More than you ever wanted to know about BACKPRESSURE...
#51
Car: Trans Am
Engine: 5.0L 305
Thanks for the support ownor. I haven't had the time to look further into the idea of a quick and dirty way to setup your exhaust right before buying anything but hopefully somebody else does, hehe. My friend is a physics major so maybe I can talk him into helping me with the idea, I'm sure he'll have some valuable input. Of course, a precise formula for the proper length would be difficult to come up with due to my limited knowledge on the subject but maybe a little research can change that. If I do come up with something then I'll definitely share it.
In response to brodyscamaro, you're right, lol. I know I'm a little crazy but I simply can't afford trial and error when mistakes cost hundreds of dollars so naturally I'm looking for a more reliable way to select parts. A precise formula to tell me exactly what I need is probably not possible to find or at least it's beyond my ability but if I can find something to at least get me close it would help.
#52
Car: 90 RS 450hp 355
Engine: Edelbrock Pro Flo EFI w/ E-tec 170
Transmission: 700-r4
Axle/Gears: stock 3.23!
Just a small but important mistake ;-)
Here are a few questions so you can learn this a bit better. If you answer all of these correctly, you will
totally understand the difference between:
- Tuned length vs. Backpressure
- Restriction vs. Flow
- Velocity vs. Pressure
Quiz A
Using the diagram below, answer the 4 questions.
The RED line is POSITIVE PRESSURE (Initial Wave) and the
BLUE line is NEGATIVE PRESSURE (Reflected wave). Also note that this is very simple, it will be explained below.
The exhaust port is at the left side of the pipe.
#3. What is the resulting pressure of both waves combined at the exhaust port for Graph A?
1. 3 psi
2. 0 psi
3. 5 psi
4. 3 psi
With some simple math above we can see that the
blue line is creating 2 PSI of negative pressure.
- 2 PSI (Graph A)
The Red line in Graph A is producing +3 PSI of exhaust pressure on the inital pulse. That means there is a difference of 5 PSI between both waves. The reflected pulse is leaving a negative zone at the port and literally sucking the exhaust out.
Since the initial wave is +3 PSI, it's going to
come out with higher velocity because of the 5 PSI
differential.
Graph B shows a similar scenario, but the reflected
wave comes back and hits the port at 0 PSI.
The intial exhaust pulse is 3 PSI.
Now there is a difference of 3 PSI.
Quiz A
1. 3 psi
2. 0 psi
3. 5 psi
4. 3 psi
- 2 PSI (Graph A)
differential.
The answer to question #3 is correct, but the comments are not. The blue curve in Graph A is actually at a positive (+) 2 psi, not -2.
Everyone should carefully note the difference between pressure difference & net effect with respect to wave physics:
The pressure difference between +3 psi and -2 psi is [3 - (-2)] = 3 + 2 = 5 psi , while the net effect (a.k.a. superposition principle) is [3 + (-2)] = 3 - 2 = +1 psi at the port.
However, according to graph A the way it is now, the pressure difference is (+3) - (+2) = +1 psi while the net effect is (+3) + (+2) = +5 psi at the port,therefore drawing the fresh intake charge with less velocity.
For everyone:
Remember that fluids (air/fuel mixture in this case) flow by the virtue of a pressure difference (i.e. vacuum in cylinder during intake stroke vs. atmospheric pressure at the air filter), and understand that the lower the pressure in the cylinder with respect to the atmosphere during the intake stroke, the greater the pressure difference and thus higher the velocity of the intake charge.
I hope I made sense...
Alex
#53
Car: 1989 GTA
Engine: LQ9
Good info but made me feel like i had ADD
Good info but it made me feel like i had ADD
#54
Car: 2 '79 Malibu 4drs
Engine: '83 LE9 305/'79 L39 267
Transmission: ATI TH350/ stock TH350
Axle/Gears: 3.08 peg/2.41 peg
Re: More than you ever wanted to know about BACKPRESSURE...
alot of good info
i like to use the term "velocity tune" & i absolutly hate the term "some cars need backpressure" NO! they don't, they need the right velocity
i have one theory that the use of mufflers can help tune a system for the right amount of flow for the engine.
For example, my one Malibu;
I have Hooker Competition 1 5/8"X3" headers, 12" long 3" diameter header extentions, Flowmaster reducer cones, Pypes 2.5" dual exhaust with an X-pipe (which i feel needs to be a little closer to the headers, but w/e)
when i initially installed my exhaust, i ran SuperTurbo mufflers, & i had an '80 267 in the car (with cheap headers) because i was "between engines" & it was the only thing i had that ran
the exhaust was very quiet (like a stock truck) & out performed my old 2.5" crush bent exhaust with straight pipe & a h-pipe, the car felt almost not horribly slow
i feel that i substantually (spelling?) increased & smoothed out the exhaust flow, & the mufflers tuned the capacity to almost be right for the little 267
finally, i installed a '83 LE9 305, other then new headers & the exhaust, it was box stock out of the wreck truck it came out of, including the stock Quadrajet
the car felt great, but i had these 40series Flowmasters from a friend that i wanted to try, so i swapped them in, & instantly the car picked up power & response across the board, with the majority being mid-top end
i ran the car like this, & ran a best of the 15.3X@83mph (in the middle of July, around 85*)
so, okay, other then for the noise, i liked them, but i felt, how would the car respond to a striaght-thru muffler?
with no mufflers to borrow, i decided, to take scraps of straight pipe, & put them in place of the Flowmasters
the car seemed to run "flat" it just wasn't peppy, & felt like it lost power everywhere, however i did love the noise it made
so i swapped back in the SuperTurbos to be quiet again & got back the low-mid response it used to have, & also installed a used Performer cam, my old Torquer 2 intake with a Carter 625AFB, tuned for my old 350, along with big wide tires, which allowed me to leave with my foot on the floor (yes i can floor it & stay there @around 2600rpm)
the car ran a 14.84@89mph towards the end of the year in cool November weather (50-60* weather)
so anyways, surprised how far into the 14s the car went (actully baffled), i said to myself, the car really liked the Flows, so i put them back on, along with some tuning i did on the ol' Carter (leaned it out a little), & the car felt a "little" better
went to the track in nice cool April weather (around 60*) the car instantly ran 14.5s@93mph (HOLY S#!T), i kicked the timing up a hair, 14.6s, knocked it back, 14.5s, then i changed up my launch, only launching around 1100rpm & nailing it off the light, the car ran several 14.3s@94-95mph, by now i'm like flipping out, calling everyone i know, etc etc (BTW i got 20 runs in that day & left early)
so i think & my theory; is the straight pipes (2.5") have a velocity peak thats way too high for my current set up to get to & use, while the SuperTurbos tuned the velocity to a more streetable rpm & is optimal for a DD since the torque & response is great at low rpms, & the Flowmasters found the happy middle, & work great everywhere, especially at mid-high rpms where my car pretty much uses, my converter flashes to 3400rpm upon launch, so anything below is just more tirespin anyways
so that being said, the exhaust needs to be tuned to the right velocity for the given combo, & when right, can reap huge benifits
plus it seems like i have a good hunch about what a car needs for an exhaust...i've been obsessed with exhausts for most of my life, & it seems like most of the stuff i do to other cars just work very well
#55
Car: Trans Am
Engine: 5.0L 305
This thread has been quiet for some time and it's an odd coincidence that I came back to visit yesterday and then you posted today with some info that just may be helpful to my current situation. I've been planning to buy an exhaust for my mostly stock 84 trans am but have been changing my mind a lot due to lack of money and my theories about which setup would work best. I originally wanted to go with dual 2.25" pipes from the headers back but I scrapped that idea because I'm new to this stuff and it would require some skill to do it right on this car. Besides, I'm still running the stock 305 (LG4 I believe, it's not the HO) so I doubt it really needs that. My next thought was a single 3" setup but it's been hard to find a good y-pipe for the shorty headers I got. The one from hedman that is designed for my headers is 2.5" in/out which seemed like it would pretty much negate the effect of a bigger intermediate pipe. This led me to my current idea which is to just go 2.5" the whole way back. Since I don't even have enough for the full exhaust right now, engine mods are pretty much out of the question for a while so I won't be putting out much more than stock. At first I thought I'd be screwing myself with 2.5" pipes because if I suddenly had the money to start playing with the engine, the exhaust might become a bottleneck again. However, until then, it seems that 2.5" would be adequate for my setup and going bigger may actually be detrimental. With the stock exhaust, low-end power is decent but after that it's kind of sluggish. I'm thinking that the new setup will allow it to breathe better at higher rpm but won't sacrifice too much on the low-end.
To be more specific about parts:
Hedman Street Hedders - http://store.summitracing.com/partdetail.asp?autofilter=1∂=HED%2D68470&N=700+400143+115&autoview=sku (not certain if these are the exact ones but specs are pretty much identical)
Hedman Y-pipe - http://store.summitracing.com/partde...part=HED-17470
Dynomax Intermediate Pipe - http://store.summitracing.com/partdetail.asp?autofilter=1∂=WLK%2D47638&N=700+4294908153+4294907958+4294925024+4294923429+4294820497+4294748490+115&autoview=sku
Flowmaster 80 series - http://store.summitracing.com/partde...part=FLO-42583
Not the greatest of parts but they're somewhat cheap and should be adequate for my car. My friend was trying to talk me into getting a 4" exhaust like the one he's getting for his 84 camaro but his engine has some work done to it and it needs the extra flow capacity, mine might actually be hurt by it. I may punch out the core of my catalytic converter/remove it entirely since I have to buy my inspection anyway, leaving the muffler as the only real source of backpressure. After considering the stuff discussed in the main post though, I may try to get a better converter so I have a chance to pass emissions tests and also because that should help me out in the higher rpm ranges since the pressure wave gets reflected sooner. If I'm not mistaken, the higher quality converters won't hurt the flow that bad and if that will actually help me tune the exhaust then it may end up being beneficial to have it in there. Gotta love the irony there. What do you guys think?
#56
i feel...a single 3" should be fine, even on a mild/stock 305 motor...a tad big now, but not crazy, especially if you do plan to do some mods, it will later support them
i'd run the flowmaster now...& once you start really using the full capacity of the pipe...upgrade to a Spintech, or full-flow muffler like a MagnaFlow or Dynomax UltraFlo, single in, single out...pretty much all crossflo mufflers flow pretty badly besides the SpinTech, better off going single tip...less noise, & more subtle....depending how you end it
#57
Car: Trans Am
Engine: 5.0L 305
Thanks for the reply. My friend has an 87 camaro that he's parting out and it happens to have a 3" flowmaster system on it so it looks like I'll be using that. I'm not sure what y-pipe he has or if he's using an 80-series muffler but I know his exhaust sounded pretty nice when the car was still running. I'll probably throw that on and get myself a nice 3" cat so I have a shot at getting through inspection legally. If that doesn't work out, I may take a shot at running dual 2.25" pipes. If it comes out alright then it's time to start saving for a new trans as mine seems like it's on its way out. It's ok for now but I give it another year at best before it starts approaching death.
#58
Car: 2000 SS, M6
Engine: Modified LS1
Thanks for the reference and credit Urban! Someone had just linked meto this thread from Fbody.com and I was surprised to see this post. It's been a while since I wrote that, and it's quite basic compared to the dyno tuning, track tuning and reference texts that I learned from. I highly recommend buying, "Scientific Design of Exhaust and Intake Systems", as well as "Engine Technology, 2nd Edition" to get a bigger picture of whatis happening.
As I skimmed through the replies, I noticed a couple of mix ups:
- A muffler slightly changes the tuned length of the secondary system depending on the change in volume between the inlet pipe and mufflerchamber. The baffle placement also effects the timing of the reflected pulse.
- The blue line in graph A is actually representing an expansion wave. The net result is negative pressure. Although the graph shows an absolute value of 2 PSI, when the waves are mixed, the pressure difference is effectively 5 PSI which will cause a higher velocity into
the chamber.
One other comment about megaphone, or convergence pipes (also works withsteps/stepped headers), is that as the pipe volume expands, the gas velocity slows down.This will effect the timing of the reflected pulse at different RPM's.
the chamber.
#59
Car: '89 trans am gta
Engine: 5.7 L 350 TPI
Axle/Gears: not a clue!
i got linked this thread from a local 3rd gen forum and wasn't going to post because i thought it was an old thread, but since it's alive again....
i pm'ed the author about my set up, but i figured i'd get others ideas.
i've got an 89 trans am gta with a 5.7 350 TPI. it's mostly stock. i put on a hypertech chip, got rid of the smog stuff (broken or not working), and put on some hooker headers. the car is mostly for cruising, but i don't want a wussy car! the exhaust is stock 2.5" pipe with a 3" high-flow cat. i'm not sure why the cat is a different size...that just what Midas put on when they did it. (i didn't know it at the time.)
i plan on doing the cat-back later, but the headers-to-cat is a must do now.
i'm not really sure what set up to go with. i know i want to keep it a single pipe for cost reasons and i know that i like the look of the dual tips out of the muffler.
any recommendations?
#60
i'm leaning towards a 3" cat-back.
what about the headers-to-cat? should i make it all 3"?
#61
1 Post
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Glad to see you're still around! That was so much great info I had to put it somewhere that people could learn from it. This board has alot more traffic than Fbody and typically has alot of younger owners so I figured it would be a great place.
I actually own "Scientific Design of Exhaust and Intake Systems" and yes it's incredibly interesting and very informative, if a little dated (my copy is early 70s IIRC), however scientifically sound.
the chamber.
the chamber.
#62
Lot's of excellent theory, but what of real world applications in a lowered 3rd gen? There's not a lot of room for appropriatly positioned mufflers so as to provide proper tuned length or terminator boxes ( David Vizard ).
I can see cut outs being a useful solution. There are only a couple of examples I've seen though.
Is there specific info available as to what the secondary length should be with respect to a given engine rpm?
I'm looking to pull the torque curve down to better suit my stall speed. As the primaries are fixed and the collector diameter determined, the only tuning left is in the secondary length and the cut out placement.
#63
i read this article and some other articles and have come up with a few plans for my 383 build.
i'm in a similar boat of not knowing how long i should have my tuned length for a 383 peaking at around 6400 i think. My custom cam should allow it to peak by then. I plan to run true dual 3inch setup with round tube like mufflers so i will need some sort of "tuning effect" present to allowfor best performance at 6000+rpms. i want to run some kind of terminator box like David Vizard discussed, i'm just not sure yet what to do as i dont know if i'll have room
#64
Car: 2000 SS, M6
of 20" to 26" past the primary merge point. Depending on the collector
you have, the length will vary somewhat.
If you PM, or post your cam specs, I can run some numbers in a software
program to give you a better idea of the length you'll need.
Orr89,
What sort of plenum and runner design are you using to peak at 6400 RPM?
That's pretty impressive. The cam must be ~300 seat duration, with about
110-112 lobe centers?
#65
Car: 2000 SS, M6
Urban,
I'm always around, but I'm spending a great deal of time as admin on Speedtalk, and busy with the biz! I'm jumping on here and Fbody from
time to time though.
Scientific Design is a great book for getting the science behind the design,
however the current trends are a bit different know that cylinder head
efficiency and port designs have evolved. Still a great starting point nonetheless!
#66
[QUOTE=lukn4trbl;3637528]Secondary tuned lengths for RPM ranges of 4000-6000 RPM, fall in the area
Hi lukn4trbl,
Here are some specs for you to work with regarding secondary length:
350 cid/standardbore/stroke/rod length
Vortec heads. 3 angle valve job, no porting, 64cc measured.
9.97:1 static CR measured. ( .028 gaskets, .025 below deck, -6cc piston )
Comp 268H flat tappet cam ( old single pattern version)
IVO (BTDC) 4.0
IVC (ABDC) 34.0
EVO (BBDC) 44.0
EVC (ATDC) -6.0 (or 6 BTDC)
110 LSA
102 ICL
218 @ 050"
4 degrees advanced
.488" lift w/ Comp Pro Magnum 1.6 rockers
600 vac sec Holley
34 degrees total advance w/ 12 initial
94 Octane
Currently using Hedman shorty headers with 2.25 y-pipe and 3" cat and 3" flowmaster cat back system
TCI 1000 over stock stall converter (flash @ 2750+/-)
3700 lbs. race weight
3.73 posi w/ 26" drag radials
Best pass. 13.4 @ 102.5. 1.8 60'.
20 mpg hiway.
I use Dyno 2000 and Drag 2000 for analysis.
I'm interested in your insight.
Kevin
Hi lukn4trbl,
IVO (BTDC) 4.0
IVC (ABDC) 34.0
EVO (BBDC) 44.0
110 LSA
102 ICL
218 @ 050"
4 degrees advanced
600 vac sec Holley
94 Octane
20 mpg hiway.
Kevin
#67
#68
1 Post
Car: '72 Chevy Nova
Transmission: TH350
Here's an informative thread I found on speedtalk:
http://speedtalk.com/forum/viewtopic...er=asc&start=0
#69
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
HELLO
I AM FROM MALTA AND HERE I CANNOT FIND PARTS FOR MY 89 CAMARO RS WITH 350CI AND I SAW THAT YOU KNOW A LOT ABOUT EXHAUST
I LIKE IF YOU CAN HELP ME DOING HOMEWORK TO INSTALL A NEW DUAL EXHAUST TO MY CAR MAY BE YOU CAN SEND SOME PICS OR DIAGRAMS AND WHAT TIME OF MUFFLERS SHOUL I USE AND PIPE THICKNESS?? YOU CAN ALSO EMAIL ME VOX@ONVOL.NET AS I AM NOT PERFECT USING FORUMS!!
THANKS
LORRY
THANKS
LORRY
#70
Anybody here familiar with the Pipe Max program?
#71
Location: Southern Ohio, tween Cincinnati and Portsmouth
Car: 89' RS
Engine: SB 350 .40 over
Transmission: Stock 5spd manual
Axle/Gears: Stock one-wheel-wonder... :*(
I dont know if anyone bothered to read the link posted for http://www.pontiacstreetperformance..../exhaust3.html but its got some good stuff on the X and H type of crossovers, and some basic guidelines that they came up w/ from tests back in the late 90's...
Know is kinda dated, but it couldnt have changed that much??
1. Always use a crossover of one kind or another. Our tests indicate that the X type gives additional improvements over the H type.
2. Mount the mufflers as far to the rear of the chassis as possible. An important characteristic of the exhaust system (behind the headers) is its ability to dissipate heat energy. Heat loss brings with it, gas volume reduction, enabling smaller mufflers and pipes to be used without penalty.
3. Always us the largest case muffler that you can fit under the chassis possible. The larger internal volume allows additional acoustical energy to be absorbed ,dissipated and eliminated.
4. Unless an engine is in the 500+ horsepower level or run at very high RPM, the maximum tailpipe size required for minimal power loss is probably 2.5" diameter. When the exhaust pipes and mufflers drop the temperature significantly, the volume of the exhaust gas is reduced and tailpipe sizes is not as critical.
5. When you must adapt various pipe sizes, always use long tapered cone reducers, such as, those available from Flowmaster. You can also use a crossover that has reduced pipe sizes built into it.
#72
Car: 83 z28
Engine: 305 v8 5.0L
Transmission: T5 5SPD
Ok heres a question?
I just installed Holley's Flowtech "equal" length headers i belive, they are just a tad bit longer then the stock manifolds, but I don't think theyre considered shorties... ANYWAYS...
I installed them, which required taking a bunch of smog stuff out...
O2 censor is still on, and hooked up (weather its working properly or not i have no idea)
I started the motor with straight headers, no pipes at all.
I noticed MAJOR loss in power, and lots of hesitation that did not happen before the headers, so whats going on? I heard straight headers will make lots more power, and it feels lost through the hole power band 1-5500rpm, I dont know whats going on! Any ideas?
#73
That's where the ' lots more power ' comes from.
#75
Car: 83 z28
Engine: 305 v8 5.0L
Ok so in the event, i put the Y pipe back on, and keep the cat off, and run piping all the way back to the rear into the muffler, i should get atleast my stock power back?
Also, i've heard rumours, and wouldnt doubt if its true, but I heard running straight headers, CAN or WILL cause your heards to warp when you shut the engine off and allow all that cold air to return into the headers, is this true? May i already have damaged my engine?
And since I already have the attention of the users, what smog wise can I take off this engine, without causing it to run like "kaka"? Smog pump is disconnected, and completely out of the car, cat is obviously cut out, the little valve thing (no idea what it is, so fill me in) thats connected at the exaust flanges on the manifolds and the pipes, is out. Anything else I can do to make more performance without making the motor run bad if i got rid of smog stuffs! hit me up
#76
Car: 1982 Camaro Z-28
Engine: 350 4bbl
Transmission: Borg Warner Super T-10
Axle/Gears: Richmond 10 bolt 4:10 Posi
Wow my head hurts and that was a lot to take in, I think I stupider now in some other area to be discovered at a later date because of all this info lol
Excellent write up
Excellent write up
#77
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
So, you can replace the stock system from your headers back and likely your power will come back (unless you've snafu'd something else by accident), but if you put a giant 4" diameter short system, you will only get a tiny bit back. I hope this is useful.
TA
#78
Car: 1991 Camaro RS
Engine: 5.0 305cid tbi
ok, so i have a question. i have a 91 RS it has a LO3 tbi and i put headers, 2.5" y-pipe, no cat (3" test pipe), and a 3" flowmaster with a 80 series w/ 3" in/out. ok so at idle its not too loud at all, but when i get on it, it just "opens up" and sounds much louder. but like you know at idle you get that deep throaty sound, well my car doesnt have it like that, i mean you hear the throaty sound but its not really noticeable unless standing behind car leaning on bumper. what caues that deep throaty sound? and (dont get me wrong it sounds good) but can that be adjusted? as in, i know a cam will change the exhaust sound a lot, but is there something that can be done with the actuall piping, or the different components that are in line?
I \know that LO3 stands for "low output" and i also know chevy put a not so high perfromance cam, and ,lower comprsion so it only makes about 170 hp stock. like i said cam will change the sound, so with that smaller cam maybe thats why the exahust sounds different? it doesnt have a crazy mean sound, thats what i kinda wanted.
thanks,
-Anthony
thanks,
-Anthony
#80
Hello UrbanHunter, I just came across this article about
exhaust backpressure and I thought I'd ask for your educated opinion on a situation that I think may have to do with this stuff.
I'm wondering if the dent in my exhaust pipe could be contributing to
the very high knock counts I'm experiencing. I'm figuring this dent is messing up the exhaust gas vibration and could be contributing to this. RBob mentioned I should make sure my driveline is tight, which I'm going to do.
The knocks are happening when I accelerate hard. With the tranny in neutral there are hardly any knocks.
In talking to RBob about this he reckons it could be due to the driveline being loose. I bet that is the case but I'm interested in what you think. I'm putting new exhaust on once I've saved up enough $$.
#81
Car: 88 Camaro Silver and Black
Engine: 350 4bbl.
Transmission: World Class T-5
Axle/Gears: 3.42 with eaton posi unit
good info to know! alot of times its overlooked
#82
Car: 88 IROC-Z
Engine: 383
Axle/Gears: 4th gen 3.42posi
Re: Some more on exhaust...
FOR A V8--
- It is not possible to adjust the firing order to prevent this in a V8. No other engine type has this issue.
- A crossover on a V8 helps to equalize these extra-wide pulses and low pressure areas, and helps the tuning for both banks.
- Well-designed unequal-length headers can reduce this effect, and make it disappear altogether in a narrow RPM band, without a crossover.
- Equal-length headers ALWAYS benefit from a crossover.
- The shorter the crossover is, the more effective it is.
- An "X" crossover gives the ultimate in balance, but causes all 8 cylinders to exit through both tailpipes.
- Some exhaust makers (like Flowmaster) make an "H" crossover that is of zero length. The two pipes run parallel to each other, with no more than a welded hole between them at one point. This is done to get the maximum balance, while minimizing the actual crossover of exhaust flow between pipes.
- I can't way whether a "zero-length" "H" is better than an "X." Flowmaster must think it matters. Or maybe it just gives them the sound they want. All I can say for sure is that the shorter the crossover is, the better.
#83
Car: 84 Camaro
Engine: 350 Goodwrench with Edelbrock pkg
Transmission: rebuilt 700R4
sorry to bother with this, but from what i am reading, if i keep my headers at 2.25 and the Y pipe all the way to the cat 2.25 and expand from the cat-back to 3 in. ill see an increase of power with no huge loss of low end torque?
#84
Incredible amount of exhaust information. Thank you for sharing. When my headaches goes away I will try to figure this out...
Could you give advice please. I have a 1990 5.7L Suburban TBI egine stock and stock single exhaust. It needs a muffler and I want something like a flowmaster 40, just for the sound. But after reading this I may do more. Purpose of this vehicle is daily driver and occasinal tow rig for 4000 lb load. High rpm power is not a concern but low end power and MPG are.
So if I keep my factory Y pipe what should I do after it? I may remove the cat altogether or get a high flow and a muffler because it needs it. Any mufflers better than a flowmaster 40?
After Y pipe I have a straight shot through CAT and muffler. I could get rid of tailpipe and run out in front of rear wheels. I will probably build from Y pipe back based on your recomendations. Thanks again.
#85
#86
Yeah I like the TBI engine the way it is, if I were going to build an engine it would be differant to start.
But back to my exhaust question, I have to replace the muffler because of a hole. While I'm doing it I may as well take advise from all the information in this thread... just can't get my head wrapped around what would be best. I am keeping the Y pipe because it's perfect, I have to replace the muffler because of a hole, I don't need a cat for inspection but am not oppsed to keeping it to do my part of keeping air clean. But while I am at replacing muffler I could very easily without an expense run the exhaust out in front of rear wheels if it would help low end! Don't want to if it would hurt low end. This vehicle has no purpose above 3000 RPM.
#87
yeah i have a good amount of torque and power low end, and not so great top end, but my misfire may have something to do with that. i understnad your question but all i can really do is ask if you checked out sites like gmt400, or fullsizechevy.com. thats more or less your best bet. you could probably find some samples of exhaust clips and so on. flowmaster 40 i know is a classic for the obs's.
#88
I'm not so worried about the sound, I can just replace the muffler. What I'm asking for is expert advice on, while I change the muffler, should I shorten it up and come out in front of rear wheels, or bigger pipe from the Y pipe, or certain muffler, or will a loader muffler like a flowmaster 40 hurt what I already have?
There's just so much information at the beginning of this thread I'm confused! But one day I will get a better understanding of all that info to put it to good use...
#90
Car: 1988 IROC convertible
Engine: 5.7 TPI
Axle/Gears: 3:73:1
I have an '88 iroc.Has a stock 5.7 tpi.Going to add a bigger cam later on .Wanting to get around 300 hp.Was wandering what would be a good exhaust setup for it.Want to put shorty headers on and leave cat off.
#91
1 Post
Car: 1984 Trans Am Recaro Edition
Engine: Chevy 383 Stroker
Transmission: Probuilt 700 R4
Axle/Gears: 3.73 with a Detroit Locker
Wow a lot of work there! You should just take us all the way to tuning single pipe per cylinder fuelers. Thanks man, good info.
#92
1 Post
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
Great read for anybody that wants to alter their exhaust. With all this info people can do it correctly and not worry about the what ifs and the does it really help questions.
Very informative and should be made a law that ALL exhaust shops post this for customers to read.
#93
Car: 89 CHEVY IROC-Z28
Engine: 355 Built/High Performance
Transmission: 700R4 Swap For T56
Axle/Gears: 3.73 Posi
I got edelbrock headers with a Y pipe to a high flow cat out to 3inch pipe to borla muffler. If i remove the borla muffler put str8 duals after cat will it make a difference or should iput flomasters on? I just want it to sound loud n push outthe power at,the same time any suggestions plz & thank you.
#94
1 Post
Car: 88 gta
ok I know a little bit about exhaust tuning and I know about the programs. But I lack the information to use. All I can find about my cam is the basic details found in this sight.
So I was curious if someone can help with these stats. I need to know the length of the secondary pipe for 2.25, 2.5 and 2.75" pipe for a 4k peak.
There have been lil performance mods performed, cold air and airfoil booster. And as far as cam specs its the big lb9 cam (10066049)
dur@.050-int 207 ex 213 / lift-int.415 ex .430 lsa-117. I can't find centerlines or any other information for this cam, so I can't use the programs for exhaust tuning.
#95
1 Post
Mystyk_Wynds, not to worry about your cam specs. The most important point in all cam timing is the Intake opening. As the cam grows in duration usually Cam Grinders keep moving the intake to open earlier and earlier. If you want to know exactly what the grind is you simply put the cam in a block with #1 piston installed (no rings needed) and degree it. There is so much available info to research on how to degree a cam it shoulldnt be covered here but try this book, Engine Builder's Handbook by Tom Monroe. It is a basic book and it will teach you the fundamentals. Find the Machine Shop you may work with and ask them if they can help with a Blown up block that has a crank with # 1 cylinder still moving freely. Take it home and take it completely apart clean it up put in the crank, #1 piston, rod, Your cam and #1 exhaust and #1 intake lifters. Then find your favorite place to get the knowledge on cam degreeing. Degree the cam by indicating off the tops of the lifters. Muliply cam lift by the ratio of rocker arms to get lift numbers. You will find all you need to know about the cam and you will definitely find that once you can do it AND repeatedly get the same numbers you are there. Back to your exhaust.... unless you are really a serious racer where every bit of HP counts, forget about tuning the exhaust. It will never be noticed on a street car. You are stuck with what you have. The headers do one very important thing for street cars with cams. It isolates the cylinder pulse. Shorty’s work well with a opened up H-pipe into 3" all the way back up to about 400HP. I have Hookers with their Y pipe customized. Most Y pipes actually can cost you a lot of power if you just put it in. You have to open up the Y connection. Your cam is not very "big". The Y- pipe connection is awfull as shipped but, easily changed to something bigger. Not to "dis" your cam but that is really mild. Pretty close to a stock grind. It will run very well and polite. At about 220 deg duration on the intake @ .050 lift you will start to hear it as exhaust gasses try to rush back into the chamber at overlap. You will definitely need a modified exhaust at that point and up. Tuning the pipes for a particular rpm isn't worth it on a street car. The cylinder isolation however is a must. It has always worked like this... the more air in and the more air out equals HP. Good luck and have fun with it!
Bob
Bob
#96
1 Post
Car: 88 gta
What makes things like you say difficult, is that the engine is still in the car and its a daily driver. So removing the cam at this point is not an option.
The reason I wanted to tune the exhaust is well its 4 diffferent sized pipes right now, and its the worst cobble job I've ever seen. So I scored a set headman headers for it, and I have to redo the exhaust to begin with. So I wanted it done My Way, not the factory way.
Now I understand the purpose of headers, but you say its not worth tuning the exhaust, and yet everything I've read says otherwise. I'm not saying your wrong. Just asking for truths otherwise so I make my own conclusion. Now its a 305, so to me, every once of power and torque, matters.
The cam albeit is small, its still the biggest one offered stock for these engines. I mean if you use 1.6 rockers, your pushing close to what the lt1s are running, and your out of the stock springs limits. So with the right stuff, i can make the cam appear bigger than what it really is.
Also taking into account that a cam for this engine is $350 I'm not about to drop that much, when I can put in springs and roller rockers for less.
#97
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
I have a 3.1. V6 without all the smog BS. I plan on getting headers and deleting the cat. So ypipe back what size pipe should I use? . I have a Ported intake&throttle body and 1.6 roller rockers.
#98
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
WOW. I can't believe I just understood most of what you said. Crackin' job mate.
#99
1 Post
Car: 88 gta
So What I need to know is..When i comes to the secondary length:
Does the length of the resonator/PWTB (Pessure Wave Termination Box)add to the to the total tuned length?
And should a H or X pipe be used in conjunction with a PWTB? An should it still be placed as close to the header as possible?
It would seem to me that putting an X pipe or H pipe would change the volume and act like a PWTB.
#100
As for the balance pipe (X or H), it should be placed as close as possible to the collectors and evidently, it does not change the effective length of the secondary.
