2 cats, I cant decide which is better
Old 08-25-2009, 02:49 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Which one do you think is better for my application. 1988 Camaro Iroc 350, stock exhaust, stock everything.
These are factory exact bolt in. In your experience, which one of these flowed better/sounded better?
MagnaFlow 93441 - MagnaFlow Direct-Fit Catalytic Converters
http://www.summitracing.com/parts/MPE-93441/
Catco 9118 - Catco Direct Fit Catalytic Converters
http://www.summitracing.com/parts/CTO-9118/
Old 08-26-2009, 11:23 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 2 cats, I cant decide which is better
The cheaper one - cats have nothing to do with sound, and all aftermarkey cats are hi flow.
Old 08-27-2009, 09:41 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
The Magnaflow says no AIR pipe. But the picture shows it having one.
I have the Catco. No problems with it. Stephen has the Magnaflow. No problems with it.
Old 08-27-2009, 09:49 PM
Stephen's Avatar
Car: 87 GTA
They are probably just using a "stock picture" not showing the exact cat for each part #. My Magnaflow also has no AIR tube, but then again.....My smog pump was pulled and the tube going from the pump to the cat.
"Technically", my setup is illegal, but my outputs #s were CLEAN, at my last test, on a 1 yr old Magnaflow cat.
High Speed-2692rpm
HC 220-limit...............4-my reading
CO% 1.20-limit.............0-my reading
Idle
HC 220-limit..............16-my reading
CO% 1.20-limit.........0.01-my reading
Old 08-28-2009, 10:19 AM
IROC216's Avatar
Car: 1985 CAMARO
Engine: 350 v8 CARB
From my own personal experience i would say magnaflow, When I replaced the cat on my 89 IROC with a 305 the exhaust was all factory and the magnaflow cat DID make a difference. It was alot more aggresive sounding especially when it is started. Also i orderd one without the AIR tube and the guy at the exhaust shop swapped mine for another one with a AIR tube
Old 08-28-2009, 11:41 AM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
i have a catco 9118 and love it. when i hooked it up a noticed the car sounded great and the car drove alot smoother. i would go with catco.
Old 08-29-2009, 12:24 AM
Bmv5's Avatar
Car: 1986 Iroc-z Camaro
Transmission: 700r4 Automatic
I would prefer the Magnaflow just because I like there exhaust, it looks nicer, and it's cheaper.
Old 08-29-2009, 08:23 PM
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
I'll go with the catco I currently bought to high flow Catco cats for $50 off my friend im going to do the setup with the dual cats for my car and keep on going with the dual to my 1 Chamber muffler.
Tony.
Old 08-31-2009, 05:57 PM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
http://banditexhaust.com/catalog/pro...oducts_id=1260
got mine from them for 93 or so shipped. has the air tube and bolted right up.
Old 09-01-2009, 06:48 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Thanks for the info man. Ill check it out.
I prior to this weekend i wasnt 100% sure it was the cat, so i went and tapped the cat to see if i could hear stuff moving around, which i can, but not much.
Anyway, i took the hammer and gave the cat a few slams to break the clog up, and when i took it out for a drive it was like a totally different car. The tires chirped 2nd gear (auto) i could barely get it to spin thenm from a stop when i first got the car.
Im now sure its the cat.
Thanks, everone for help.
Fronzizzle
02-09-2017 09:31 AM
mud runner
11-02-2015 07:30 PM
topteam54
10-06-2015 12:21 AM
Camaro_383
09-11-2015 11:28 PM
UltRoadWarrior9
09-02-2015 08:24 PM
Quick Reply: 2 cats, I cant decide which is better
