Any one fab their own y pipe ?
Old 07-14-2016, 01:16 PM
MachinistMark's Avatar
Car: 85 Trans Am
Engine: 416 headed LG4 (i think)
Transmission: auto
Axle/Gears: 9 bolt, unknown ratio
i Have hedman shorty headers. The ball and socket type non coated ones. Currently mated to a. Severly hacked together factory y pipe. I live in Canada where there is no emissions testing so smog legality doesn't matter.
Easy option would be to just get hedmans y pipe but I'm not a fan of the 2.25 piping. Would like 2.5 or even 3 inch as I will be piecing together a 3 inch system replacing the cat
Has anyone done this? Or had a shop do it? Or is there one available that will work?
Old 07-14-2016, 01:50 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Any one fab theyre own y pipe ?
Made one for my friend and one for my self on 86 TA and 84 TA with sub frame connectors
https://www.thirdgen.org/forums/exha...al-y-pipe.html
Attached Thumbnails Any one fab their own y pipe ?-photo-3.jpg   Any one fab their own y pipe ?-under_body.jpg   Any one fab their own y pipe ?-img_20140910_213400_712.jpg   Any one fab their own y pipe ?-img_20150404_215411727.jpg
Old 07-14-2016, 02:59 PM
Car: 85 Trans Am
Transmission: auto
Re: Any one fab their own y pipe ?
Do you recall what bends/where you got them? What about the 3 inch ball and socket flanges?
Total cost?
Old 07-14-2016, 03:50 PM
midias's Avatar
The parts list is in the link I left you is I think he got them here probably $150-200
The one I made for my self was $100-150, merging much faster without using the flowmaster collector.
http://stores.ebay.com/Mandrel-Bendi...=p4634.c0.m322
http://mandrelbendingsolutions.com/mandrel-bends/
1. 6 @ 2.5" 90 degree bends
2. 2 @ 2.5" 45 degree bends
3. 1 @ 3" 45 degree bends
4. 5 @ 2.5" to 2.5" couplers.
5. Flowmaster Y250300 Collector
To get the ball and socket joints google found them instantly
https://www.summitracing.com/parts/hed-21115/overview/
https://www.summitracing.com/parts/hed-21119/overview/
Old 07-14-2016, 04:49 PM
Car: 85 Trans Am
Transmission: auto
Yeah, I'd noticed that after I had posted was at work so could only skin the other thread. In your parts list above you have 6@ 2.5 90 degree in assuming 6 is the quantity you used? Or is it the radius of the bend
Old 07-14-2016, 05:15 PM
midias's Avatar
Quantity 6 but what you need depends on the style you choose.
Old 07-14-2016, 05:39 PM
Car: 85 Trans Am
Transmission: auto
I'd like to replicate what you have carbon copy except perhaps swapping the mandrel bends for normal bends sources locally to keep costs down. And to mate up to hedmans instead of the flowtechs you built it for
Old 07-14-2016, 08:54 PM
midias's Avatar
I made it for hooker headers, I would not use flotecks as an anchor
but you will need these + the ball and socket stuff
you can skip the 2.5 to 2.5 couplers but I used them to help me get angles and lengths right
Old 07-14-2016, 10:59 PM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
I just got the Hedman Y pipe pn 500-17678 from Jeg's and it's a ceramic coated 2.5" pipe paired with their 68478 ceramic coated shorty headers. Get your headers coated if you can.
Old 07-15-2016, 05:25 AM
Car: 85 Trans Am
Transmission: auto
I stripped them to bare metal before installation and painted them with the vht header paint. 3 years later they've held up great. Yeah I have hedmans not flowtechs.
Old 07-16-2016, 12:42 AM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
Again, I have the Headman's also and their Y pipe is 2.5"
Old 07-16-2016, 08:17 AM
Car: 85 Trans Am
Transmission: auto
It's 2
25 onto 2.5 accordi g to everything page I've seen.
Old 07-16-2016, 08:00 PM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
Maybe I'll have to double check to be sure and get back with you.
Old 07-17-2016, 06:39 AM
Car: 85 Trans Am
Transmission: auto
I was just going off of this from the header sticky on this page:
The y-pipe is a 2.25" pipe that y's off into a 2.5". However, you can cut this at the y and use 2 mandrel bent 3" peices. The collector design on the pipe (for the y) expands out to about 3.25" which allows you to easily weld the 3" section in. Y-PIPE WONT FIT WITH MINISTARTER!! Also, you'll need to weld an o2 bung on the header collector. Avg price: $135.00, Ypipe #17470: $95.00. ($215 set)
As well as summits site says 2.25 onto 2.5
Old 07-20-2016, 02:28 PM
83 Crossfire TA's Avatar
I did 2.5 > 3", but I also started with the older version of those headers with the 3 bolt header flanges, cut them off and put on 3" v-band flanges like you see on turbo setups, making pulling the headers a roughly 45min job for one person....
I have pictures somewhere... I also sandblasted mine (I've owned the headers since the early 90's this is the 3rd f-body I've had them on �� and they were quite rusted before I started) and coated them with VHT, they're holding up OK but they definitely are showing some rust spots...
Old 07-25-2016, 09:15 PM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
Hey crossfire see if there's a local powder coating facility the does ceramic coatings also. I asked the guy who did mine if I could have them redone down the road after years of use and he said they do them all the time that way.
Old 07-28-2016, 09:01 AM
Tony V's Avatar
Car: 88 Camaro
Engine: 383
Axle/Gears: Moser 9 inch/4.11 TruTrac
I'm putting together a y-pipe for a 4" mufflex single to my Hooker 2210's. Not quite finished.
Attached Thumbnails Any one fab their own y pipe ?-20160719_200150_resized.jpg   Any one fab their own y pipe ?-20160721_185451_resized.jpg   Any one fab their own y pipe ?-20160721_185507_resized.jpg   Any one fab their own y pipe ?-20160721_185441_resized_1.jpg   Any one fab their own y pipe ?-20160722_170607_resized.jpg
Old 01-28-2017, 09:42 AM
84 Kamp311's Avatar
Car: 1984 Camaro Z28
Engine: 406
Transmission: TH400 3K stall
Axle/Gears: DTS 12 bolt 3.73 eaton posi
Here's a couple pics of mine
Attached Thumbnails Any one fab their own y pipe ?-20170124_145035.jpg   Any one fab their own y pipe ?-20170124_143321.jpg
Old 01-28-2017, 09:59 AM
Twin_Turbo's Avatar
not really a y pipe biut they are on hedman mid lengths
Old 01-30-2017, 09:16 AM
makaveli09's Avatar
Engine: 350sbc
Transmission: TH700R4
Very nice setup you got there
Old 01-31-2017, 03:59 PM
86CamaroDan's Avatar
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
Their not shorties, but i used a magnaflow 2.5" y to a 3" outlet. Real nice piece. Also used the hawk's T56 longtube crossmember.
Old 02-04-2017, 06:19 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I made this one for my second hand Dyno Don headers I have. 2.5 into a 3.5 single.
Attached Thumbnails Any one fab their own y pipe ?-20170204_043307.jpg   Any one fab their own y pipe ?-20170204_043930.jpg
Old 02-06-2017, 07:52 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Nice job Robert. Ive had a guy in town build me two sets over the years to match up to my headers and 3in intermediate pipe.
mikeyt
06-27-2016 05:29 PM
TP355Z
06-09-2016 01:23 PM
Grant2k
06-02-2016 07:27 AM
I_R_O_C_Z_2_8
04-24-2016 12:29 PM
Quick Reply: Any one fab their own y pipe ?
