Here's my 4inch over the axle best sound exhaust
Old 02-23-2015, 07:55 PM
davidsiebert2's Avatar
I did a dual 2.5" y pipe to a single 4 inch basically cat back, with a dynomax 4inch muffler.
Attached Thumbnails Here's my 4inch over the axle best sound exhaust-image.jpg
Old 02-23-2015, 09:06 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: Here's my 4inch over the axle best sound exhaust
The vid is set to private
Old 02-24-2015, 06:50 AM
Danny_VXH's Avatar
Vid is set to private like LB9GTA said.
Old 02-25-2015, 05:38 AM
Sorry about that it's fixed now
Old 02-25-2015, 06:38 AM
Danny_VXH's Avatar
Sounds sweet. Doesn't the fat pipe cause any clearance problems?
Old 02-25-2015, 08:16 AM
It did on the first few big bumps n then it was good lol.
Old 02-25-2015, 10:17 AM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Sounds good! Very Impressed that you snaked it by with the upper brace in place.
I recently completed my 4" exhaust build. I ended up using a bullet muffler before the axle in addition to a hooker max flow afterwards. The RH exit is definitely a more direct flow path, plus it probably doesn't heat the fuel tank as much.
Attached Thumbnails Here's my 4inch over the axle best sound exhaust-20141004_171105.jpg   Here's my 4inch over the axle best sound exhaust-20141004_171132.jpg   Here's my 4inch over the axle best sound exhaust-20141004_163938.jpg
Old 02-25-2015, 12:13 PM
Hell ya looks good !! Do u have a video of it running ?
Old 02-25-2015, 06:37 PM
25thannivZ28's Avatar
Car: 1992 Z28 Camaro w/70k
Engine: 427 w/4" Mufflex Exhaust
Transmission: 700R4 3500 stall
Axle/Gears: 4.10:1
Sounds really good! I don't have a clear picture of over the axle, but its super tight on the passenger side. 4"Mufflex system with Magnaflow single-in-single out muffler
Old 02-26-2015, 11:54 AM
Car: 1991 Z28
5.3 with LS9 cam. This is going through manifolds and a dirty 2.5" to 4" y pipe.
Old 02-28-2015, 08:08 AM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
ive been looking to dumb the sound of mine down a little. ive got the magnaflow race 4 inch on it now. I might do what you did .
mine does get the fuel tank warm.The stock steel sheild is long gone. I just saw a muffler heat shield that is held on with stainless straps. I wanna say it was DEI.
Old 03-01-2015, 09:11 AM
With mine going straight out my tank never got warm. It didnt cross over n come out the pass side. But if you got the say back half of the exhaust or just all of it black ceramic coated it would shed very little heat 👍.
Old 03-01-2015, 05:02 PM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
I might go with these in the near future
http://www.jegs.com/i/Thermo+Tec/893/16800/10002/-1
http://www.jegs.com/i/Thermo+Tec/893/16500/10002/-1
I got to drop my tank soon again. I might use the one wrap in between the tank straps.
I like it going out the pass side like you did. id just have to tone the sound down. I like the sound, don't get me wrong ,but my car has been completely redone, and im struggling to hear for any problems on tset runs. and all I hear is drone. wont be such an issue once ive worked everything out and have more confidence in the car.
Old 03-03-2015, 04:46 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
http://youtu.be/y1DDVQTCrl8
Love that hooker max flow mines sounds like yours really low key part trottle and idle but screams WOT , people are surprised by the WOT tone only the they realize that's not no normal thirdgen lol
Dyno Don
01-24-2016 08:24 AM
UltRoadWarrior9
09-02-2015 08:24 PM
Hotrodboba400
09-02-2015 07:28 PM
DJanes97
09-01-2015 02:55 PM
db057
08-22-2015 08:17 PM
Quick Reply: Here's my 4inch over the axle best sound exhaust
