I only want.....Headers that will actually fit my 91'
Car: 91' Z28 1LE R7U
Engine: 350 ZZ6
Transmission: 6 Speed T56 Magnum
Axle/Gears: 3:42 posi G80/GU6
Headers for my 91'R7U/1LE. Headers that FIT!!!!!! Not headers that the ad hype proclaims to fit, but actually fit. I'm pulling my LB9 & T5 out and replacing with new ZZ6 350 (carbed) and 6 speed. I really do not want to put the stock manifolds on to it. I will be putting in new motor mounts regardless of the original's condition. Y pipe **** i can deal with i just want headers i dont have to smash and bend and that wont crack or fall apart in 6 months. Everytime i find an interesting set i start investigating and they usually get shot down in reviews/threads/posts whatever. This is getting frustrating. Any help would be cool.
Re: I only want.....Headers that will actually fit my 91'
I'm using Hooker 2055s with their y-pipe in my '91 Z28 with a (mostly) stock 305/T5. Only issue I see is that one of the brake lines rides awfully close to the headers. I don't know if you saw this thread, but it did influence my decision: https://www.thirdgen.org/forums/exha...055s-come.html
Now to be fair, I have to retain my emissions (so you might not need AIR tubes) and I haven't installed the full exhaust yet (it ends at the y-pipe). It's also a royal PITA to install/change plugs, but I fee like that is the case with most headers. Let me know if you want to see pictures of anything.
Hope you find a set that works!
Engine: 350 ZZ6
Car: 91 G92 Z28
Axle/Gears: 342
I'll get some pictures tomorrow!
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You would have to cut them back to make them 2 1/2" they are not even 2".
Interesting, I hadn't tried to measure them (I'm just going off the product listing) but now I'm going to pull the y-pipe and take another look. Those are the 2055s?
EDIT: Ahh, I found the post that originally came from and I see what you mean now. The flange itself is nowhere close to 2.5", but it can be widened up a bit. Thanks!
Last edited by BovineZro; 09-16-2016 at 11:53 AM. Reason: Adding additional information
Well, I neglected to take pictures over the weekend but I do have a couple old ones that show the driver's side header.
http://cimg9.ibsrv.net/gimg/www.thir...9560ca0a27.jpg
http://cimg8.ibsrv.net/gimg/www.thir...d1cf89d95d.jpg
Clearance is a little tight around the brake lines but I managed to move them a little further away. Also worth noting is that I don't have any HVAC stuff, so I don't know what clearance will be like on that side of the car.
I hope that helps!
I hope that helps!
Engine: 350 ZZ6
thanks guys. Still undecided.
Engine: 350 ZZ6
Found a set of used ones recently pulled out of later 3rdgen camaro. No airtube holes. Also thru in a new y pipe that matches them up to where my cat used to be.
Car: 1987 Pontiac Firebird
Engine: stock LG4 305 ccc
Transmission: r700
Axle/Gears: 2.73 (turd)
Transmission: r700
Transmission: r700
I looked on the OBX website, and couldn't find headers for third gen, only 2nd and 4th, did you get your headers direct or from a dealer?
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
http://www.ebay.com/itm/STAINLESS-ST...pV3RLI&vxp=mtr
For under $300. I have them on my supercharged 412". They are fantastic.
They also have these shorty headers, also stainless:
http://www.ebay.com/itm/OBX-Exhaust-Header-86-90-GM-Chevy-Camaro-Firebird-305-350-Ci-Stainless-/172257878913?vxp=mtr
These I'm confused on. I've not actually had a pair in my hands, but they are listed as 1 5/8" but I'm told that they measure out to 1 3/4". The long-tube version is sometimes listed as 1 5/8, or 1 1/2" but are always 1 3/4"..
Nearly $600 for shorty headers is a little expensive, even if they are stainless. The long tube headers are the way to go. Whatever you do though, don't buy mild steel headers unless they are $150.
-- Joe
Thanks... from the research I've been doing, it seems long tubes might be a pain to install on my '83 LG4... it's stock... what do ya think?
When I'm responding to posts I'm assuming the person is swapping out the old, tired engine for a new one. The OP for example was installing a ZZ6.
But beyond that, I found them quite easy to install on my Formula.
-- Joe
Thanks Joe, I really do appreciate the help, and I don't mean to highjack the OP's post. Yeah, I still have the original LG4. That's why I'm going for replacing the exhaust first. I'm hoping to find some headers at a decent price.
Oh well, my intent wasn't to suggest installing headers on a stock engine. Especially an LG4.
-- Joe
-- Joe
Engine: 350 ZZ6
I just wound up getting used headers for $150 from a Camaro/Firebird junkyard that they pulled out of some thirdgen that was smashed. I don't even know what brand they are but whatever they are still better than putting the original 305 manifolds back on. Sand blasted for a sixpack and $20 for can of headerpaint and they look like new.
Engine: 350 ZZ6
Haha, nice! A guy about 3 hrs drive from me just sold a used set of Dyno Don's... sorry I didn't jump on that one. I might just get a new set of 2205's.
https://www.summitracing.com/parts/sum-g9005
The stainless version is around $135:
http://www.ebay.com/itm/STAINLESS-RA...BV3hc9&vxp=mtr
Then the Y-pipe is another $125 or so.
-- Joe
-- Joe
Engine: 350 ZZ6
Those headers are $119 new:
-- Joe
-- Joe
Engine: 350 ZZ6
So the $135 stainless are charged out at $178 cdn plus 14%tax = $203 plus $89 shipping which is actually $101cdn for shipping.= $304 cdn by the time i see them.
You may have already noticed the tube is quite close to the starter (especially if you run a large starter). You may want to get one of those blankets for the starter to avoid hard starts when hot. I ran those headers on a car back in the late 90's and I had a lot of hot start issues.
-- Joe
Engine: 350 ZZ6
[QUOTE=anesthes;6083531]That's too bad. Must be tough in Canada - high taxes, no handguns, and now I hear they are banning pitbulls.
-- Joe[/QUOTE
Thanks u bet I'll get a blanket for it. Is there any benefit to wrapping the pipes? See that once in a while.
Ya Canada is a pain in the rear when buying anything. I saw a new z06 vette at the dealer and the price was $128890😥 plus the mentioned 14% sales tax. New camaros are $50000-$80000 depending on model.
Pit bulls are only banned in a few **** cities. Where I live there are more guns & pet wolves than pit bulls lol.
-- Joe[/QUOTE
anesthes
10-11-2016 07:48 AM
Michael Canfora
09-13-2016 10:16 PM
nzwcpn
09-06-2016 08:05 AM
