sb350 timing install
im building a carbed 350 and installed a miloden double roller timing chain.it seems super tight and when I turn the crank cam gear makes a pop kinda noise.i don't want anything to be wrong..think its to tight?..thanx
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: sb350 timing install
Are your cam and crank gears lined up vertically? Look across the face of the engine to see if there is any misalignment.
ya gears seem to be good..i did give crank gear another go in hopes that it wasn't all the way back...its all together as it should be..i havnt turned crank yet tho...im gunna see..hope it spins like its supposed to
