Any use these hooker motor mounts
Car: 91 RS Camaro
Engine: 5.3 LM7
Transmission: 4l60e
For ls swap I'm wondering if anybody had problems lining up a 4l60e trans & what transmission cross member did you use.? Or recommend
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
Re: Any use these hooker motor mounts
You dont want those. For SBC adapter plates, you want 1" setback style that dont have the holes lined up evenly
1" setback is a misnomer, it actually puts the BH in the stock location so your DS will fit without modification. Also, note the holes for the clamshell and engine block dont line up. This is taking the plate thickness into account so you dont have to force the long bolt through
You can also use the hawks/spohn engine stands, but be aware they leave the engine slightly crooked
Car: 92 Firebird
Actually, those look like the holes do line up, so scratch them too
Thats more like it
Thats more like it
Car: 91 RS Camaro
Engine: 5.3 LM7
Transmission: 4l60e
ambainb
04-25-2016 09:21 PM
NBrehm
08-05-2015 07:57 PM
