Long tube headers to vortec heads
Old 09-09-2015, 06:11 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Hi,
propably going to buy long tube headers(obx,stainless works or dougs),and I'd like to is there enough spark plug clearance with EQ vortec heads,and how is it overall fitment with those headers?
Old 09-14-2015, 01:31 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Long tube headers to vortec heads
i can only comment on the oem vortec heads with Hedman Hedders, but the spark plug clearance with them is better in every way than other oem heads..
Old 09-15-2015, 08:19 PM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
I ran vortec heads with Hooker super comp headers and they fit just fine
Old 09-15-2015, 08:42 PM
skinny z's Avatar
I've run Hedman's with the OEM Vortec as well as the RHS Vortec which is the EQ casting. No trouble with the plugs. It is necessary to use an offset box end wrench on a couple but other than that, it's all good. Plenty of room with 90 degree plug boots as well.
Old 09-18-2015, 03:58 AM
z 28 jari's Avatar
Engine: 385
Thanks for replies.Anyone experiences stainless works or obx(or similar )long tubes?
Old 09-25-2015, 01:50 AM
Car: 89 Formula
Can't say about fitment with factory vortec heads, ( I switched to AFR 190 "vortec" heads) but I also changed to Hawks Stainlesss works headers and they fit much better than my hookers ever did. Only problem is they're tucked up so well I'm having a hard time wrapping my mind around how to get exhaust on the damned thing.
Old 09-25-2015, 03:36 AM
z 28 jari's Avatar
Engine: 385
Do you have angled or straight spark plugs at those AFR heads?
How is it with frame/headers clearance(do they hit anywhere,need cut/hammering)?
Edit. 15.12-15
I got maximizer long tubes(1.75" primaries) and test fit them,plug clearance is good(with ngk tr55's and accel 300+ wires 90 deg. boots)
Old 09-14-2021, 10:03 PM
Chaga's Avatar
I am putting a 5.7 vortec, from 98 into my 86 z28 wondering what headers will fit best
Frozer!!!
01-19-2024 04:55 PM
84z96L31vortec
08-20-2017 12:16 AM
italiano67
12-11-2016 09:21 AM
bamaboy0323
09-03-2015 06:07 AM
L98GTA87
08-11-2015 06:55 PM
Quick Reply: Long tube headers to vortec heads
