silly cat-back question
Old 02-21-2011, 09:30 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Hey guys, newb question here. I'm gonna be dropping my fuel tank soon to perform the dreaded fuel pump swap and while I have the rear axle out, I wanted to bolt in a new 3" mandrel bent cat-back with a magnaflow muffler (heard good things about them). I'd like to swap the stock manifolds for headers sometime, but that's going to have to wait. Can I swap in the new 3" catback in with the factory catalytic converter, manifolds, and y-pipe for now and then swap those out for shorty headers later on? And any recommendations for the cat-back? And am I correct to understand that the magnaflows are good at keep interior drone down?
Thanks guys!
Old 02-23-2011, 05:34 PM
Engine: LB9
Re: silly cat-back question
i know i'm not the brightest crayon in the tool shed but my question isn't THAT dumb is it? lol
Old 02-23-2011, 05:39 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Your stock exhaust is 2.5in or maybe 2.25in, so you'll need a 3" to whatever coupler to connect it, available at any auto parts store. Just don't weld anything that is getting replaced soon.
You don't have to remove the rear axle, just drop it down enough to skinny the intermediary pipe/muffler out. Just don't stretch too much or break the rubber brake hose on driver side rear.
Old 02-23-2011, 05:52 PM
Engine: LB9
THANK YOU. I had a feeling that was the case with the coupler but I wanted to double check.
MustangBeater20
10-29-2022 09:20 PM
fasteddi
09-10-2015 09:32 AM
Bubbajones_ya
08-31-2015 12:02 PM
ezobens
08-19-2015 10:29 PM
redmaroz
08-16-2015 11:40 PM
Quick Reply: silly cat-back question
