projectcamaro
12-08-2015 12:25 AM
88SS6SPEED
11-11-2015 07:05 AM
Reid Fleming
10-10-2015 09:56 PM
WejaZ28
10-03-2015 07:38 PM
IROC ZELLER
09-29-2015 03:00 PM
Quick Reply: 95 lt1 scan tool
