engine/tranny/k-member out as a unit?
Car: 89 iroc vert-91z-28
Engine: 305 tpi-305 tpi
Transmission: 700r-4-700r-4
Axle/Gears: 3.23 posi-3.73 posi
how hard would it be to drop the engine/tranny/kmember as one unit out of the bottom of the car? i have a car that i am scrapping and want to keep these. or would it be easier to pull the engine/tranny as a unit and then pull the k-member? thanks
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Not too bad, I understand. You need to disconnect the brake lines and struts, and control the A-arms somehow. Put the engine/transmission/K-member on a dolly, lift the body off.
