Making Edelbrock y-pipes suck a little bit less.
The 88 IROC I have had a set of Edelbrock TES headers when I got it. I don't really like them because the collectors are terrible and the merge in the Y-pipe is a real disaster. I'm replacing the catalytic converter and making a new 3" intermediate pipe that's not crush bent. I'm also installing subframe connectors which is why the Y pipe is off.
I'm trying to keep this car a budget build, or I'd have already bought a set of Dyno Don's headers. (I have a set on my GTA and they are fantastic) The header collectors are bad enough, but I just couldn't stand to look at the Y-pipe. It is absolutely terrible as you can see.
Step one was to tack weld some support pieces on to keep the pipes in place while I work my magic.
Re: Making Edelbrock y-pipes suck a little bit less.
Once I had the collector cut off, I used a cutoff wheel and a sawzall to cut the middle out of the merge. A band saw would have been really nice but I don't yet have the space for one.
After I got the middle cut out I began cutting a template for the section I was going to weld back in.
I then cut out a few pieces of steel the same shape as my templates. The steel I used was the same thickness as the exhaust tubing. I welded the plates in starting at the collector and working my way up. I used a hammer to fold the metal patch down between the pipes. Now its all welded and just needs a coat of paint before I reinstall it.
It's not glamorous but its bound to be better than it was...
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
LOOKING GOOOOD !!!!! should be the same on most other "Y" pipes . I have HEDMANS on my car . I will be checking out mine the next time I have it on the lift . DAMN , so many good ideas on this site . hope it never stops , good luck and thanks ..............
Car: 1986 Pontiac Firebird s/e
Engine: 305 Chevy
Axle/Gears: 2.77 for now
Glad some else noticed this on the edelbrock stuff. The outlets on the headers should be 2-1/2". The y-pipe is also pretty bad. I'm a Headers By Ed guy, I recommend getting their catalog and cassette tape , because it's great reading/listening .
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
i have the same on mine and thought the same as you.. good work
what updates are you looking for? I did the work over winter do I can't say if it made the car feel quicker or not. it was properly welded and supported so it didn't crack or break. That's about all I can add.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Or this.....PM me
Transmission: 5-Speed Manual
Guess That's One Of The Reasons Edelbrock Dropped Their Entire Exhaust System Line.
[NY] Dyno Don Headers
huberta5691
35
04-12-2016 10:12 PM
customblackbird
18
11-16-2015 03:02 PM
