blue smoke at idle? valve stem seals right? please help! - Third Generation F-Body Message Boards
Thread Tools Search this Thread
Old 04-11-2005, 10:42 PM   #1
Car: 1992 camaro rs
Engine: 305 tbi
okay, I have a stock 92 camaro rs 305 tbi, with open element. I bought it used with 100,000 miles. The original owner was an older gentleman, I have every reason to think it was well maintained. The engine bay was a little dusty but nothing like ones I have seen. I mean no leaks from the top or bottom of engine or trans. The motor had some blue smoke at start up but seemed to clear up after driving. Then I noticed it would smoke at idle in traffic. I checked this wonderful web site for information. Its got to be the valve stem seals right? Well, $405 dollars latter with new seals. Now it`s smoking twice as bad. I know the mechanic and saw were he replaced the driver side on a surprise visit. He was bummed with the results too. The motor just runs and idles too smooth for it to be the rings? I replaced the plugs and wires, distributer, rotor button and installed a stage 1 chip before the seals were replaced. I purged the engine today but it got dark on me outside. I really couldnt tell if or how bad it is still smoking. Im stiil crossing my fingers hoping tomorrow will be a clear day. LOL. I cant stand the smoke! Can anyone help? Sorry so loooong I just wanted to be thorough.
rob37nc is offline vBGarage Page   Reply With Quote
Old 04-14-2005, 09:15 PM   #2
Car: 88 Pontiac Trans Am (crap)
Engine: 305 TBI (crap)
Transmission: TH-700R4 (crap)
Axle/Gears: 2.73 (crap)
have another mechanic check the valve seals, the only other thing i could thin of is over-oiling?
useful_idi0t is offline vBGarage Page   Reply With Quote
Old 04-20-2005, 11:16 PM   #3
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Not to shoot you down, UI, but I seriously doubt its over oiling. What typically happens when you have leaky valve seals, is that it will shoot a little blue smoke (oil) for a moment, and clear up almost right away. This is because oil leaked past the valve seals while the engine was not running, and what did get into the cylinders is being burned off now that the engine is running. If it constantly smokes at idle, then I'd look somewhere other than valve seals unless they are REALLY bad.
Something I had a problem with a few months back, was a leaking intake manifold gasket. It wasn't bad enough that it visibly smoked, but looking at the spark plugs showed the engine was burning some oil. Turned out that the bottom of the intake gasket on one side of the engine was leaking, and was sucking in oil. I replaced the gaskets, and it cleaned up right away.
If you want to find out if your rings are good, the best thing to do would be a compression test. That will tell you if they are in good shape or not. Worn rings could definitely be the cause of the smoking.
Air_Adam is offline vBGarage Page   Reply With Quote
Old 04-22-2005, 06:40 AM   #4
Car: 1992 camaro rs
Engine: 305 tbi
Thanks U.I & Air Adam for your replies. I found the problem with the excessive blue smoke. I came across a thread where the guy was talking about checking the oil galleys.
I pulled the drivers side valve covers, the 2 oil passages were, 1 on the far left corner & the other was the far right corner. I took a small 1\16th inch wire and began picking pieces of hard sludge from the holes clearing the passsage. Once I was sattisfied with that I bent a tight small hook on the end of the wire and began pushing it further in the hole until I pushed through were it seemed to lead to a bigger opening maybee to the crank case. The next day I did the same on the passanger side. These two holes were so packed there was no way the oil could leave the top of the head. My guess was the oil was getting in the top of the head and was just sitting there were ther was no were to go. Just burning up the excesssive oil and blowing it out the exaust. When I changed the plugs when I first got the car all the plugs had normal wear except the back 2 plugs had oil deposits on the passanger side. Anyway, put it all back together and presto, no blue smoke anymore!!!!!!!!!!!!!!! Now I`ve got to look up that thread and thank that guy for the good advice. See ya`ll.
Old 04-22-2005, 03:54 PM   #5
Air_Adam's Avatar
Good to hear its been fixed, AND unlike most people here, YOU FOUND OUT THE USEFULNESS OF THE BUTTON!!
See guys? The search button works great!!
Thread Thread Starter Forum Replies Last Post
1992 camaro 305 v8 TBI idles very high and shifts at high idles db057 TBI 11 06-07-2016 09:26 PM
Backfire and Black smoke what do I do? Red iroc-z 305 Tech / General Engine 8 09-30-2015 06:22 PM
Car really hard to start after sitting SolarGoldRaptor Carburetors 16 08-25-2015 03:25 PM
Project Torched 2.0? 86White_T/A305 LTX and LSX 0 08-17-2015 01:16 AM
Blue valve covers? mustangman65_79 Tech / General Engine 4 08-08-2015 02:18 AM
Go Back   Third Generation F-Body Message Boards >
Tags
305, blue, burns, exhaust, gasket, idle, idles, intake, leaking, leaky, oil, seals, smoke, smokes, stem, stems, tbi, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
