Swap advice and stuff
Old 05-24-2015, 11:43 AM
Crc1991's Avatar
Found a company that sells complete dropout engines they have some nice 5.3 and 6.0L engines for about 1k-2k with everything on them and guaranteed to work with a warranty. Only thing is there maybe surface rust and sometimes rear main seals are leaky, how much would it be to get that fixed. Also looking at going with a tk0 built 5 speed for about 2.5k. This should have no trouble mounting in the third gen right?
Old 05-24-2015, 11:50 AM
Crc1991's Avatar
Re: Swap advice and stuff
Meant if the tko 5speed is different in getting it mounted then a standard t56? This car will be driven on the street occasionally with the majority of time on track. Down the road I may go turbo or supercharger so less gears would be better for boost. But just taking it one thing at a time right now. Thanks for your advice guys. I'm new to the forums here, go easy on me!
Old 05-24-2015, 06:38 PM
Pocket's Avatar
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
5.3's and 6.0's are still truck engines, so the intake, FEAD and oil pans will need to change adding to the cost
Using the TKO is no different from any T5 swap. Use the 621 BH, a LS1 style clutch, LS2 CTS-V pilot bearing and whatever TOB you want
Old 05-25-2015, 07:58 PM
Crc1991's Avatar
Is the t5 a different swap from the t56?
As far as purchasing a pre made or custom harness what are most people using?
Old 05-25-2015, 08:07 PM
Pocket's Avatar
Car: 92 Firebird
T56's have a reverse lock out solenoid, T5's dont. Order a T56 harness even when using a T5 or TKO
Old 05-25-2015, 08:35 PM
Crc1991's Avatar
Gotcha thanks for the advice pocket. As far as physical size and mounting it, is it any different then the t56?
Old 05-26-2015, 06:19 AM
Pocket's Avatar
Car: 92 Firebird
Yeah, the T56 is bigger, but all fit the 3rd gen tunnel nicely
Depending on which trans, the shifter hole will change slightly
Old 05-26-2015, 11:36 AM
Crc1991's Avatar
Thanks pocket, what are people doing for stronger axles?
Old 05-26-2015, 04:25 PM
Pocket's Avatar
Car: 92 Firebird
Lots of options
Off the shelf are 12 bolt or 9"
DIY guys like me build 8.8s and 9"s
Old 05-26-2015, 04:41 PM
Crc1991's Avatar
Oh cool I messages the DSS and they said they didn't have much available for fourth gens. Good to know there are options.
How much do the F body accesories usually run? With the f body accesories will I need a cowl hood? I was hoping to pick up one of those hoods with a slightly raised cowl but also one of those ram air type scoops in the front the style reminds me of the c6 z06 slit at the front of the hood.
xkingcodex
02-12-2020 07:43 PM
lt1z350
08-28-2015 05:57 AM
E Rod
08-28-2015 05:17 AM
Hello, Michael
08-20-2015 03:19 PM
jharrison5
08-19-2015 05:53 PM
Quick Reply: Swap advice and stuff
