Two or one piece rear main
Okay I have an 88 iroc I'm going to do a 350 carb swap I have a 305 tune port now 700r tranny I'm wondering if I can use a two piece rear main or do I have to use a one piece if I can what's all involved and what do I have to change
Car: '86 Trans Amvanian Frankenbird
Engine: 350 4bbl
Transmission: T5 4.03/.76
Re: Two or one piece rear main
You can use either, just make sure you use a flex plate that matches the crank (The one-piece units are externally balanced and have a weight on the flex plate, the two-piece does not.)
RyanJB
09-14-2015 03:39 PM
Glowsock
09-11-2015 11:09 PM
