Internal/external balancing ???
Old 05-22-2012, 11:51 PM
Horn0816's Avatar
Car: '92 RS
Engine: GM 350 swap
So I have my 350 bored .30 over, a brand new 383 kit from eagle that is balanced. I'm looking for a new harmonic balancer.
My research shows that 400sb is externally balanced. Since it's a "400" crank does that mean it needs to be internally/externally balancing... balancer? Or do I pick the "Engine Balance: Internal" on summit?
Old 05-23-2012, 12:08 AM
Horn0816's Avatar
Car: '92 RS
Engine: GM 350 swap
Re: Internal/external balancing ???
Nevermind... Straight from Eagle Specialty Products' website:
"You can also notice the contents of the kit. An internally balanced kit will not include a harmonic dampener or flywheel because they are not required for balancing - use whatever brand you like. Externally balanced kits will include a harmonic dampener and/or flexplate as needed. If we provide a harmonic dampener and flexplate it will be a O.E. style replacement, not SFI approved. If you building a high horsepower engine, internal balance is preferred anyway. Internal balance is better for longevity of parts and fatigue life."
3GZJerry
LSX and LTX Parts
10-14-2015 05:17 PM
monte87cortez
09-26-2015 08:10 PM
roysatikas
09-22-2015 08:15 PM
italiano67
09-22-2015 08:42 AM
Magman
09-13-2015 12:14 AM
Quick Reply: Internal/external balancing ???
