ZZ4 Crate engine with 1989 Tpi upper
Old 06-04-2012, 11:34 PM
prplroc92's Avatar
Car: 1992 25th Anni. camaro
Engine: 5.7 liter ZZ4 swap TPI
Transmission: T56 (manual 6 speed)
Axle/Gears: corp. disc GM 10 bolt, 3:42
Got a ZZ4 crate engine installed last year in a 1989 camaro. GM dealership build and install. It has 30lb injectors, and a Fast chip made to run it. everything else is stock except the exhaust. It has hooker headers, 3inch y pipe and an 3.5" American Thunder Exhaust system. It has 3:42 gears and a Retro fit T56 trans. The car runs low 13's. since last year I put on an adjustable fuel pressure regulator. Just wondering what fuel pressure psi is recommended? Anyone have a ZZ4 swap with TPI would love some input on this matter. Also Bought a stock Throttle Body bored to 52mm. I put a new IAC sensor on it and dialed the TPS to .59 at Idle. Since doing this the car idles like crap about 500 rpm cold when it warms up its running 1000rpm. It also surges at idle. What can I do to fix this problem? Please help!
Old 06-05-2012, 12:00 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:42
Re: ZZ4 Crate engine with 1989 Tpi upper
Did you do an iac reset after adjusting the tps and changing the iac sensor? If not I would start there. Fuel pressure at the rails is usually between 45-50psi for tpi systems.
Vintageracer
01-10-2020 05:33 PM
italiano67
12-11-2016 09:21 AM
kyleb24
08-15-2015 08:24 AM
Sanjay
08-12-2015 03:41 PM
bradleydeanuhl
08-12-2015 11:48 AM
Quick Reply: ZZ4 Crate engine with 1989 Tpi upper
