92 5.7 swap to 84 corvette 4+3 manual?HELP asap
Old 06-15-2011, 12:46 AM
da84Berlinetta's Avatar
Car: Trans Am
Transmission: t5
Axle/Gears: 3:73 borg
As of now I have a chevy 350 4 bolt out of a 1992 truck I have found a 1984 corvette shell with a "doug nash"(4+3) transmission 4 speed with 3 OD I figured it would be an easy bolt up but a friend said I will have big issues getting the 92 to connect to a 4 speed transmission kinda new to the engine swap only done one basic i figured every chevy 350 would bolt to a700r4 t350 5speedBW, but not a 4 speed ? HELP asap hoping to buy it in two days if the swap isnt to much of a bitch all feedback welcome
Old 06-15-2011, 05:55 AM
Received 1,666 Likes on 1,264 Posts
Re: 92 5.7 swap to 84 corvette 4+3 manual?HELP asap
Figure out what you're going to do about your torque arm before biting off on it.
Old 06-16-2011, 02:43 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Easy bolt up swap to engine with correct flywheel / clutch combo and 4+3 bellhousing
However the problem arises as Sofakingdom notes above because Vette trans does not have regular GM rubber trans mount underneath ext housing ( no trans cross member in C4 Vette ) and you would also need to fabricate something to mount your stock torque arm.
Also the stock 4+3 shifter mounts to the tunnel ; not the trans like normal so you would have to make that work as well.
All not impossible but not a weekend bolt in swap
Also be aware the O/d component of these trans is very expensive ($1500+ ) to repair so do not buy at any price unless you are sure the O/d is working.
The 4 spd part is just is BW Super T10 ; rebuild kits can be had for $120
Frozer!!!
01-19-2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
06-22-2021 08:21 PM
stalkier
08-21-2015 01:54 AM
jharrison5
08-19-2015 05:53 PM
Quick Reply: 92 5.7 swap to 84 corvette 4+3 manual?HELP asap
