Duramax Thirdgen Swap
#101
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
Re: Duramax Thirdgen Swap
it will get tubbed just dont know how far I need to go with it
#102
Car: 2006 Cobalt SS/SC
Engine: LSJ
Transmission: F35 MU3
Axle/Gears: 4.05
A Ford engine in a Chevy:
http://www.popularhotrodding.com/fea...o/viewall.html
Yes, they do exist. LOL!
#103
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
theres also one going on right now in a 3rd gen...https://www.thirdgen.org/forums/fabr...le-street.html
#104
most dont put ford motors because they arent the best out there when a stock GM motor can achieve 1000 plus hp why would you go with something else
http://www.hotrod.com/techarticles/h...g_bang_theory/
#105
I recently picked up a 04.5 crew cab 4X4 with the ZF6 speed, it's bone stock. It has the same hp as my LS1 and almost twice the tq. I wasn't even half way home for the first time with the truck when the thought of stuffing that diesel into my car crossed my mind. It pushes that big truck around pretty good. That is a very interesting project you have on your hands, good luck with it.
#106
wish we could trade trans the allison for the zf
#107
You do not want it 1st gear is a granny gear and a good clutch is expensive.
#108
lol, 1300lb-ft at like no rpm... what do you need a tranny for? Real world you're going to want as low a rear gear in it as you can find to make this thing fun on the road. Heck, my cummins w 4.10's and 36's will burn the tires from a 25mph roll at 7800# (951lb-ft do help a little ), but gets kind of buzzy and unhappy over 85mph.
the dmax is pretty much the truck diesel of choice for car swaps, it's the only one that's really small enough to work well in most chassis. All the cummins talk here is pretty much a non starter, a 6bt is bigger and heavier than the whole front end of that camaro. OTOH, if you wanted to do a 4bt (cummins used in things like bread delivery trucks) that would be pretty interesting and smalle enough to work.
can't wait to see this thing rolling, what are you planning for fuel delivery? the lift pump assembly that I'm running on my cummis is huge, that would be a bigger packaging problem than getting the dmax in the engine bay.
#109
im getting a airdog II and im going to sump my tank to feed it I have a 4th gen tank that is still steel so ill just modify it and make room for the pump and filters but still have them available
I am going to gear the rear very low I have a 3.42 in there now but im going to see how that feels and if needed go lower
#110
Car: 1991 camaro RS convertible
Engine: EFI 383 150shot nitrous.
Axle/Gears: 2:73...
#111
you can't make make anything fit into anything... the cummins is physically larger than all the room available and more than 2x the weight of a small block. The monti on youtube is fairly unique, an early 70's monti has a fan shroud that's close to 2 feet long, you could fit 2 big blocks in a row under their hood. To make that much room in an f-body you'd have to set the firewall back so far that you'd be sitting in the back seat.
#112
1 Post
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
This is a real head scratcher for me but i think its very interesting, if i had the money i would opt for a caterpillar engine, i think they got a ton of power straight out the box.
#113
I want it to be a sleeper not obvious power for weight and size you cant beat the duramax
NHRDA rules to race in the street class is stock style suspension and unmoddified firewall are some of the key items
#116
Car: 90 Chev Suburban 4x4, 5.3L, th400
Engine: 2002 5.3 Vortec swapped in.
Transmission: Stock th400
Axle/Gears: 10blt front/ 14bltSF rear 3.73 gears.
Same here! This is going to be awesome!
#117
Axle/Gears: 2:73...
hmmm cummins vette
http://www.youtube.com/watch?v=Lw9FT...eature=related
and 6.5 camaro
http://www.youtube.com/watch?v=FHfx-...watch_response
if you got money and time it all fits
and dmax in a v6 car
http://www.youtube.com/watch?v=4XTxG...eature=related
im sure we could do this all day but its not worth it
anyway i cant wait to see this thing
#118
I want to see more of those cars but you cant find anything you would think there would be alot on the vette or it was just sound FX the 6.5 dead end and the GN droped off the face after it got done no track time dyno ect
#121
Axle/Gears: 2:73...
yeah but there is alot of things out there im sure alot of people want to see more of but they just stop working on them i got pics of a 2000hp tri turbo cummins down the street but it hasnt moved in 3yrs he just got sick of it
#122
i know the cummins is alot bigger ive got a 02 2500 i had a 72 monty in hs i know the size and
hmmm cummins vette
and 6.5 camaro
hmmm cummins vette
and 6.5 camaro
#123
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Hopefully, this gets finished. There are a lot of off the wall project threads that never get finsihed on here. I will forsure watch this thread.
#124
it will I will take donations or sponsors to make it happen faster lol
just waiting on DOM to show up and money to buy the coilovers and Ive been busy these past weeks I got some time off comming up and should get alot knocked out then
#125
Car: 91 Trans Am GTA
Engine: Tpi 5.7
Axle/Gears: 3:23
This is crazy. But If you are going to do a swap why not a duramax. great power and great fuel mileage. I Wouldnt be surprised if you got 40 + mpg if you gear it to do that
#126
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
It might fit.... Between the wheel centerlines that is. The smallest CAT straight 6 is something like 6.6+ L with an intercooler & aftercooler for the turbo and is so large that it constitutes about 20% of the weight of a 12 metric ton excavator.
#127
Car: 1982, 2000 Trans Am
Engine: 350 bored .040 over: LS1
Transmission: Borg Warner Super T-10: Tremec T-56
Axle/Gears: 4.10s; 3.42's
subscribed
#128
got some stuff done today cleaned the garage and worked on the jig for the Kmember still waiting on DOM tubing
half way through my bandsaw broke so I had to use the cut off wheel for the few remaining cuts I hate them because I have had discs come apart on me
but all in all got some good welds for a temp fixture lol
#129
Car: 1986 iroc-z
Engine: 5.0 tpi
Axle/Gears: stock.
good job man i hope this works out for you.
i dreamed about this along time ago when i saw a chevelle with a dmax in a magazine, but i wanted to do a ford 6.0 in a fox body musthing but that engine is huge.ford was planning to make a smaller v6 diesel but scrapped it for the ecoboost. which is something ive been giving thought into swapping into a third gen....or an audi/vw v6 tdi.
#130
no update this week I got stuck building an exhaust for a friends truck this weekend I have the week after Christmas off so im hoping to get alot done then because I am leaving for NCOA (Non Commission Officers Academy) first week of Jan till feb so it will be a dead spot there then when I do get back I have a V6 auto to LS 6 speed swap and a full resto rod job on a 69 mustang fast back which will be awsome they guy im doing it for has cash to spend and we are doing a new coyote 5.0 and top performance parts all around
I was hoping to be running by spring and may be still but summer is looking more realistic and the weather here is not cooperating here but I cant wait till the longer days again
#131
Car: 87 ws6 trans am
Engine: 305sbc
Bummer, i've been showing all my buddies this thread and they think its freakin sweet and are excited as i am to see it done. Good luck man, enjoy the holidays
#132
I am going to try and get alot knocked out next week I am still waiting on tubing I think the shop in town is just a bunch of Aholes and I will end up procuring it myself
If I get time in class or decide to I will be heading home on the weekends but if anything I will be able to compile parts while I am gone because money is the biggest limiting factor right now with the holidays spare cash goes to presents and stuff
I told the wife for christmas just let me shop online for alittle and to not get me anything becuase I know what I want and need
#134
it sucks too because I had a nice 2 week TDY set up that I was looking forward to in FL that got canceled the same day it got approved so I can go to this to many guys failed PT tests and droped out and I just took mine last week so I was most eligablle
NCOA is ALS on crack
#135
Car: 1985 Z28
Engine: 8.3 ltre viper
Transmission: Tremec T6060
That's a cool swap. I too am doing an unconventional swap with a gen 4 viper motor in my 85 z28. Looks good so far.
#136
Car: Faster
Engine: Than
Transmission: You!
#137
still busy this week but managed to get the rest of the harness out of the donor truck I wanted to have more than less so Yeah i took the whole harness the only items I dyked off are the radio and tail lights
I will go through it and clean it up as much as possible good news is I can use a stock truck cluster bad news it I already sold the one I had so ill have to get another
Pretty ugly looking
Pretty ugly looking
#138
I pick up some tubing tomorrow not what I need but some I had to order a 24 ft piece still need to get 1.5 inch but ill have the 1.25 for the A arms panhard and tq arm
#139
1 Post
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
I'm a a duramax tech and huge fan of them. Lb7's are more prone to injector failure than lly and later. Nothing to fear or worry over. And yes, lb7s do have stronger pistons. I run an lly with Efi live with a dsp5 switch. 225,000 miles so far. Do yourself a favor and buy a new torque converter for your trans. You actually want a lower stall converter for your duramax. Helps control of line jump and keeps tranny temps down. I went with a rev Max torque converter. Call them, honest, great guys. They custom build and have decades of experience. (I run a stage V billet series). MAKE SURE you put in the biggest radiator you can fit. Duramaxes don't like heat. (Put in auxiliary cooler) put a new water pump on while its out also. (MUCH EASIER). Try to fit 4" exhaust in if you're gonna run Efi live. (I went with duramaxtuner.com for my Efi live).
#140
the injectors have 20 k on them they were already replaced and the water pump is newer also but I might still change it out I will be doing a full 4 inch exhaust and ill be getting a custom tq convertor for the 4l80e that ill be using
cooling will be addresses big intercooler and biggest radiator I can fit
I cant wait to get it in and running but it will be awhile I have some other projects getting in the way but then again they pay for my projects
#141
Car: 1985 Z28
No I just stumbled on this site a few months back researching if anyone has done a full nose flip. I am going to graft the viper hood into the cowl hood and bond it with a one piece nose and fender. I just started the tear down of the z. The only parts I am retaining are the back glass. The rest of the stuff is up for sale. So if anyone needs some original equip, let me know.
#142
built a jig for the a arms today and picked up some dom tubing but decided to make one out of scrap pipe and steel for some practice it looks like crap but im happy with it on the final product ill have the end steel cut out of either waterjet or plasma table depends where or who I know working
#143
here is the actual DOM tubing ill use for the real ones it 1.25 with .125 wall thickness
#144
got the front A arms done just need to get the rod ends and ill cut and ajust them
#145
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Wow! those are super clean! and awesome! how much they weigh compared to stock?
#146
Car: 91 Camaro RS
yea, i like those. how hard would it be to get you to make another set with spring perches.......
#147
they are at least half the weight maybe just alittle more half but the pair feels about the same as one stocker
I can make it with the perches pretty easy but you can get coilovers for around 190 go to QA1s site you can buy the springs needle bearings and the perches with ajustment jam nuts for half of the cheapest you can find online
http://www.qa1.net/qa1_motorsports/d...-wrenches.html
http://www.qa1.net/qa1_motorsports/d...over-kits.html
http://www.qa1.net/qa1_motorsports/d...l-springs.html
#148
I have the jigs built and the plans to a buddy with a waterjet I would consider making a few after they get tested and I trust my mig welds but anything I would put out would be tig welded
#150
nothing is wrong with them I have 100% trust in my welds and most you buy from companys are mig welded too
Tig is a better weld and they look damn good too
I might make some sets after I test these out I am also doing the same for a 4th gen in Feb just picked up a metal lathe too just have to figure where to put it
