Stock Manifold Mating Surface Cleanup
A previous owner used cheap manifold gaskets that eventually led to one of them blowing out. I pulled the manifold and its not warped when I line it up to a straight edge. The problem is that there is baked gasket material on the mating surface of the manifold.
Does anybody think going at it with a wire brush is sufficient or should I take it to a machine shop and have it decked so I know its clean and straight?
Received 1,672 Likes
Re: Stock Manifold Mating Surface Cleanup
Wheel of death.
As cheeeeeeep as having it shaved is though, not a bad idea. Last one I had that done was like $15.
Wheel of death means no good?
Ill phone around and see if I can find a place that can do it.
Wheel of death
https://www.google.com/?gws_rd=ssl#q=roloc+disc
Plus of course, yerbasic 18,000 RPM die grinder
You can pick em up at pretty much any parts store in the abrasives aisle. Die grinder is like $20 - 25. DG is one of my most-used tools Wizz wheel is probably what I use the most on it, but those 2 things plus a 1" sanding drum, plus cartridge rolls, plus a buffing wheel and some rouge, will cover AN AMAZING amount of applications.
Axle/Gears: 10 Bolt 2.73 Open
I've had good luck with products like this. Softens up the old material for easier removal.
http://www.napaonline.com/napa/en/p/...940/BK_7651940
