is a 1990 350 LO5 a good place to start?
Car: 91 camaro RS
Engine: 305 TBI
Transmission: auto
Axle/Gears: 89 2.77 BW 9-bolt disc possi
hello...i have a 91 RS 305 auto...77k like new/ runs great....i was wanting to find a motor to slowley rebuild on the engine stand for more power...i see on craigs i can buy a 90 350 4 bolt main LO5 engine for 300 obo...15k since rebuild....i have read on here you can inlarge the roller cam,biger injectors/or just raise the preshure,tuning and headers and intake and k&n...and you have a nice engine....sooo would this 350 be a good start?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Passenger car LO5's had roller lifters, truck LO5's did not. The majority of LO5's were put in trucks, and the majority of them were not machined for roller lifters. So, that's a crapshoot there.
LO5 heads aren't anything to write home about, but they aren't totally worthless in a mild build.
What to do with LO3 TBI for a 350 is covered in the TBI forum.
K&N is a "must-don't" in my book.
Car: 91 camaro RS
Engine: 305 TBI
Transmission: auto
Re: is a 1990 350 LO5 a good place to start?
the motor is out of a caddi Brouhme...i'll ask if it has rollor Rockers...it does have a rollor cam...i asked
Car: 1983 G20 Chevy
Transmission: 4L60
If its the stock caddy engine it will have roller lifters and the 305 peanut roller cam for a grand total of 185 HP/300TQ. Good thing is, it will most likely have flat-top pistons for a 9.6:1 compression ratio with 65cc chambers.
Engine: LS1/LQ4
It certainly wouldn't have roller rockers from the factory. Roller lifters is as far as they went.
theshackle
03-05-2017 06:37 PM
db057
08-11-2015 10:11 PM
