Heat riser valve broke off- replace?
Old 10-24-2016, 08:31 PM
bubbaz28's Avatar
Car: 1983 Z-28
Engine: 305 LG4
Transmission: 5-speed
While investigating a rattle under my Z, I see this thing hanging down... the bracket had rusted through and the vacuum tube (which was very dry rotted) was the only thing holding it.
I think the valve is in the open position, but kind of flapping around in there.
I'm replacing the exhaust with Hooker 2055's soon, magnaflow cat and aerochamber muffler. So.. dumb question... no more need for a heat riser valve?
Thanks..
Old 10-24-2016, 08:57 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Heat riser valve broke off- replace?
Plug the line for now and just remove that vacuum line entirely once the headers are installed. If you can hear the valve flap rattling around when the car is running than just find a way to hold it open ( wire ?) till the header project starts.
Old 10-25-2016, 06:25 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
No more need.
JamesC
