i have some vortec heads, and i have some questions
Old 01-09-2011, 11:21 PM
hb22man's Avatar
hi this is my first post on the forum, ive spent alot of hours reading and researching to plan out my first engine build. i managed to get a free set of vortec heads (actually gave me the whole motor but its blown) they are 906 casting and they have some pretty good rust on them. is there any way to clean them or should i take them to a machine shop? there doesnt appear to be any cracks, would you bother sinking time and money into these rusty heads? they have seen a couple years in a field on the blown motor. also, what is involved with machining the heads to accept the larger valve spring? should it be taken to a shop or can it be done myself? just weighing my options as i dont have alot of money and want to do everything myself to save money to invest in good parts. i will be able to get pictures tomorow, and i may start a build thread of my car. thanks in advance!
Old 01-09-2011, 11:52 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: i have some vortec heads, and i have some questions
I would strip them and check for any obvious defects.Heavy rust pitting on the machined faces is going to hard to fix
If OK take them to a shop and get them to hot tank them and possibly give them a light skim to clean up the head gasket face
No need
http://www.alexsparts.com/products/V...AT-TAPPET.html
Vortec heads need more valve travel ; not a larger spring
Old 01-10-2011, 12:14 AM
hb22man's Avatar
strip them? as in disassemble or use a chemical to clean them? i have the valves out i would like everything on the head to be brand new, i dont want to use the stock stuff. im very glad you pointed out those springs thats a simple solution. i didnt know they had springs out for vortecs, thought they had to be machined. as for the machined faces there is hardly any pitting, exhaust side was the worst but from what ive done so far it looks like it would clean up ok. whats the best way to get rust off a cylinder head?
Frozer!!!
01-19-2024 04:55 PM
MustangBeater20
10-29-2022 09:20 PM
84z96L31vortec
08-20-2017 12:16 AM
L98GTA87
08-11-2015 06:55 PM
84z96L31vortec
08-10-2015 08:27 PM
Quick Reply: i have some vortec heads, and i have some questions
