305 TPI to 383 Swap
Old 01-14-2015, 08:37 AM
Ryder85's Avatar
Car: 1985 Camaro Z28
Engine: LS2
Axle/Gears: 3:73
305 TPI to 383 Swap
I read some other threads but could not find exactly what i was looking for. I have an 85 Z28 with a 305 TPI, 700R4 trans. I am looking to drop in a blueprint 383 crate motor from summit. I am going to keep it fuel injected and need to know what i need to do to keep it fuel injected and have the TPi work. What size injectors you guys used? type of throttle body used? Manifold used? I cannot afford these ram jet kits and stuff. i need to get it to work as cheap but right as i can. Do i need a new chip? whats involved in the tuning the new motor will need? do i need new flex plate? I am trying to put a parts list together so i can get everything i need and any help would be greatly appreciated.
http://www.summitracing.com/parts/mll-bp38313ct1
Old 01-14-2015, 12:04 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 305 TPI to 383 Swap
I wouldn't use the 85, 1226870 upgrade to the 1227165. The baud rate , code of the 870 ECM isn't that great. For a 430 hp engine you will need 32#hr or could use 36#hr injectors.A Hsr or knock off on eBay would allow the 383 to breath fairly well.
Old 01-17-2015, 08:22 AM
Ryder85's Avatar
Engine: LS2
Axle/Gears: 3:73
Thanks for info, that helps alot.
Old 01-18-2015, 05:05 PM
Engine: Lb9
Transmission: M20
np contact member southbay08 for your injectors. If you mention Tuned you can save 10%
Old 01-19-2015, 08:38 AM
Ryder85's Avatar
Engine: LS2
Axle/Gears: 3:73
i am having a ton of problems trying to find a mass airflow meter to go with the 36lb injectors i have. even summit had no answer.
Old 01-19-2015, 08:57 AM
Engine: Lb9
Transmission: M20
Use your stock max and have your ecm tuned. You will need to buy some equipment like a Aldo to USB cable and use tunerpro rt or tts data master to capture data.
Old 01-22-2015, 05:57 AM
Ryder85's Avatar
Engine: LS2
Axle/Gears: 3:73
The ECMs dont come with chips, so what should i do about a new chip?
Old 01-22-2015, 10:05 AM
Engine: Lb9
Transmission: M20
Post a wanted add in the classifieds, look on eBay, I have a few and would sell you one, tpiparts.net has them.
Old 01-28-2015, 05:54 AM
KCG
KCG's Avatar
Car: 89 IROC
Hopefully not hijacking thread. just looking for more info on this...
Do you know what years this 1227165 came in? I have an '89
Capture data to send to someone to mail order tune it?....or is there a way to tune it myself. I have TTS and also TunerCat for LT1 I used to have. I'm new to TGO as you can tell.
Old 02-06-2015, 05:49 AM
KCG
KCG's Avatar
Car: 89 IROC
bump this back up please...
BlueIroc-Z
06-09-2019 03:22 AM
drewdock87
South Central
08-18-2015 09:02 PM
st.evel07
08-13-2015 06:15 PM
Sanjay
08-12-2015 03:41 PM
drathaar907
08-06-2015 04:20 PM
Quick Reply: 305 TPI to 383 Swap
