Anyone interested in me chronicling my 2.8 swap and restore?
Car: 1988 Camaro
Engine: 2.8 to 383
I've had several Camaro's and this will be my first attempt at a swap. Not sure if a good walk through with photo's would be worth it to this board.
Here is what I have so far:
*Laughed, cried and smiled at Kurt & Derek's sticky
*One fantastic, garage kept, grandmother owned and only driven to church on Sundays, 1988 Camaro Berlinetta in white. (slung a rod)
*Set of 1969 Camel hump heads for inspiration.
*Worn out 5.7 block, crank rods and pistons.
*An overabundance (almost gluttonous) of spare time.
*And the most important, a small and limited budget
Any thoughts?
Any thoughts?
Car: 85 Camaro Z28
Engine: 400 SBC .040 over bore
Transmission: TH350 (TH400 on the way)
Re: Anyone interested in me chronicling my 2.8 swap and restore?
Any thoughts?
Any thoughts?
Car: 1988 Camaro
Engine: 2.8 to 383
Just started pulling the 2.8 yesterday with my kids. They are having a blast helping too. I don't have a donor car, and don't on getting one (not enough space). I do plan on this taking a looonnnnnggg time, since it is a hobby and want everything out to come out perfect.
Today I pick up my worn out motor from the junkyard and drop it off at the machine shop. Bored, line bore, new crank, rods, pistons, acid bath, new plugs, new cam bearings and balancing. Plan on staying in the 10:1 CR range.
No idea what I will do for the trans. I have the option of a 400 turbo for $500 rebuilt, but it doesn't have the tail shaft housing for the torsion bar. Stuck in though process on this one, more homework and price checking. Possibly go with the 700r4 and put a toggle switch in for the lock up. Again, thinking.
Heck, I don't even know what color to paint it and it is not staying ugly flat white.
Any thoughts?
Any thoughts?
Car: 85 Camaro Z28
I think it's awesome you're planning on building it with your kids. All the time I spent wrenching with my dad definitely gave me the bug. I plan to pass it along to my son and daughter if either of them are interested. Alright, I'll slow my role a little before I thread jack too much. I'll stay tuned and chime in if I have some good advice. Best of luck on the build!
Car: 1988 Camaro
Engine: 2.8 to 383
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
There are many 383 rotating kit options. Since you said "new crank, rods, pistons", it doesn't cost any more to do a 383 kit as it does a 355 kit.
Car: 85 Camaro Z28
What he said with the only exception being if the block needs to be massaged a little for clearance with the larger crank. With all the other work you're having done they may not charge for this or they might charge $100. All depends on the shop.
Car: 1988 Camaro
Engine: 2.8 to 383
* Should I go with 6 inch rods and short pistons?
* Being the engine 2 bolt mains, will this be strong enough (remember, no stall and street driven)
*One peice RMS, I see scat has cast and forged sets for these applications, are they worth it?
Car: 85 Camaro Z28
I have decided, in light of this advice, I'm building the 383. Done a little research though and have a few questions.
Car: 1985 Z28
Axle/Gears: Best I can tell 3:23
Found a pretty good YouTube video series by myvintageiron7 on a 383 build. This is the first one in the series.
Engine: LS1/LQ4
2-bolt mains should be fine for a street-driven car. The alternative would be to get splayed-bolt main caps and machine the block for them (drill & tap the outer bolt holes, align-hone - this does have to be done by a machine shop). 2-bolt blocks modified this way are actually stronger than factory 4-bolt blocks.
Car: 1988 Camaro
Engine: 2.8 to 383
Ok, I'm back.
Gentlemen, thank you for the advice.
Here is the update:
Block is at the machine shop, but I am only boring it .03 over. Deck looked great actually, leaving it a .025 because of my head selection, which is where I need help from you guys with.
I went with aluminum heads, cheapo FloTechs. 205cc/64cc chambers, 2.02/1.60. Flat top pistons 6.6cc valve relief, .041 gasket/4.166 gasket bore/ and standard deck height put me at 10.22 to 1 compression ratio from the calculator. Will this work on pump gas? I have read a lot on the internet and it is kinda wishy washy. I'm not going to use a knock sensor, remember it's carbed old fashion. I want the most bang for my buck but I don't want to fuel up at the local airport with the expensive 101 or 111.
Also, the shop is recommending that I stick with 5.7 rods, since I am going forged. He said that I will get a really loud cold piston slap and that I should just stay with hyper pistons, short rods since it will never see the strip, only cruising and the occasional haul butt from the red-light.
I'm tossing some old Camel hump iron heads. anyone want them?
Here is the update:
Car: 1988 Camaro
Engine: 2.8 to 383
As far as beefing up the front suspension, a co worker suggested deflating some footballs, slip them into the front springs then re-inflate them. Odd, but really? could it work?
Car: 85 Camaro Z28
Ok, I'm back.
Here is the update:
Here is the update:
Car: 1988 Camaro
Engine: 2.8 to 383
OK here is where I need pro advice
I just got back from the machine shop. Had it bored 30, stroker grind job, new cam bearings and plugs, hod dipped and checked, magnaflux?! is that right?
I purchased a set of aluminum heads, 2.02/1.60, 64cc chamber and 205cc intake, angled plugs. I got a little flak from the shop, he said that these are big heads?! And I would need to deck the block to .000 or it wouldn't run "right" and to expect 10/10.5 to 1 compression ration. He recommends 5.7 rods, flat top pistons and the deck job. Does this sound right? Or is he selling a deck job? He said if I went with these heads and the combo he is recommending that it would be one hot little engine.
Something else about quench~ off to google now!
Car: 85 Camaro Z28
Car: 85 Camaro Z28
Almost forgot to be clear on your actual head selection. I don't think your runners are so large that you'll lose a lot of low end performance. I think decking the block will give you a better performing engine, but whether the $$ is worth the hp is up to you.
Car: 1988 Camaro
Engine: 2.8 to 383
Thanks for the reply, it clarifies things a little better. Now I am diving into the complicated and complex world of CAMSHAFT selection. Is there any advice or warnings I should heed before I endeavor into this magical realm?
Car: 85 Camaro Z28
If you want the best cam for your application without a lot of number crunching and guesswork, choose the style of cam you want (mechanical flat-tappet, mechanical roller, hydraulic flat-tappet, or hydraulic roller) then get with the cam manufacturer of your choice. They're going to ask you a lot of questions about your car like weight, stall speed if auto, head selection, displacement, gear ratios, etc. I highly recommend letting the guys who have spent hours in the dyno room developing the lobes of their cams choose the one they think will work best for you.
Car: 1988 Camaro
Engine: 2.8 to 383
Car: 1988 Camaro
Engine: 2.8 to 383
Soo, took my old friends 2014 gt500 out for a spin today. Supercharged, the works. I'm not going to lie, that thing was FAST. And I mean FAST, he had it dyno'd at 730 rwhp. New goal now, I want to eat that thing alive and it still be just as steetable as his. I now have project goals, I really really really want to out run that thing.
Maybe centrifugal charger? A little boost? Nos? Not sure how I can obtain that kind of RMP range he has with the combination of low end torque too.
I'm really impressed with his ride and sick to my stomachs it was a M**t**g.
Car: 1988 Camaro
Engine: 2.8 to 383
Car: 85 Camaro Z28
If you really want to get there, I would've suggested going with an LS swap. From the research I've done, those things respond to boost much better than our old sbc. Mainly because the heads are 18* with monster ports. We're talking heads that flow closer to stock big block numbers. Forget 2 vs 4 bolt main caps. LS motors have 6. Personally, I would want to do a twin turbo LS if I had to outrun the supercharged GT500. Turbo motors don't have the same heat soak issues, but do typically cost more especially with all the fabrication. Then again, I'd love to do a carbed LS454. An all aluminum V8 in one of our cars would prolly be lighter than the GT500 but honestly I don't know how much the GT500 weighs. Don't get me wrong, I love my old sbc, but I think the LS has surpassed it in making cheap reliable power.
Car: 1988 Camaro
Engine: 2.8 to 383
Ok, update~
My budget won't let change what I'm already building so Im sticking with my current build.
I do have some questions though:
Edelbrock 2701? What do you guys think?
Where in the heck do I get a flywheel for this thing, it's a 1pc RMC, something the 400 never had~ the crank manufacturer says "Notes: Requires a Chevy 400 harmonic balancer and the use of a stock type counter weighted flexplate or flywheel.." Is that stock for the 400 or 350?Any thoughts/recommendations?
I purchased a standard 400 SBC balancer, it is weighted but it cannot be changed. Will this work?
I am shopping for rods and pistons. The target bob weight specified by the crank is 1855 +/- 2%. Any recommendations? How do I shop for that target weight when a lot of these online retailers don't have that info?
AND FINALLY~ Should I buy me a scale and follow the you tube videos for balancing the rods and piston weights or let the shop do it?
Car: 85 Camaro Z28
Well the LS idea was out there a little more for $h!ts and giggles than anything but getting back on track:
You can order a flywheel or flex plate for a sbc 400 from summit racing that is for the externally balanced setup. When balancing a sbc 400, you have to balance it with the damper and flywheel/flex plate attached. You said you have an abundance of time so you could save money by trying to balance the setup yourself if you already have the appropriate tools. If you aren't confident in doing it yourself or don't already have accurate scales and the appropriate tools, I think you'd be peace of mind ahead to have a shop do it. Just make sure that the pistons and head gaskets are going to bring you to around 10.0-10.5:1 compression. I'd calculate using .039" for gasket thickness if you don't already have your gaskets as this is the thickness of my preferred Fel-Pro gaskets. As for the performer intake, I'd step up to the performer rpm with your combo. I am personally a fan of weiand products, but whichever brand is your choice, I'd look for something that advertises it's power starting somewhere in the 1500-2000 rpm range and makes power to about 6500. Your heads are going to make power a little higher in the rpm band so getting an intake to match that is going to help you. Also have you picked out a cam and do you have flow numbers from .050"-.600" lift for those heads? That info would definitely help us help you. I think with your heads, the right intake, and cam as well as the rest of your combo you'll end up with a torquey motor in the vicinity of 450 hp. That should make for a really fun street/strip car.
Car: 1988 Camaro
Engine: 2.8 to 383
So, Im chatting with summit and they are telling me to use the standard counter weighted flexplate for the 350. The crankshaft only needs the external weight up front. Does this sound right? It is a 1 piece rear main seal~
Car: 1988 Camaro
Engine: 2.8 to 383
Here is the chat~
" Dale: Hi, my name is Dale. I will be with you in a moment.
stephen dean: Sure, thanks
Dale: I'll find out. Just a moment.
Dale: I'm sorry for the delay. I'm working with two customers at the same time.
stephen dean: NP, take your time. I just needed clarification on the Notes "Requires a Chevy 400 harmonic balancer and the use of a stock type counter weighted flexplate or flywheel."
stephen dean: If that is a stock type flex plate for a 350 or 400 SBC
Dale: Thank you for your patience.
Dale: Use the flywheel or flexplate for a 350 with a 1 piece rear main seal.
stephen dean: Thats all i needed to knnow, thanks!"
Car: 85 Camaro Z28
He's telling you the real deal. I had a moment there thinking about my sbc 400 vs a 383. Different game same crank. Kind of curious why you didn't go with a balanced rotating kit instead of piecing it together yourself. From my shopping, that typically is the cheaper route in the end without as much headache. Anyway, I ran some compression numbers for you using .025 as your deck clearance, .041 gasket thickness, 4.030 bore, 3.75 stroke, and 64 cc heads. You'll want flat top pistons with somewhere from 5-7cc deep valve reliefs. That'll put you in the sweet spot of 10.25-10.45:1 CR and give you the added benefit of extra piston to valve clearance. Aside from that, just make sure that you choose pistons with the correct wrist pin location for the rod length you choose. Fortunately, they have pistons set up for 383s to use 5.7" rods as opposed to the 5.565" 400 rods you would have to use with a regular 350 piston. You just have to make sure when you order them.
Last edited by BeyondZ28_85; 02-18-2016 at 03:08 PM. Reason: Wrote deck clearance where I meant gasket thickness.
Car: 1988 Camaro
Engine: 2.8 to 383
the pistons are forged 6.6 cc double reliefs.
Will my quench be sufficient with those specs?
Car: 85 Camaro Z28
They'll give you 10.28:1 with your current quench. That'll be 93 friendly and still have thump. Looks good in my book.
Car: 1988 Camaro
Engine: 2.8 to 383
Car: 85 Camaro Z28
Can you give us a part # on those heads? I've not heard of this issue before. Maybe five7kid or someone else who's been in the hotrodding game longer than I have has came across heads without the water passages you're referring to.
Car: 1988 Camaro
Engine: 2.8 to 383
UPDATE!!!
How does it look?
fkboatman
01-09-2016 04:58 PM
