V6-V8 Swap Questions
Car: 88' Camaro
Engine: 2.8L V6 MFI
Transmission: T5 Manual
As my 1988 Camaro's V6 is aging, I'm pondering engine swap options, and have been eagerly reading pretty much every thread I can find on the subject. I see I have lots of options, but I've pretty much set my mind on the stock 350 TPI V8 swap. However, I have some questions on topics I haven't seen covered yet...
First, the donor car. From my readings I have decided that a donor car is a desirable technique for swapping, and the best choice for me, since I have no desire to search hither and yonder (either salvaging nor purchasing new) for the parts I would need to perform the swap.
I know that there is only a .7 liter displacement difference between the 305 and the 350, and I'd like to know where that difference is made. Is the bore size larger in the 350, or is the bore size the same but the stroke longer??? Do both use basically the same block?
The reason I ask that is because as I search for my donor car, I am wondering: If I had more luck finding a 305 donor, rather than a 350, would it still be viable donor for swapping parts (brackets, general accessories, exhaust, etc.). If I find a 350 donor, that would be great, but would it be possible to bolt up 305 brackets, accessories, exhaust, etc. onto either a rebuilt 350 or a crate 350, if I can find a decent 305 donor?
Second, is there more involvement regarding the A/C system during the swap other than changing the lines going to and from the A/C compressor, since my V6 compressor bolts to the drivers side of the block and the V8 bolts to the passengers side? Do I simply need to change those lines (which would be shorter) than what I have now?
Any guidance would be greatly appreciated!
Car: 1988 Camaro
Engine: 2.8 to 383
Re: V6-V8 Swap Questions
No offense, but it sounds like you need to do a bit research before get into this journey.
First, what are your goals? Daily driver? Street? Strip? Drag? Budget? Time Frame? Knowledge of engines/engine building? Since the variables are vastly different with each approach, it is nice to know some background intention.
The externals on the 305 to 350 are identical. The bore size is smaller on the 305 and is NOT thick enough to be bored to the 4.00in of the 350(the 305 bore escapes me at the moment).
All of the accessories and manifolds will interchange.
The easiest way to do your swap is find a running v8 car and go from there. The trans from your car will not work either so you will need to find a 5 speed car or the trans separately if you find an auto car.
As for the AC, just using the correct lines and the V8 compressor and you will be fine.
As Stephen said though, start researching. Good luck!
Car: 88' Camaro
Engine: 2.8L V6 MFI
My goal is a daily driver (as it is currently my daily driver), on a moderate budget. I'm looking to spend no more than $3500 on the engine swap, and the same on a transmission swap. I am NOT seeking excessive hp. What I'll get from a stock 350 tpi will be plenty for me. Again I have done research towards transmission options, and I won't discuss my plans for that here, since this thread is for engine swaps, but be sure, I am aware that using a T5 behind a 350 is not feasible. I'm not planning on doing any of the rebuilding of the engine alone, I'll have experienced help. I have yet to speak to him in great detail about my intentions, but I plan to do so in the near future, and when I do surely I'll get some good info from him as well.
All I want to know at this point is whether it is possible for me to use a 305 donor for the external (outside the engine block itself) components of the swap.
Car: 88' Camaro
Engine: 2.8L V6 MFI
I posted this today because I may have found a running, or almost running (it ran when it was parked 2 years ago) 1986' z28 in Salt Lake that I might be able to purchase. They're asking $600, so I figured that might not be a bad deal for a donor... I don't know if it is a 305 or a 350, so that's the main reason for this post... to learn if i might still be able to use it if it is only a 305.
As I assured stephenscamaro above, I am aware that I will not be able to feasibly reuse a T5 behind the 350. I'm looking into using a T56, because I want to continue to have a manual transmission. I'm aware of the factors to consider for that swap. I've already done lots of reading, and I consider myself nowhere near finished. I don't plan on making any changes until summer of 2017 (provided I can get another 30,000 or so miles out of my original powertrain that has 210,000 right now), so hopefully I'll have a lot more time to make plans and prepare.
Thanks for your reply!
Car: 1988 Camaro
Engine: 2.8 to 383
Well, as I said in the first post, I have been reading lots of threads (scores of them in fact), and again, I have lots of information that I have learned from them, so the inquiry in this post is a just one small part of my research that I have done so far, and plan to do in the coming months. I have been reading for a couple of months already now, and I am not planning to actually do the swap for another 18 months or so (provided my engine nor transmission fail before then). So I'm planning on another 18 months of research and planning before this actually happens.
My goal is a daily driver (as it is currently my daily driver), on a moderate budget. I'm looking to spend no more than $3500 on the engine swap, and the same on a transmission swap. I am NOT seeking big hp. What I'll get from a stock 350 tpi will be plenty for me. Again I have done research towards transmission options, and I won't discuss my plans for that here, since this thread is for engine swaps, but be sure, I am aware that using a T5 behind a 350 is not feasible. I'm not planning on doing any of the rebuilding of the engine myself... Again, not the topic of my thread.
I always have this thought process: If i am going to put my hard earned money into something, i want the best and most I can get out of. Biggest bang for my buck.
And I like bragging rights!
Edit- the brackets I am using came from a 305, so yes they will work. if you need pics, hit me up and ill get you some
Car: 88' Camaro
Engine: 2.8L V6 MFI
Well, lets think about it in this view point. A 305 is less cubic inches than a 350. Cubic inches or CID is the base line for your power. A hot 305 produces the same power as a stock 350. So, if you start with a 350 to begin with, you start out with more power baseline. If you plan on building the engine or having it built professionally, it costs no more to have the 350 stroked out to a 383. That is 78 more cubic inches in the exact same weight block, making A LOT more power, for the same cost of rebuilding and machining a 305 or 350 block, which is essential. You can build a mean street engine that performs reliably and gets reasonable gas mileage, so it is all in your view point.
That is great insight. Thanks for pointing out that as an option, I will have to seriously consider that! Just for curiosity's sake, how many more horses would that give me and what might be gas mileage? That's great advice
Car: 88' Camaro
Engine: 2.8L V6 MFI
As for the mass air versus speed density, my 2.8 runs with a mass air flow, so i'm fine with having that as well.
Thanks again for pointing that out to me. I'm learning a lot from you guys and I still have a lot to learn
Car: 1988 Camaro
If one external part fits one small block chevy, it will fit all small block chevys.
So the brackets, pulleys, etc from a 72 307 will fit a 98 vortec 350 if you wanted to do that. lol.
The 305 vs 350.. It's the bore size. Both uses a 3.48" stroke but the 305 has a 3.736" vs the 350's 4.000" bore. Max overbore is 0.060"
Warnd
06-07-2013 05:31 PM
SargeantSarkasm
06-08-2012 05:51 PM
knightyper99
08-02-2011 01:35 AM
89' RS/blue
06-13-2011 09:09 AM
88Cvert
10-18-2010 01:00 AM
