Third Gen Dual Exhaust Picture Collection
Old 08-15-2008, 06:30 AM
  #201
4RCEPWRD's Avatar
Car: 82Z28
Re: Third Gen Dual Exhaust Picture Collection
Originally Posted by 89ta_jay
id like to hear a sound clip with the borlas
Ill try to get a clip on here tonight.
Old 08-22-2008, 06:02 PM
  #202
cronsformula350's Avatar
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
I finally have my true duals finished on my formula, I used Heddman S-bends, going into a a h-pipe, then 35" back, the 2.5" bullet mufflers, then some dumps, right before the sway bar, check it out.
Then I painted the rear axle, right now I'm still working on installing the rear Spohn Lower control arm relocators, then the Lakewood control arms. I'll put in a Lakewood panhard bar later.
The cars making so much torque right now, with the car up on the jackstands; while I am idling, with the brakes all the way to the floor, the rear tires are still spinning. I have to turn the service/parking brake on, then it barely stops them from spinning.
my site: www.cardomain.com/ride/471099
Check it out, I'll take a video of the sound of the exhaust soon too.
Old 09-01-2008, 11:41 PM
  #203
I just posted some vids of my dual exhaust sound now too so, check them out.
Old 09-02-2008, 07:09 AM
  #204
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
that car looks excellent! the exhaust is simple, much like a couple of my old systems, very clean my friend.
i will tell you, from past experience...the brake problem you're experiencing is not too much torque from the motor, but rather not enough brakes, lol! you need to find out what's going on there...whether it be a sticking caliper or some old brake hoses, or what have you...check into that further...you should be able to stop.
Old 09-02-2008, 02:41 PM
  #205
Well thats the thing, when I Had it down from the jackstands yesterday, it holds back like it usually would. The calipers are the borgwarners, for the 9-bolt, they were replaced just before I bought the car along with a lot of other parts, because of the foolish owners, lol.
The action of the calipers, are working properly, but it may also be because, the car hasn't been driven in 5 years, just once around the block about two months ago, and the rotors are pretty rusty, so that doesn't help. I just took a brake class in the srping, so I'll look at ig more, but on my cardomain site, I have new videos up, and it sounds great, theres still some oil from the cylinders burning off, but it rumbles, about 98-100 db's at idle.
But some of the paint is starting to bubble, from the bad primer and paint they used in the 80's, its a little on the roof and hood, but that hood will be replaced with another next year, with that 6 banger from a 84 firebird, and that scoop I'm showing on my site.
Old 10-26-2008, 02:11 AM
  #206
chaoz28's Avatar
Car: 87 formula/69 beetle
Engine: 355/2.1
Transmission: T.C.I streetfighter th350/5 speed
Axle/Gears: 3.73 lsd/
just now got this done. 3 inch straight off the headers 3 inch magnaflow x pipe and 2 dynamax race mufflers
Old 10-26-2008, 07:07 PM
  #207
It says this for that picture:
"This photo cannot be viewed because it has either been deleted or marked as private by the user."
I also spoke to a tech guy from hooker, named Darrel cook, and he was great. I told him about my problem with my headers, now I've put 4 sets of headers on my firebird, but got 5 from summit and one from hooker; the quality is better now. I still had to do a little cleaning of the primary tubes with my die grinder and carbide cutting bit, where they come together and enter the collector. Right where they cut the tubes, there is some tubing that is still moving right into the flow of the exhaust tubing, so I cleaned it up. The gaskets they give with the headers are still only 1-9/16" of an inch, when your using 1-3/'4" primaried headers, its like tying to breath through a straw instead of your hand open wide. So I sent him pics and a copy of the december 2003 issue of car craft issue, of headers coating vs. painting. After he got the pics and what I explained to him, within two weeks I had my new headers and over this last week I was installing them, and now have them finished and just about everything under the hood, I'll post more pics later tonight of the finished look.
If anyone has problems with hooker headers, ask to speak with Darrel cook, he's the only helpful guy from holley and hooker, the other guys are dicks.
Make sure that if you buy the coated ones, you run them through at least 5 heating and cooling cycles at idle, no reving high, and cool off completely after each cycle, then the coating is supposed to last. And he said to keep the luster finish, to polish them down with mothers mag and rim polish.
Old 11-20-2008, 05:04 PM
  #208
fastrs1891's Avatar
Car: 91 rs vert
Engine: 305 tbi
can anyone tell me what tpi stands for. and does tbi mean throttle body injection?
Old 11-21-2008, 08:20 AM
  #209
mw66nova's Avatar
Engine: 7.0L
TPI=Tuned Port Injection
TBI=Throttle Body Injection
Old 11-23-2008, 10:17 PM
  #210
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Re: From the top side
Originally Posted by skidude
Attachment 115383
Attachment 115384
Chrome tips. They stick out a little further than I wanted, but I'll live with it for a while.
if i was you brow i would get rid of those and get the lt1 tips just my openion.
Old 12-31-2008, 09:23 AM
  #211
95Cam86Roc's Avatar
Car: 86 Iroc
Engine: LS3
subscribed for future
Old 12-31-2008, 10:14 AM
  #212
I added some new pics of the new set of headers I got from hooker, and everythings basically finished under the hood, for now, lol. I have some views of under the car shots too, check 'em out.
www.cardomain.com/id/cronsformula
Old 01-06-2009, 04:14 PM
  #213
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
I know the pics aint the best but I need to get it back to work after I do the timing chain so I can take the pic on a rack.. but I ran the pipes off the headers out to the sides into a pair of 32' glasspaacks and put the dumps right in front of the rear tires
Old 01-08-2009, 12:29 AM
  #214
blp226's Avatar
How loud is it as compared to other mufflers like magnaflow, flowmaster, and others. Couldn't you use glass packs in the same configuration?
Old 01-08-2009, 08:46 AM
  #215
My firebird with the dynomax bullet mufflers, which are supposed to have stainless steel material inside, but basically similar to glass packs; the car idled at 98-100 db's, and when revved it went to 117-119db's. So barely legal, lol
Old 04-25-2009, 08:17 PM
  #216
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
started on my own exhaust...
Old 04-25-2009, 08:18 PM
  #217
johnnyboy's Avatar
Size:  156.4 KB i will post more pictures tomorrow after i have finished welding the pipes and have it all hung, those tabs holding it in the pictures were just temporary.
i am also going to try to fit an h-pipe into the system
Old 04-25-2009, 09:14 PM
  #218
Your exhaust looks good, hows it sound? I almost put side pipes on my bird, but I decided on dumps instead, to blow the burnout smoke out to the rear of the car.
Old 04-25-2009, 09:16 PM
  #219
johnnyboy's Avatar
well that's the disappointing part, hah i haven't gotten the car running yet. i've been working on other projects and this has been neglected. hopefully i'll have it running within the next couple of weeks.
Old 04-26-2009, 11:21 AM
  #220
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
that drivers side pipe looks low.
how much clearance do you have?
Old 04-26-2009, 12:38 PM
  #221
johnnyboy's Avatar
i haven't checked the clearance yet, the car is still up on stands. i haven't finished welding the pipes yet.
Old 04-26-2009, 05:04 PM
  #222
johnnyboy's Avatar
the ground clearance is terrible! lol i have like 3". i guess i'll just have to make this a drag strip car.
i'll post pics when they're done uploading
Old 04-26-2009, 05:24 PM
  #223
johnnyboy's Avatar
Old 04-26-2009, 05:25 PM
  #224
johnnyboy's Avatar
Old 04-26-2009, 05:27 PM
  #225
johnnyboy's Avatar
Old 06-15-2009, 08:53 AM
  #226
The White Knight's Avatar
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Transmission: 200C 3 Speed
Axle/Gears: 2.93 Open Diff
New exhaust is done!
2" Duals into 2into1 convertor, 2-3/4 inch pipe into Raven crossflow muffler, 3" Stainless rolled edge tips.
SOUNDS SO BADASS, so much nicer then white car with the Flowmaster and this setup!
Sounds clips soon! :
http://www.facebook.com/album.php?ai...1&l=7bed39b0d4
Old 06-15-2009, 04:12 PM
  #227
johnnyboy's Avatar
but that is not a true dual exhaust.
Old 07-28-2009, 08:02 PM
  #228
SystemX's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27:1
Here's a pic of my true duals after getting them welded up:
consists of:
Hedman #LT-68460 full length headers (not shown of course, they're on car)
Hedman Xtension S pipes #500-18806
Flowmaster H-pipe 2.5inch #15920
Cherry Bomb "mufflers"
and a pair of turndowns (not shown)
Got the idea from juggernaut 69's post here: https://www.thirdgen.org/forums/exha...tubes-all.html
All-in-all I'm very happy with the set-up. Header install went great. you just have to have patience and a die grinder! Passenger side went in no problem from the top. Drivers side went in from the bottom and had to trim out the engine crossmember and the rear of the A-arm where it wraps around the bushing. Headers bolted right up and required no denting or crushing of any tubes. I will take some more pics when I get the exhaust back on the car.
Old 07-30-2009, 05:49 PM
  #229
jerrod75110's Avatar
Car: 89 camaro
Engine: 383
Transmission: 350 tci 3000 stall
I just put a set of hooker Lt 2210 on my car now im trying to figure out what i wanna do about the exhuast..Im thinking about coming off the headers with hedman s bends and (maybe) a x pipe, 2 mufflers and then dumps..my question is If I go with a x-pipe will I have to chop on it or doing any custom bends?
Pls give your thoughts..
Thanks, Jerrod
Old 08-15-2009, 01:54 PM
  #230
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
i went with the old SLP dual exhaust style they go side by side all the way to the rear then split under the gas tank. its a work in progress but it sounds great and i have good ground clearance
i cut the y pipe in half before the merge and ran 2.5 inch pipes thru a xpipe then side by side under the driveshaft then up over the axle into 2 spiral moroso resonators then i welded to 3.5 inch hooker tips to them
sound clip is from my phone so its no justice
http://s248.photobucket.com/albums/g...slpexhaust.flv
everything was free except for the xpipe so hopefully when i get more time i'll clean it up.
Old 08-15-2009, 05:17 PM
  #231
SystemX's Avatar
Engine: 5.7L L98
Axle/Gears: 3.27:1
RockJay81, nice job! I've only seen a couple run that way and it looks very clean. Reminds me I need to take some pics of my duals to post. Doh!
Old 08-15-2009, 05:54 PM
  #232
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
i had dual exhaust on my 82 ta with shorty headers no cats or mufflers but they welded the pipes together so it would not rattle and for room
Old 08-15-2009, 09:32 PM
  #233
johnnyboy's Avatar
wow that looks good! at first i thought that you had used some of that stupid flex exhaust pipe, but then i realized they were just crush bent pipes.
pretty clean setup.
Old 08-15-2009, 11:50 PM
  #234
RockJay81's Avatar
thanks guys when i get a chance i will set up a new one with better bent pipes its just for now. it feels like it gained a bit more power also
Old 08-29-2009, 05:36 PM
  #235
cvz6977's Avatar
Car: 89 RS
Engine: 355
Transmission: T5 B&M Shift kit with short throw
Axle/Gears: 3.73 Posi
Re: Dual exhaust picture collection ***HELP RE-READ***
Here is a link to the exhaust I did on my car, couldn't upload the pics. http://s794.photobucket.com/albums/y...tom%20exhaust/
Old 08-29-2009, 06:42 PM
  #236
andrew69_04's Avatar
Car: 92 Camaro RS
i should get pics of mine uploaded. its super clean and fits great. i used the bassani true dual system off a 4th gen car. its 2.5 true dual out the rear of the car with an X-pipe.
Old 08-30-2009, 10:40 AM
  #237
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Thanks, Jerrod
I have the same headers you do, scroll back a few pages and see my setup.
Old 08-31-2009, 06:11 PM
  #238
stanton8's Avatar
Here are a couple pics of what we have come up with for a 2.5" true dual exhaust, let me know what your guys think.
Old 08-31-2009, 07:07 PM
  #239
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
is that flex tubing? Do I see exhaust paste??
Old 08-31-2009, 11:18 PM
  #240
That flex tubing on an exhaust, is lame, and half a**ed, sorry, but you should have done better than that with some mandrel bent tubing, then it would be pretty sweet, maybe you should go back and change that flex tubing now!
Old 09-02-2009, 03:25 PM
  #241
stanton8's Avatar
Yeah, I know the flex tube is just temporary until i complete the mandrel bent sections, I just wanted to mock up and post pics to get some feed back. Dang, pretty brutal here...cut me some slack, other then the flex tube? what do you think?
Old 09-03-2009, 09:45 AM
  #242
I think it would be best just to replace the flex tubing with mandrel bent tubing, then the exhaust would be fine, because that flex tubing hurts the flow and is kind of a restriction, and velocity being the key to good power and mileage down low, is hurt because of that flex tubing.
Its good for a mock up, you'll just have to get some 90* and maybe some u-bends, take more pics when you have it mocked up. They aren't that expensive from summit for dynomax tubes.
Old 10-14-2009, 05:48 PM
  #243
GMODUDE's Avatar
Car: 92 Camaro RS
Engine: 5.7L 385 Fastburn
Axle/Gears: 9 Bolt 3.70 Gears
I am about to get true dual exhaust on my 92 RS. I have the hedman LT headers on it now and i had problems clearing 3inch tubes under my car. I noticed some of you guys dont have the torque arm that goes from the rear end to the transmission.....do i really need it? if so why dont other models have it? The reason y i ask is because i wanted to try to run my duals tucked into the driveshaft valley.
Old 10-15-2009, 10:42 AM
  #244
whatever you want
Old 10-16-2009, 06:46 PM
  #245
GMODUDE's Avatar
Car: 92 Camaro RS
I have found a great setup and it is only possible without the link from the rear end to the tranny. thats wht im askin....is there a way to delete it? I dont wanna run 3inch. I wanna run 2.5" duals but the best way ive seen is by sticking the pipes up in the driveshaft valley. but i cant with that link n the way. I mean I can run 2.5s other ways but that way seems like it has the most clearance. And one person here that had pics of his iroc didnt have the torque arm.
Another thing u should kno is im doing this exhaust because i out a 385 fast burn crate motor in my car with a hot cam. dynoed at 425hp. and i have a built 9bolt rear out of a 89 iroc.
Old 10-25-2009, 07:23 PM
  #246
1badnhra's Avatar
Car: 86 Firebird
Engine: 355 vortec heads
Transmission: 700r4 Huges 2500 stall
Axle/Gears: 4:10
I just tried the link to the pics but it doesn't work. Has it been removed or closed down?
Old 11-14-2009, 09:03 AM
  #247
Engine: 3.0L 2JZGE
hAS ANYONE TRY THE DYNO MAX BULLET MUFFLERS?
TONY.
Old 11-17-2009, 08:17 AM
  #248
89RsPower!'s Avatar
read drum or disc? If it's drums they're out of adjustment..
Old 12-06-2009, 06:16 PM
  #249
305forever's Avatar
Car: 98 blazer 4x4 lifted 3inches
Engine: 4.3
Transmission: auto
Axle/Gears: idk, but not a posi
my dual exhaust kit consists of my hedman full length header and 18 inches of straight pipe with turndowns
Old 12-20-2009, 10:10 AM
  #250
84 fbird45's Avatar
Car: 84 firebird
Transmission: th 350
I have a 84 Firebird and was thinking of sidepipes.Already have hooker shorty headers.Does anyone have any pros or cons.
Quick Reply: Third Gen Dual Exhaust Picture Collection
