88 5.0 swap, need to get running
Car: 1988 Pontiac Firebird
Engine: 305 carburated
Im also doing a motor swap but my 5.0 is from an 88 camaro, i have it all swapped over but when i start it, itll start to idle down then die. If i feather it it misses like crazy. If i put it to the floor it pukes. It just will not stay running after it starts but when it starts it sounds nice like its firing on all 8. I have new injectors and new idle control valve but that changed nothing. Any suggestions? Please help, wanna get this bird back on the road.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Re: 88 5.0 swap, need to get running
I moved this from the thread where you posted it to its own thread because it wasn't on-topic where you posted it.
Give us some more details - what your car is, what engine it started off with, what engine you now have, what you've done during the swap, etc.
Fast355
12-02-2016 06:33 PM
Iroc8t8
08-26-2015 08:14 AM
1992 Trans Am
08-08-2015 08:16 PM
