Notes on Installation of Hooker Long Tube Headers (2210)
Old 06-05-2003, 07:30 AM
  #101
Momar's Avatar
So there were no problems with the t56? That is awsome. I already have the longtubes, but want to get a t56. I thought that I had read that they wouldnt fit together.
Ben
Old 06-05-2003, 11:37 PM
  #102
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
Nope, i just installed mine with the T56 and clearance is fine. Here is the closest thing on mine.
Old 06-05-2003, 11:39 PM
  #103
Momar's Avatar
Cool and thanks for the pic. I guess that just means that when I finally get around to getting one that there will be a little less modification.
Ben
Old 06-05-2003, 11:50 PM
  #104
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
I'll take a pic of the drivers side tommarrow when i'm back under the car so that you can see the clearance on that side.
Old 06-07-2003, 06:02 PM
  #105
prockbp's Avatar
Car: 1989 IROC-Z
Engine: 1992 TPI 350
Transmission: 1989 T5
Axle/Gears: 1992 10 Bolt Rear w/ 3.42 gearing
i would just like to mention some of my experiences compared to some of trax's experiences...
i agree with all points except the ones that i reference here:
point#
2. the stock starter worked fine, we removed it to install the headers then reinstalled it
4. and 5. no grinding neccessary
13. my mufflex y-pipe bolted right up... but it is a bit of a puzzle because some of the pieces(particularly the pieces that bolt to header collectors) have different angles built in to them.. my only complaint about mufflex is that i broke one of the clamps that comes with their stuff
15. i bought the mufflex 3.5" single outlet cat-back, it fit ]PERFECTLY[ with the mufflex y-pipe ... everything tucks up very very nicely(it is up to you to make it tuck up nicely though, there is plently of play in a system with that many joints)
16. i used my 80k mile stock motor mounts
18. my stock plugs worked fine with the headers(i have stock heads) but i did need angled boots
and that's it, just a summary of how my experiences differed from Traxion's
Old 06-07-2003, 06:33 PM
  #106
Momar's Avatar
point#
Well, mine went about the same as yours other than the fact that I have dual exhaust instead of the mufflex.
2. I used the stock starter for a while, but I happened upon a lt1 starter that didnt cost anything so I am using it. I actually had the stock one in and out a couple times with the headers also and I only had to remove the slip fit primary.
4. and 5. Ditto. No grinding.
16. I did however have "new" rubber mounts.
18. I used stock plugs and they worked with a shorty socket I made, but when I changed them I used shorties because it just made it a bit easier. (ported 416 heads)
Ben
Old 06-18-2003, 04:09 PM
  #107
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 9" 4.11 Truetrac
where can i get this mufflex Y pipe, whats the part # and will it clear a T5 tranny also would a 2" drop cause this setup to sit on the ground?
Old 06-19-2003, 06:50 AM
  #108
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Point #13 in the sticky for PN and the 'where' to get it. IMHO, a 2" drop is too much to run the Hooker Long Tubes and the Mufflex Y-Pipe without some front frame modifications to make room for the exhaust to tuck up closer.
Tim
Old 06-21-2003, 04:12 PM
  #109
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Got mine in the car last week with very little problems as well. I have a mini starter which worked out great and i too had no clearancing issues, so far! I recently did a motor swap and had bought new mounts, but when we got the motor out, the stock 82K mile mounts were still in great shape, so i decided to hold off on those. I also had some minor issues with the brake lines on the pass. side of the k-member, which i just simply moved around a bit! Was carefull not to crease it, just bent it around a bit so there would be no more problems with it. The hardest damn part of this install, for me, was getting the damn oil filter off! lol I have a crate motor and they put that damn filter on so tight it was unblievable! I went up to Pep Boys twice to get different wrenches for it and i wound up getting lucky with one of them. The oil filter looked like confetti when i was done with it. That needed to be done and also jacking the car up high enough to get the drivers side header in. Besides that the install went pretty smoothly. Thanks to the people who responded to TRAXION'S post as well as TRAXION himself for getting this info out there! I mean, it could be done without this thread but it just went more smoothly and i kinda knew what to expect with this info being out here. As far as an exhaust system, have no clue what to go with now. I mean i have some ideas, but i am open to suggestions, that is if you read through my BS post! lol Thanks for your time and help guys. Later-Bryan
Old 06-21-2003, 09:00 PM
  #110
SLP IROC-Z's Avatar
Car: 1999 Z28
can one of u guys measuer from the closes part of the header to the ground and what ur fender lip to ground height is as well.
Old 06-22-2003, 03:09 AM
  #111
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Sorry man, car is on jack stands still!
Old 06-22-2003, 07:21 AM
  #112
agchoset's Avatar
Car: 2001 C5 convertible
Pictures of the full setup nearly finished
Got some pics while I the car was at the shop having the joints of the y-pipe welded, as well as having the O2 bungs welded in and the muffler hangers fabbed.
The pics are a bit large, so dialup users beware. I may get around to shrinking them down, or may not.
Pic 1
Pic 2
Pic # (clamps still in place in this one)
Pic 4 (good full-length side shot of the car -- angle is a bit deceiving though)
Pic 5
Pic 6
Pic 7 - clearance between Skulte T56 crossmember and Mufflex Y-pipe after tweaking
Enjoy :-)
Andrew Choset
88 IROC-Z
Old 06-30-2003, 10:35 PM
  #113
Kingtal0n's Avatar
Car: 240sx
Engine: whatever works
Transmission: 4l80e this year
Axle/Gears: 3.512
I just ordered Part# HED-68460-6 from summit, Hedman Coated Longtubes... mainly out of curiosity. I wanted to see how the long tubes would fit in my car...
now im really curious. Ill be using the stock 100K motor mount, a 700R4, and I have a catback on it right now. the motors coming out this week so i was going to test fit the hedmans on the motor before i removed it....
One of my concerns is I need the O2 sensor in the headers, and i dont think those are coming with it, so Im wondering if i need to get a diff. part number with the O2 hole or how can i modify them with the coating on them for the O2 sensor... ?
Old 07-02-2003, 07:02 PM
  #114
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Well I just installed my Hooker Long tubes..... I installed them while I was putting in the motor and I have stock motor mounts.
1) The driver's side header dropped right in with absolutely no clearance problems.
2) The passenger side is a major PITA. It hit all the places TRAXION mentioned. I'm still trying to get it to fit nicely. I also had to bend the brake lines way out of the way
3) I thought my stock starter would fit but it DEFINATELY doesn't unless I beat in some of the tubes ....so a mini-starter is on order.
4) I have vortec heads which are straight plug. The #7 plug is so close you couldnt even remove it so I dented the tube in and now its got plenty of clearance. I'm glad I didn't buy the nice purdy ceramic coated ones because I've scraped and dented these things to sh!!t.
Really fun ....about as fun as getting your teeth pulled out.
Old 07-03-2003, 12:26 AM
  #115
Kingtal0n's Avatar
Car: 240sx
Axle/Gears: 3.512
can anyone share experience with the hedman longtubes?
Old 07-03-2003, 10:46 AM
  #116
TRAXION's Avatar
This sticky post is for Hooker Long Tube headers ... not Hedman. For relavant posts about Hedman Long Tubes just do search. There's a bunch of unconsolidated info on this board about the Hedmans ... but you won't find it in this post.
Tim
Old 07-12-2003, 08:25 AM
  #117
maniacc's Avatar
Thanks to all who have contributed to this post, i have been considering installing hooker long tubes for some time but have heard of alot of problems, but this thread has seemed to address them all, except one...
Will the long tubes fit with A/C system still intact...i looked thru all the pics and could seem to find anyone that retained the a/c???
thanks again for this great post!!!
later
larry
Old 07-12-2003, 09:03 AM
  #118
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
88+ cars with the serp belt system will have no issues with retaining the A/C. There are a couple of braces that mount from the stock manifolds to the accessory brackets to help eliminate vibration. It is your choice to eliminate them or fabricate some custom spacers down on the header to keep them. Nobody I know uses the braces, and we all have been running without them for years with no vibration issues whatsoever.
I am running A/C and supercomps with zero problems. (see sig pic)
Old 07-14-2003, 08:17 PM
  #119
Kingtal0n's Avatar
Car: 240sx
Axle/Gears: 3.512
uh oh. whats it mean when the coating turns from shiny silver to a non-shiny flat white color? i think they got a little too hot.
Old 07-14-2003, 08:28 PM
  #120
jon_volk's Avatar
you didnt install these headers on a brand new motor did ya? your not supposed to use ceramic coated headers during break in b/c the egt's get too hot.
Old 07-14-2003, 08:41 PM
  #121
Momar's Avatar
I did the same thing. A wet rag took the white back to the shiney coating. Scared the crap out of me though. No one told me not to use the coated headers on a new motor break in. Not to mention that I had the old style timing tab with a new balancer so I was running very retarted to start with. I got those suckers glowing orange. Whoops!!!!
Ben
Old 07-14-2003, 09:36 PM
  #122
JMatlock88's Avatar
Car: 1991 Formula
I did the same thing. Mine got to the point where the alum began to surface (looks like aluminum sandpaper shavings on the pipes) A scotch brite pad and some restoration polish found at www.hpcoatings.com did the trick to restore the finish.
Old 07-15-2003, 03:40 AM
  #123
Spdfrk1990's Avatar
So your saying if you want coated headers on your new engine you have to buy the non coated ones then put them on break it in then take them back off to coat them
Old 07-15-2003, 07:43 AM
  #124
JMatlock88's Avatar
Car: 1991 Formula
Not really. Most can/will correct the timing immediately on a predictable new motor setup. As for my situation, I had to run my timing far from stock for it to run right on the stock chip. Timing was way off where it needed to be at idle but closer at cruising speeds, hence the red headers at idle. I had a new chip within a few days, but the coating was damaged slightly.
Old 07-15-2003, 11:56 AM
  #125
Momar's Avatar
Mine was also a mishap. I had the wrong timing mark so I had the timing way to retarted for cam break in. I think that if you have everything set right you would be fine.
Ben
Old 07-15-2003, 03:06 PM
  #126
Spdfrk1990's Avatar
thats cool just the way they were talkin was like ohh no u used coated headers on the break in
Old 07-15-2003, 03:09 PM
  #127
jon_volk's Avatar
we were talkin like ohh no b/c you wont find any header company that will warranty the ceramic coating if it was used during engine break in.
Old 07-15-2003, 03:16 PM
  #128
Spdfrk1990's Avatar
its not like they would know its brand new unless they came and seen it
Old 07-15-2003, 08:27 PM
  #129
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
Since just about everyone in here is using the mufflex catback system, what muffler does everyone prefer as far as sound? spintech or the flowmaster?
Old 07-15-2003, 10:22 PM
  #130
JMatlock88's Avatar
Car: 1991 Formula
My three chamber Flowmaster 4" is extremely quiet and unagressive. It has a tin/metalic mid range exhaust note.
Old 07-16-2003, 12:35 AM
  #131
Kingtal0n's Avatar
Car: 240sx
Axle/Gears: 3.512
<b>A wet rag took the white back to the shiney coating</b>
A wet rag? so if i go out there with some water on a rag and wipe real hard it may fix the coating?
<b>A scotch brite pad and some restoration polish found at www.hpcoatings.com did the trick to restore the finish.</b>
what is scotch brite and what is restoration polish and how do i use it? after i try the wet rag trick of course...
and no it wasnt a "brand new" motor it had about 200 miles on it, but it was running at about 2* advance for the first few minutes while i set up the base map so it would idle steady for me to check the timing. i kept running back and forth between the throttle body and the desktop computer (in the car) to set the darn idle, then took me about 2 minutes to figure out how much fuel was too much on the map. sigh*
Old 07-16-2003, 07:19 AM
  #132
Momar's Avatar
I wont say it will work for sure, I may have just got lucky. Also I havent even cleaned up my entire headers yet to see if it works on the whole things. I just figured out it worked last weekend when I had the car up on a lift to work on my tranny. I was trying to wipe some oil off of it and realized that it was taking away that dull white that was there from when I had the timing retarded. I tried it on the bottoms of several of the primaries and it seemed to be working. I plan to try to do them completely soon.
Ben
Old 07-17-2003, 11:46 AM
  #133
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Ive read all the way through, but I cant seem to fin out how much the headers were?
Ive seen them for $399, but how much are they from jet-hot pre coated?
Old 07-17-2003, 11:54 AM
  #134
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
I got mine for $580 shipped to my door from jet hot and thats including the 2 o2 sensor bungs.
Old 07-17-2003, 12:02 PM
  #135
SweetS10v8's Avatar
Engine: L98 & 355ci
hmm, i jsut called and they quoted me $628 shipped? did you get any club discounts or anything?
Old 07-17-2003, 12:08 PM
  #136
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
I ordered two sets, thats probably why they cut me a deal.
Old 07-17-2003, 12:09 PM
  #137
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
You only really need one o2 sensor bung if you don't plan on hooking up a EGT or do any wideband tuning.
Old 07-17-2003, 12:14 PM
  #138
Car: '89 IROC-Z
Am I the only person having issues with getting the header bolts in? I installed the headers a week or so ago but didnt put all the bolts in. Today I go out to put in the final bolts and like 3 of them wont go in because the primary tube hits 'em. I have Stage 8 locking bolts but I dont use the locks ....I guess I'm gonna round off the end of the bolt and just use an allen wrench to screw them in......
Old 07-17-2003, 12:35 PM
  #139
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
i had that problem only on the number one cynlinder primary. All the rest were fine for me.I just nouched it in with a hammer and all is well now.
Old 07-17-2003, 03:38 PM
  #140
fb305svs's Avatar
doesnt jegs sell them already coated? liek 550 bucks....
Old 07-17-2003, 05:27 PM
  #141
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
On some of the bolts, in the middle cylinders, I had to start them first with the header pulled back a little from the head because the primary tube swelled about 1/2 from the flange, hope this helps some.
Jason
Old 07-17-2003, 05:44 PM
  #142
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
I don't believe they have the same finish as the jet hot coated ones. I could be wrong. I am referring to the sterling silver jet hot coating.
Old 07-17-2003, 06:00 PM
  #143
Momar's Avatar
Jason
Ditto that. I just dont start them all before you tighten any. It should be fine.
Ben
Old 07-24-2003, 08:06 PM
  #144
fb305svs's Avatar
Just got my set- got them bolted up to the motor on the engine stand... i have a very usefull measurement for all of you wondering how much lower they hang than normal exhaust's
refer to the pic below, if someone wants to host it, that's fine by me- dunno if my ISP is gonna aprreciate a bunch of hits lol..
anyways, using the bottom of a stock oilpan as a measurement (specifically the gm pan that comes on the zz3's, which is the same size as out stock pans) it comes out to the headers hanging about 1 3/4" below the oil pan to the lowest point.
Although this seems like a lot to some of you, keep in mind that a lot of people's y-pipes are the actual lowest part in their exhuast systems.
Good luck everyone, here's the pics of mine- ordered through summit, 589 bucks, ceramic coated.... things are beautiful, best quality header i have ever seen to be honest.
http://home.zebra.net/~stevesoares/w.../P1001216a.jpg
http://home.zebra.net/~stevesoares/w.../P1001220a.jpg
http://home.zebra.net/~stevesoares/w...P1001223aa.jpg
Old 07-30-2003, 04:09 PM
  #145
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
Those ceramic coated headers do look better than the Jet-Hot coated ones that I've seen, plus they're cheaper. But I'm curious to know what your guy's opinions are on whether or not to order the 2210's with ceramic coating? Or is a coating like Jet-Hot or similar coating much better as far as reducing temps and looking perty for a long time? If I need to ask this q in a new post I will, but I figured more guys with the 2210's would be more apt to check out this thread.
Old 07-30-2003, 05:51 PM
  #146
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
those ceramic coated ones look just like my jet hot ones. I don't see the difference in the pics versus mine on my car.
Old 07-31-2003, 09:08 AM
  #147
TRAXION's Avatar
If you really want to do it right then you will want the Jet Hot coating because you can get their special 2000º coating. That level of protection isn't available from Hooker.
Tim
Old 08-05-2003, 06:46 PM
  #148
Moderator/TGO Supporter
AaronIROCZ's Avatar
When installing my hooker headers I had to install all bolts 1 or 2 turns into the head and then turn all of them evenly to get them all the way in. (88IROC350TPI) And My GTA sounds EXACTLY like TRAXION's car. FYI
Old 08-06-2003, 04:01 PM
  #149
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i had the same problem with the bolts and i used the stage 8 locking header bolts. you will have to grind down the washer they give u like in the picture they supply where it looks like a C. i had to do that on a few of them to get them to fit.
the only problems i have now is the y pipe its the trans xmember everynow and then and will vibrate(not so bad) but then i also have a few exuast leaks ill have to weld up closed.
does anyone think the spin tech pro street muffler will sound good with the hooker long tubes and mufflex ypipe (i have no cats shhhh)?
i heard that one guys car the one with the blue z28 with the custom true duals and i like how it sounds but thats true dual and not single. also i forgot you it was but someone has there flowmaster i think with the center inlet and outlet and the single dump in the stock location. i was thinkin of running mine becuz everyone around here has the hooker catback and im gettin sick of it
Old 08-06-2003, 04:21 PM
  #150
Momar's Avatar
I think it would sound good. If I ever get my duals clear out the back I want to use those mufflers. They sound awsome.
Ben
Quick Reply: Notes on Installation of Hooker Long Tube Headers (2210)
