511ci with turbo 400 some trans ?s
Car: 91 Z-28
Engine: 350 carb
Transmission: built 700r4 megashifter
Axle/Gears: 4th gen 3.73s
Okay guys so I'm starting a build thread because Ill need the help and advice. And just because I'm pretty excited to get this going. I've learned a lot already from people on here with my 305tpi to 350 carb swap. So I already have the carb setup working in my favor.
I'm going from southern VT to north eastern PA to pick up a 511cid short block. I'll be building the short block over the winter, as well as swapping a built turbo 400 into the car.
So I have a few things to clarify if anyone is still reading...
Is there a set of headers that fit around a turbo 400 better than others?
Is the driveshaft issue easier with a short tail 400 or a long tail 400?
Is the trans cross member going to located in the same position, or is it going to need to be moved?
How long can I expect that 4th gen rear end to last at around 600hp lol? And what will my options be when I grenade that.
Car: 91 Z-28
Engine: 350 carb
Re: 511ci with turbo 400 some trans ?s
Quick pic of the car, and out with the 350 and built 700r4. Got a guy coming up from Boston before I leave in the morning to buy the package! Also picked up a 5inch cowl induction hood on CL that will be covering up that big block I hope.
Car: 91 Z-28
Engine: 350 carb
I think I read somewhere that the largest diameter primary pipes on the BBC swap headers is 1 7/8 inches. If that is the case, has anyone here made a set of headers out of anything 2" or bigger for a BBC?
What are my options for a rear end swap? Could someone weigh in on what would be my easiest option there? What to do with the tq arm.
Car: 1991 CAMARO Z28 VERT
Engine: LS2
Transmission: MAGNUM T56
Axle/Gears: STOCK 7.5/3.73
ON YOUR TORQUE ARM PROBLEM .I FACE THE SAME DELEMA AS I AM GOING TO A LS2/TREMEC MAGNUM TRANS. THE MAGNUM TRANS DOES NOT HAVE A TORQU ARM MOUNT ON THE TAIL SHAFT. SO I WILL BE USING A TRANY/TORQUE ARM CROSS MEMBER FROM SPOHN.THIS WILL ALLOW ME ALSO TO ADJUST THE PINION ANGEL ALSO.
Engine: LS2
AS FOR THE REST OF MY BUILD I WILL KEEP EVERY ONE INFORMED OF THE LAS SUPERCHARGER ADDTION , CANT WAIT TO BREAK THE REAR AXLE, THEN IT WILL BE ONE OF HAWKS 8.8 REAR END OR I FIRST CHOICE WILL BE THE JAGUAR XJ6 IRS AXLE WAITING FOR A HOME..........GOOD LUCK ON YOUR BUILD!!!!!!!
