Smog system modification
Old 12-21-2014, 01:19 PM
CatmanFS's Avatar
Car: 85 Z28
Engine: 93 LT1
Axle/Gears: 3.73 01 SS
The pipe that goes down from the AIR switch to the cat broke off right at the side of the cat. I am going to get a cat without one and just slowly remove the smog pump. For right now I'm going to use an elbow where the T junction used to be, and the smog pump and air diverter valve will just be sitting there pumping out just plain air I guess.
Two Questions:
1. Will the AIR pump and diverter valve continue to work the same way without the exhaust and still pump just regular clean air?
2. Can I use this extra air pressure for some beneficial reason. I was reading about the PCV valves being used to filter out gasses that could contaminate oil. I was wondering how this system would behave if extra air was pumped in one side to force air out the other. Just an idea. Any info is appreciated.
Old 12-21-2014, 06:03 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: Smog system modification
You will hear a humming without the pipe hooked up
Old 12-21-2014, 06:44 PM
CatmanFS's Avatar
Car: 85 Z28
Engine: 93 LT1
Would removing the Air diverter thing help? Better or worse?
Old 12-21-2014, 08:57 PM
VincentZ28's Avatar
As far as performance goes, no loss and no gain. All it does is heat the cat up quicker so it can work faster.
Old 12-22-2014, 08:45 AM
CatmanFS's Avatar
Car: 85 Z28
Engine: 93 LT1
I'm talking about the vibration.
Hotrodboba400
12-10-2019 07:07 PM
norcalz28
Northern California
26
12-07-2016 12:49 PM
91L98Z28
Southern California Area
09-19-2015 09:35 AM
R13_Braz
09-18-2015 05:00 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Smog system modification
