which msd plug wires w/ dyno don headers?
Old 05-11-2015, 08:56 PM
91 zeee's Avatar
Car: 1991 Z-28
Engine: 383 TPI
91 z28. Which MSD plug wires work best with Dyno Don headers? (MSD could not give me any advice with headers). Distributor and coil are stock. Hoping someone has tried a set and found a good part #. Thanks!
Old 05-12-2015, 11:05 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: which msd plug wires w/ dyno don headers?
Do not use MSD wires with headers. (junk) They arc thru the insulation.
BW Nascar Select work well #CH8833
Old 08-09-2016, 06:23 PM
BOTTLEDZ28's Avatar
Transmission: A4
91 z, what wires did you end up going with? Im running OEM wires at the moment which have a #5 and #6 straight plug boot. Not sure if it will work yet. I may need all 90 degree ends and if so then it wire hunting time.
Old 08-13-2016, 03:55 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
either get a set of custom plug wires for a mid 70's (75-77 is the best bet if you say it's a Monte Carlo or Camaro) car or truck with a 350- they run the wires around the valve covers and down to the plugs- or get a universal set with 90 degree boots and make them fit however you want.
Old 08-13-2016, 07:23 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I like taylors with all 90 deg boots.
Old 08-13-2016, 01:26 PM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
I also use these and they work great with headers.
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
Thaney9
10-15-2015 06:37 AM
meeklay812
10-01-2015 03:46 PM
z28joe2
09-28-2015 05:54 PM
Quick Reply: which msd plug wires w/ dyno don headers?
