and yet another 400 sbc to tpi question
I have a 1988 gta 305 sbc....
tpi
I have a opp to get a crank and block in good shape and I want to build it over winter and put it in my 1988 gta 305 tpi
I just had my heads rebuilt is it possible to use them on the 400 sbc so I can keep all the tpi???
what head gasket would I use
or can I just get used 400 sbc heads and bolt my tpi to it???????
ty
tpi
ty
Received 1,664 Likes
Re: and yet another 400 sbc to tpi question
You might be able to use your 305 heads; that would depend to a great extent on EXACTLY what the 400 is. If it has the usual "rebuilder" type of "stock replacement" pistons, it would probably work. If OTOH it has decent ones, the compression will be WAY too high for pump gas.
305 heads have teeny tiny valves, which are a restriction even for a 305. They'll totally strangle a 400. Although, with TPI on it, that'll be so much of a performance killer that the valves might not matter all that much... they might not be "the bottleneck".
my 305 got 240 rwhp and 310 rwtq
with those tiny valves and tpi
I love tpi its pure torque monster
and my car was running rich
300 hp engine and 375 engine tq
14.3 that's ben tec
14.3 that's ben tec
