PS pump with headers?
Old 08-21-2009, 08:57 AM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
i just got my hedman shorties installed the other day and now im wondering what you guys have done for your power steering pump? i know im not the first one to run into this and the search diddnt come up with anything pics would be nice, thanks
Old 08-21-2009, 12:26 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: PS pump with headers?
Wow, I've never heard of anything like this.
Try this thread?
https://www.thirdgen.org/forums/engi...lternator.html
Old 08-21-2009, 03:55 PM
Brennan's Avatar
this is a pic from the link you posted showing my exact problem but i was hoping there was something better then buying a longer bolt and spacer. my bracket is already cut tho, just like the one in the main pic. i geuss i couldve explained the problem more, its not the ps pump its self just that peice.
Old 08-21-2009, 05:58 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I just put in my Edelbrock headers last night. The install kit came with a couple of spacers and I had to reuse the old bolts.
Old 08-31-2009, 12:32 PM
Corey's Avatar
I just ran into the same dilemma this past weekend after installing my headers. I have a serpentine belt setup on my car, and I have just been running without that support bar in the back, but I'm sure it's not a good idea.
At first I was going to use a spacer, like the pic above but to me that would just not look professional. I also want to use locking bolts on the headers, which means I couldn't use the header bolt hole at all.
My latest idea was to try to fabricate/find a flat bar type thing that I could bolt between stud on the back of the pump, and an unused accessory bolt hole on the front of the head. I haven't checked yet to see if the two points would really line up with a flat bracket, but I'm hoping so.
Old 08-31-2009, 01:59 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I ended up using a spacer from at sway bar bushing settup, just cut down. That way it was big enough it didn't fall in any holes and one piece to make it look professional...
Old 08-31-2009, 02:48 PM
da.slyboy's Avatar
Car: 84 frankenstein Z28
I am surprised that your headers didn't come with bolts and a spacer. I could have swore my came with them when I purchased mine (though it was about 10 years ago) Anyway just paint the spacer in your engine color and it end up not looking half bad.
Old 08-31-2009, 06:34 PM
Brennan's Avatar
i ended up going with a spacer and longer bolt. looks half decent because i found a chrome spacer and cut it down, ill get pics tomorrow
Old 09-02-2009, 11:30 AM
Racing_Master's Avatar
Car: 1991 Camaro RS
Engine: 305 TPI V8
Axle/Gears: Stock V6 Rear End
Mine did not come with anything either. I plan on deleting power steering when I get a manual steering box, but for now I just deleted the bracket all together. There is a bolt near the water pump that can be used for adjustment, and a top bolt, those are the only two I even use right now. Yeah the pump makes some noise when I turn it to lock, and its not perfect, but it works for now, until either I make a bracket myself, or delete power steering all together, and free up that extra power.
TreDeClaw
Theoretical and Street Racing
06-22-2021 08:21 PM
hectre13
09-08-2015 03:38 PM
hayesaw0210
08-23-2015 11:15 PM
theurge
08-21-2015 12:46 PM
Dialed_In
08-20-2015 01:45 PM
Quick Reply: PS pump with headers?
