Help with ls swap starter
Car: 1992 Z28
Engine: Magnacharged heads cam lq4
Axle/Gears: strange s60 4.10
I have a 92 z28 that i put a ls1 t56 from 01 z28. I have a harness built by pocket. The problem is when i go to plug in the battery it makes the starter start clicking. I am using battery cables from the 01 z28. The positive cable goes to the big bolt on starter and the other positive cable goes to the alternator and the third positive goes to the power distribution block. My negitive cable goes to ground on fender and ground on block above starter. I have a ground from driver head to firewall and ground from block to k member. Any help would be apperciated!
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
Re: Help with ls swap starter
Seems like the starter command wire(typically purple and 12-14 gauge), is connected to hot at all times battery power or a relay is stuck on. Not sure about your set up, but starter command wire is getting power at all times and not just when ignition is on crank
Car: 1992 Z28
Yea i found that my power wire to the starter was touching the solenoid wire so it was making it have power all the time
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Looks like you started two threads on this topic.
Slowridr
35
12-16-2015 09:09 AM
