Those with Hooker 2055's, come on in!
#201
Re: Those with Hooker 2055's, come on in!
Its a machined surface fit, and no gaskets are neccesary.
#202
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Alright, good, thanks for clearing that one up.
#203
Car: 87 T/A GTA
Engine: 5.7L TPI
Axle/Gears: 3.27:1
hey i have one quick question about the stage 8 locking bolts. i can only find them in quantities of 12. do i just have to double my order for an extra 4 bolts? hardly seems worth the almost $50 extra.
#205
Car: 91 Z28
Transmission: 5 speed
Axle/Gears: 3.23 posi
just to double check, they offer different length cats. im diong 2055's with american thunder catback. how long of a cat should i get to bridge the gap?
#206
1 Post
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
what i ended up doing: there was a 1.5 inch gap from the ypipe out to cat in. i got a 3 inch wide exhaust clamp and some of that red exhaust tape. clamped the red tape in and tightend it down. no problems yet lol
#207
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
i just bought a direct fit magnaflow cat and there was no gap. 3" in 3" out with the flange to bolt up the catback.
#208
Car: 91 Z28
Thanks guys. theimpaler68, do you have a part number by chance? thanks for the feedback
#209
hey squatingeagle, hey is the link to the exact converter i bought at summit
http://www.summitracing.com/parts/MPE-93441/
i actually just finished locktiteing my header bolts the stage 8 bolts i had didn't lock into place and i got tired of tighting them so locktite red. hope they hold now.
#210
Car: 91 Z28
perfect! thanks for the help just ordered the cat back hopefully headers and cat soon to
#211
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
#212
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Anybody want? Brand new, never used. $70 shipped to your door. Magnaflow #94109 High Flow Catatlytic Converter.
http://www.summitracing.com/parts/MPE-94109/
I can get actual photos if needed, but its no different since its never been used. Thanks for looking.
Edit: SOLD!!!
Edit: SOLD!!!
#213
i tightened them all the way down put in the lockers then the snap rings just like you are supposed to but i would keep hearing a jingle. the rings went in fine just didnt preform the way i wanted. didnt like that so i put lock tight in after what a year now. if i can find better ones later i might do it. or if i put this motor in the 86 i will fix it. but for now locktite! luck of the draw i guess
#214
Nice thread
One question, wich catalytic converter shall I buy if I want to install the
Hooker 2055 Ceramic Coated headers, Borla 14888 cat-back. (3inch)
I want to keep the A.I.R so the catalytic converter need AIR inletpipe.
So wich one to choose so I can pass inspection and exhaust emissions etc!?
I will buy the headers and exhaust from summit, so the catalytic converter would be nice to be bought from there to, to save shipping etc.
Thanks in regard.
EDIT: Also as good fitment as possible dont wanna cut and bend stuff "to much" I want a good fitment with as little force as possible
EDIT2: btw, I have brand new MSD 8.5 Super Conductor wires (not every wire is 90deg connections.) will this work with those headers or do I need to buy new cables ? would love not to change them again (replaced them last year at autumn) and the last question, can I use AC Delco RJ45TS plugs or do I need new ones ? Please help me out guys and girls, need to know this before I can order the stuff.
Thanks in regard.
#215
all 90* plug wires is better. i just put the 4 180* to the distributor til i can afford wires. converter depends on where you are located and the laws. the direct fit magnaflow 3" in and 3" out listed earlier is what i used also on summit. it says no a.i.r. but it has it just capped over. no bending or moving anything or cutting required. someone else chime in for the plugs i have shorty header plugs.
#216
Car: 91 Z28
just installed my 2055hkr's this last week. pulled the engine to do it so i had plenty of clearance piece of cake. got it all back in and noticed a huge problem... the y pipe that came with them didnt fit! it had about 1/2" too much pipe between the to down pipes so when you bolt one in place the other wasnt even close to lining up. really aggravating. i dont mind the fabrication but i had to grind off the ceramic coating so i could weld! now the cat back is all tweaked because i had to take some pipe out so the angles are off! its not like these headers we built for multiple cars. they were built for an 86-90 camaro... and they didnt fit... a camaro. not very happy with the y pipe but dont mind the project. the headers were super easy to install. dropped the engine with them on had no clearance issues with the brake booster or ac box.
as for spark plug wires. i bought a set for a 79 z28. they are all 90* boots. i bought the cheapo duralast ones and the boots have to much length to them so i had to take them back and i bought the accel ones. worked out great they even came with some clips so you can route them neat.
i used accel 276s for the plugs. plenty of clearance
#217
Instead, now you have voided your warranty, as well as your ceramic coating warranty.
#218
Just installed a secondhand set of 2055's on my '88. The car has AFR heads, serpentine brackets removed and replaced by generic ebay accessory brackets, AC and heat removed but the AC box still in place.
Install took 1.5 hours, but I didn't have to touch anything but the plug wires to get them both in from the top.
#219
Car: '91 RS, '64 C10 Stepside
Engine: 305 TBI, '00 5.3
Transmission: Manual, Automatic
Axle/Gears: 4th Gen with 3.42, 4.10
Are the Accel 276S and 8199 the same plugs? Jegs sells the 276S and Summit the 8199. Went to the Accel website and they don't even have the 8199 listed. I'm looking at installing the Hooker 2055's and want to make sure I've got the right pieces. Bought the 8199's at Advance yesterday. Also, what about a part number for the wires? I got the Accel 4065's.
#220
Aside from the #8 plug I can do them all in about 5 minutes. I usually spend about 20 on the #8 plug because its such a pain to get a socket on there.
Also, if you don't want to spend forever, find a set of Cap Head hex header bolts for a few of them. I use a mix because the cap heads are way easier to get in some places and I don't want to dent the headers. They are ceramic coated and I don't want the ceramic coat to crack.
#221
Anyone have the part number for the wire set? Are some of the wires 90*'s and some straight or are all 90*'s?
#223
Thirdgen89GTA, thanks for the info and taking the time to reply, but...
I know everyone is busy, but I can't believe no one has the time to simply look under their hood to see if all/some of the boots are 90 degrees or not. A part number would be even better. I'm running out of time as I'm getting ready to once again deploy to Afghanistan at the end of the month and would really like to get all of my mods done prior to leaving. It's gonna be a long six months...
Thanks Brothers...
Thanks Brothers...
#224
Thanks Brothers...
Thanks Brothers...
#225
Copy... Went back and looked and noticed squatingeagle posted that wires for a '79 Z-28 will work (post 216). I'll be heading to Advance to return my 4065's for a set of Accel 4048's.
Thanks Thirdgen89GTA...
#227
Here's what I'm looking at: http://shop.advanceautoparts.com/web...AMS_1316847699____# I'm not familiar at all with the TPI Vette's and wouldn't even know where to begin as far as searching for the correct ones to use.
#229
Also, it's a good idea to run spark plug boot protectors, they run about $40.00 a set from Jegs though Checkers or O'Reilly's might have them. I've gone through two sets of wires on my #'s 5 and 7 plugs. Gets hot down between all the collectors. Also the 3 and 4 were cracked but not arcing yet. Lastly, all my wires by my starter ahve started to melt from th heat (The plasic around them) and on the fan switch and knock sensor. running some protectors around them might not be a bad idea also.
#230
Car: 1983 Daytona 500 Edition Trans Am
Engine: Carb 305
Transmission: NWC T5
Im having a problem with the supplied y pipe hitting my oil pan. There is no clearance at all and it looks like i either have to dent the pipe or the oil pan to get it to fit. Anyone else have this problem???
#231
I will do a "ditto" on this. 90* is a must, nothing else will work.
Call Hooker tech support. Where is the y-pipe touching on the oil pan? front/rear, pass/driver.....
#232
Car: 89' IROC-Z
Engine: LO3
I saw Ozz1967 post #229 talking about boot protectors. I have 1700* coated 2055's but still went with these. Extra safety never hurts.
NOTE: They come with a metal ring on the boot end which makes it very hard to fit the wires through even with straight boots. I turned the protectors inside out, removed the metal ring, and slid them right over the whole spark plug boot and they sit right up against the motor itself. Full boot and plug protection. I recommend.
http://www.summitracing.com/parts/DEI-010512/ *Black Version*
#233
Engine: Carb 305
Its hitting right on the whole front face of the pan. I cant even connect the collectors on the headers because i get one on and i hit the oil pan before i even get close to the other collector. I will definetly try to get ahold of hooker.
#235
Car: 1991 camaro RS convertible
Engine: EFI 383 150shot nitrous.
Axle/Gears: 2:73...
i had them on my first 1991 camaro i got mine on trade traded the old 5.0 for them to put on my 355 that was going in i had installed them in the car on the street infront of my house everyone told me the pass side was the hard side so i started there it was easy i was really happy till i tried to do the driver side ha after unbolting the motor mounts and going in from the bottom i got it in then the hooker y pipe had to go in and again had issues with the driver side once it was in it was well worth it and you want locking nuts some of the header bolts are a sob to get to
i now have long tubes on my 91 vert those are the sobs to put in
#236
Axle/Gears: 2:73...
i had the same issue with mine hitting but it will fit it just takes alot of moving them around and cussing
#238
Car: 1991 RS
Engine: 383 stroker
anyone have an issue installing the 02 sensor?.....I can't get mine in because one of the pipes is sticking down too far inside the ball flange.
#239
After my old set of edelcock (sic) headers totally destroyed my last set of wires, I picked up a set of these off eBay at the same time I purchased a new set of DIY accel wires.
Been over 10k miles and 2 years now, now on a set of hooker 2055s. 3 or 4 of the wires are right up against the primary tubes actually resting them on them and with these protectors I haven't had any further BBQ problems.
#240
QFT!
#241
Those of you who have the hooker 2055's, does anyone know the length and thread pitch of the collector bolts that hold the ball flanges to the Y-pipe?
Somehow, after 3 years one of the bolts has decided to walk its way off the car. Hence, I now have a massive exhaust leak. Ugh. And there is a car cruise tomorrow that I want to go on.
I still have one, but don't have the opportunity to pull the other one off tonight to match for a bolt.
#242
https://www.thirdgen.org/forums/tech...-nut-stud.html
Hooker 2055 Collector flange bolts are 7/16"-14, 2" long.
That thread saved my butt for tomorrow's cruise. Now if only Mother Nature would cooperate.
#243
Hi !
Tell me please, this header (HOK-2055-1HKR) can to install, in my Firebird 1991 , 5.0 TBI ? what problems may arise?
I wanted to buy HED 66481 - a big problem !!!! manufacturer breaks the terms of
I waited for 1.5 months, in the end, I refused
Thank you !
Thank you !
#244
hey i got the hooker 2055 headers hooked up to my 350 tpi, im wanting to do an lt1 swap soon and would like to know if my current exhaust setup can work with it. thanks.
#246
Car: 89' IROC-Z
Engine: LO3
Solved my own issue through the power of Google and a reference to TGO's page.
http://www.boltdepot.com/fastener-in...IandPitch.aspx
#247
Car: 1992 Firebird
Engine: L03 305 TBI
Axle/Gears: 2.73 posi rear
Can I install Hooker 2055's on my stock 305 TBI? Or do I need to install angle plug heads?
#249
Car: 1992 Firebird
Engine: L03 305 TBI
Thanks!
Can anyone recommend a good 3" cat and cat-back that are to go with these headers (and will fit)?
So far I picked out a MagnaFlow 94000 (3" in/out), and Magnaflow 16829 Stainless Cat Back Exhaust
#250
I believe Dynomax makes a high-flow cat. Do a search for it on the board in the exhaust section and you should find it. It's a 3" in/out. For the catback, I love my Hooker Aerochamber muffler. WIth that, just have a shop fab up a 3" "catback" from the cat to the muffler for you.
