engine swap
engine swap
i am putting a 350 in my in my 1989 v6 camaro with a automatic. i know now that the tranny will not bolt upif i put a turbo 350 tranny in it will the drive shaft fit orr what other problems will i have will the engine swapp the 350 will be carberated
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
TH350's came in two lengths, 6" tailshaft and 9" tailshaft. The longer ones often came in trucks & vans.
If you use a 9" TH350, the driveshaft is the correct length. If you use a 6" TH350, you need a longer driveshaft, either one custom made, or one from an '82-'83 Camaro/Firebird with 3 spd auto or 4 spd manual tranny.
You also need some means of mounting the torque arm. A retrofit bracket is available that uses tailshaft housing bolts. Or, Spohn (sponsor button above) makes a nifty conversion crossmember and torque arm that takes the torque arm mount off the transmission (a very good idea, by the way).
The other problems you'll have is basically anything that the engine bolts to or anything that bolts to the engine is different between a V6 & V8. That's why donor cars are so highly recommended for this operation, even if you don't use the engine or transmission from the donor car.
Re: engine swap
Is this a good donor for my 89 v6 firebird?
https://richmond.craigslist.org/pts/5517393241.html
theshackle
03-05-2017 06:37 PM
