305 carb to 350 carb berlinetta
Old 03-31-2010, 09:34 PM
U.S.Marine09's Avatar
Car: 1986 Berlinetta, 1988 Iroc-Z
Engine: 305 carb, 305 TPI
Transmission: 700r4, 700r4
Axle/Gears: stock
Ok so i have an 86 berli and i found a 85 carb 350 locally but it does not have the carb can i just put my carb on there and bolt it in and call it a day? or is there anything else i have to worry about....my car has to stay as much emissions legal as possible i live in jersey my car is stock besides the mods listed below im not looking for a race car but i do want a good sleeper that will help me put the local honda guys in their place if this swap is as easy as it seems..-_- i will be putting bolt/weld sfcs and hopefully a posi rear...money is tight
please respond asap im looking to doing this soon
ps i searched and didnt get the specific response i needed
Old 03-31-2010, 11:04 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
You can put the 350 in place of your 305.
The only real difference is the '86 is a 1-piece rear main seal, and the '85 is 2-piece rear main seal, meaning they take different types of flexplates. If the 350 flexplate is the same size (diameter, # of teeth) as the 305, then you're good to go.
Old 04-01-2010, 08:48 AM
On Probation
Atilla the Fun's Avatar
Engine: several
Transmission: none
Axle/Gears: none
Re: 305 carb to 350 carb berlinetta
That 350 probably has the 14", 168-tooth flexplate, but if it has a matching starter, you're probably still okay. Otherwise, you'll need to switch to the 12.75", 153-tooth version.
The '86-up versions have a different hole pattern for the crank, and they have a small weight welded on to them, on the side toward the engine.
Old 04-02-2010, 05:52 PM
Axle/Gears: stock
ok perfect..... im going to take a look at the motor tomorrow the guy said something about a matching trans and if thats the case i dont have to worry about the flexplate right?
Old 04-02-2010, 06:47 PM
five7kid's Avatar
Engine: LS1/LQ4
The transmission should be a TH700R-4 like yours. If you use it, you will have to take the tailshaft housing off and put the one from your Berlinetta on it. That would be a good time to swap the speedometer drive gear as well so your speedometer will remain accurate (as it was).
If it is not a TH700, but something like a TH350, I'd pass on it.
Old 04-02-2010, 07:12 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
But if it's from a 4WD pickup, the trans can't even go into your car.
Old 04-02-2010, 07:30 PM
Axle/Gears: stock
well i know its not from a truck because he hadk it in a monte carlo before he switched for a 400 its most likely a 700r4. now im just trying to think which would be my best bet...shift kit on mine and install a better tcc mine as well while im down there or take his put a **** kit and worry about messing with the speedometer gear...
Old 04-02-2010, 11:29 PM
five7kid's Avatar
Engine: LS1/LQ4
I wouldn't make the decision based on the speedometer gear. It's a piece of cake to switch over.
Old 04-02-2010, 11:49 PM
Axle/Gears: stock
true now if i put a non cc carb on there can i just tuck the wires away?
theshackle
09-17-2020 08:26 AM
Jake_92RS
01-28-2020 10:37 PM
theshackle
03-05-2017 06:37 PM
theurge
08-21-2015 12:46 PM
st.evel07
08-13-2015 06:15 PM
Quick Reply: 305 carb to 350 carb berlinetta
