ZZ4 TPI Swap Need Help
1 Post
Car: 1987 Pontiac GTA
Engine: ZZ4 350 W/ HSR
Axle/Gears: 9 Bolt 3:45
I currently have a 87 GTA with a 305 TPI in it. I have a ZZ4 GM crate motor that im looking to setup for fuel injection and swap motors.
Im looking at summit for getting a Weiand Stealth Ram EFI Intake for the ZZ4 but im a little confused on the fuel rail setup that they are suggesting. I looks like a fuel rail setup for a carburated car. Has anyone ever used this intake before and if so could you point a newb in the right direction before i spend a bunch of cash.
http://www.summitracing.com/parts/wnd-7540....This is the intake im looking at
http://www.summitracing.com/parts/hly-534-186....This is the Fuel Rail they suggest.
I read a post on here from someone who did a ZZ4 swap into a TPI car and they suggested 24lb injectors. These are the ones im looking at.... http://www.summitracing.com/parts/acc-150824
Also going to go with a 58mm Throttle Body....http://www.summitracing.com/parts/pfs-69707
If anyone out there could look over this setup and tell me what they think I would sure appreciate it. Or if anyone out there has done a ZZ4 TPI swap I would love to hear from you!!
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: ZZ4 TPI Swap Need Help
Read
https://www.thirdgen.org/forums/alte...gal-whats.html
Not even close
1 Post
Wow thanks for the great pictures....I was confused on the fuel rail but now seeing it in your photos i get the picture (no pun intended) lol
I see you used your stock throttle cable on the side as well. That answers another question I had.
Can you think of any other items I might need for this swap? or any advise with the stealth ram?
1 Post
Why do you say you dont need the TB? everyone i've talked to mentioned getting one right away.
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
You will love the ZZ4 combo. I ran a partial one for years (1990-2004) in that I had the cam, shorty headers and dual cats in a stock 350 89 iroc along with a 160 stat and a chip and the car would fly. If I had the better aluminum heads and a HSR the car would have actually wound up past 4600RPM. The 2.77 gears really worked in that combo.
1 Post
Well like TORN mentioned ^^ i got in contact with another guy who has done this swap and they said the TB is a waste of money too. Told me to reuse the stock TB, said that the HSR will be such an improvement that "upgrading" the TB wont be able to tell a difference.
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
I agree skip the throttle body. However, only certain year throttle bodies clear the throttle bracket on the side. I forget which years but I believe all aftermarket throttle bodies do clear it. I used a BBK 52mm, I feel no difference over the stock 48mm, but it did fit.
1 Post
Thanks RyanJB ^ I will have to do some research on this fitment issue. The engine is sitting on a stand right now so i havnt had to deal with fitment problems. but its nice to know so if I go to install it and have a problem i can remember your post. I had a friend give me a 89 Iroc 350 TB that i cleaned up and painted and put all new gaskets in already lol
well guys im going to do the same thing in my Firebird, i have a ZZ3 which is basically a ZZ4 a few internal differences in material of rods, valve springs and piston(small bump compression from 9.8 to 10) most notably. i do want a HSR because i know after 4,500 RPM my stock TPI will start holding it back and the HSR should take enough torque out of it that i dont destroy my transmission and rear end fast (of course that might still happen IDK). Does anyone make a good chip for the ZZ3/ZZ4? and if i go HSR i might think about a LT4 hot cam or Comp cams in the same range i dont know yet.
Sanjay
08-12-2015 03:41 PM
