What are the downsides of dumping exhaust before rear axle?
Car: 90 camaro RS
If any, what would they be?
Car: 87 GTA
Re: What are the downsides of dumping exhaust before rear axle?
At low speeds & idle, exhaust gas coming up inside the car.
Increased interior noise, especially if the tips are aimed down & the sound echoing up, into the car.
If you do it, I suggest taking it to the side, for a side turn-out, just before the back tire.
Car: 90 camaro RS
Yeah I figured the interior noise would come into play, but I plan on getting a relatively quiet muffler. I'm sure there's more I can I do dampen the interior sound, too. I was planning on running it to the sides and dumping at 45* with or without a tip, haven't decided yet. I was referring to performance when I asked the question, although I didn't specify that, would I lose high end, low end, or anything?
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
If you have your underside and axle painted up all pretty like. its gonna coat it all with exhaust. I had my truck all painted blue underneath and it was all black in a couple months. the exhaust exited before the rear axle on it. I Found that puting turndowns angle down and out it kept most of the exhuast going out from underneath.
Car: 82 Sport Coupe Street Car
Engine: Small Block
Transmission: TH350/10"-3500
Axle/Gears: 9" / 4.56 / Spool
If you drive or park in a gravel, or dusty area (pits at the track, etc) it's gunna blow a lotta dust up. Mine have always been turned down and out before the axle, and i don't mind it...just be aware that if your beside others when you start it up, or move, they may get pissed if your blowing dust all over their junk. + side is during burnouts, it blows the tire smoke out and makes it groovy lookin! ...LOLOL
Car: 90 camaro RS
Alright well forget dumping at the rear axle then, thanks for the replies
Car: 87 GTA
Just turn it out to the side, not a complete dump UNDER the car.
Car: 90 camaro RS
I would but I live in an area where they don't fix potholes and manholes stick up 3"
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
It may tune the exhaust for an RPM higher than your powerband.
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
That blue car has to loud as hell for the passenger! haha
My car is setup like the blue camaro pictured but my exhaust dumps on each side right brfore the rear tires. If you do go that route you muffler choices are limited and usally have to go with racing mufflers.
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
I also have exhaust clips on my youtube. www.youtube.com/kingbikerhead check it out and let me know what you think.
And as far as performance you loose a lil in bottom end but you gain a lot on top end and trust me it feels good to smash on the pedal and actually keep on goin at higher rpm's.
I mean its up to you from where you want to take I agree with it i love so yeah.
Go to the link and you'll see pictures of the way I have the exhaust done on my car and my friends car, and the iroc is myfriends and he has 3inch pipeing.
http://viewmorepics.myspace.com/inde...albumId=758908
Tony.
Engine: 3.0L 2JZGE
Tony.
A buddy of mines 70 chevelle is setup with the exhaust dumping in front of the tire. Looks and sounds great. Although there is 10x the room under his car than a 3rd gen has.
Car: 1991 Camaro Z28
Engine: 5.0 V8 TPI
I did the dual side exhaust set up on my car and all i can say is get a good muffler i use to have a single 3" into duals out the back with two glass packs and shorty headers and it sounded good but then when i went to the side exhaust with 3" tubing and long tubes with the same glass packs it was way to loud. when i get back from school in the summer im going to change it.
I own a 5th gen camaro and I plan on adding some cherry bombs under car and a turn pointing out of side because right now I'm just dumping straight out of cat and its ridiculous but it sounds so good.
Car: 1984 F41 Camaro
Engine: LC1 V6 2.8L
Transmission: 4 Speed Auto
You could dynamat the interior of the car, but dynamat is expensive so i bought aluminum backed window flashing for houses and did my rood and rear trunk panel(behind tail lights) to keep the heat out(roof) and try to bound my sub sound more to the front instead of out the back, one day i might do more of the car but who knows. Dynamat and its equivalents are also heat barriers too! But beware once they are put on, they give more h*** than anything you could imagine when trying to take off
I'm running long tube headers, dual exhaust, with FlowMaster Super 10s, that dump just in front of the rear axle, with tips that are turned down and slightly outward. I don't find it too loud to have normal conversations inside the car with and it sounds great. The only down side to me, and it's been covered, is the dust it blows up in a dusty parking lot at times. Here is a video I took recently of a quick drive to the store with the windows down; it's much quieter with the windows up.
Here is what it sounds like from the outside................
Engine: LC1 V6 2.8L
https://www.youtube.com/watch?v=zYBsv5KwhNU
^^^Thanks, it's still a work in progress, but it's almost finished.
Good afternoon MSgt Luttrell ,
Do you have no vehicle safety inspection in Arkansas ? I ask because where I live our cars have no emissions inspection whatsoever but we do still have a safety inspection and one of the big things they bitch about is the exhaust . Namely , that it can't be at all loud and that it has to run to the back of the car and not terminate anywhere under the car or in front of the rear wheels because that's not "as built" .
In other words , consider yourself lucky that Arkansas is as permissive as they seem to be about exhaust modifications because I'd never get my car past an inspection if I had an exhaust such as you describe .
Back when I was in the military and was stationed in Utah for four years, I legally kept Arkansas plates on my '67 Camaro and it drove the police there nuts; I got pulled over all the time for having a non factory hood scoop, but it was perfectly legal in Arkansas so they couldn't write me up for it. I got to know the officers in that town pretty well.
Two things , first that's great that Arkansas is less strict than where i live , and second , Damn we really had some fine looking cars available back in the day . My all time best wasn't a GM , it was a (real) 1970 Road Runner with the 440 sixpack & 4 on the floor .
That sure is one fine looking Camaro !
1992 Trans Am
05-10-2023 07:19 PM
