383 build
Car: 91 z28
Engine: 350 ram jet
Transmission: t5
383 build
howdy guys just droppin in to just see if you guys have any advice/tips on the build im planning on doing here. I will be getting help from a family member with putting it all together and then it will hopefully be quite a learning experience as well. The build i was interested in was on car crafters that i guess is rather budget but just wanna see what you think before i start opening up the wallet. the parts are:
Block, production, 1 piece seal
Scat crankshaft, cast, 1 piece
Scat Comp 5.7 I-beam rod
SRP forged piston
TFS 215cc aluminum head
Comp XR282HR cam
Edelbrock RPM Air-Gap
Demon 750 cfm mechanical secondary
Hedman 13/4-inch headers
A link to the page
http://www.carcraft.com/techarticles...y/viewall.html
They also have a dyno graph of what the motor put out and was said to be roughly 480 hp and 450 ft/tq.
So what you guys think? Any advice or feedback would be much appreciated
SRP forged piston
Comp XR282HR cam
A link to the page
Re: 383 build
Sounds good to me but you likely will make abit more power with afr 210's or speier profiler 210's for same or less money. Run 1.6 rockers with that cam, get it in a tighter 108-110 lsa and you are up 500 hp or so. Trickflows are 1600+ and not even cnc machined
UltRoadWarrior9
04-28-2020 10:39 PM
Mongoose462ci
09-16-2015 11:46 PM
Andrew Prakash
09-08-2015 11:48 AM
