Convince me to buy a single 4 inch exhaust for my 421
So I got a 421 ci motor.
I know its making north of 500 HP (never ran on dyno) but some day I will confirm. Tuning is coming along and its getting more and more fun to drive. So here's my question to the people in my neck of the woods CI wise, did you move to 4 inch sigle exhaust and have regets? As in was it too loud? I am not looking for Max numbers but I want a good sound but not red neck no muffler sound. I hear the videos on you tube and many are a touch to loud for my taste. I am running Hooker long tubes into 2.5 pipes into a 3 inch magnaflow cat back atm but I want to go bigger.
I know, I know can't have big and not loud.
I am looking at running the 2.5 off the long tubes into a 4 inch collector and all the way back single in single out muffler. Looking at Hawks setup specically and pick out my own muffler to suit my needs.
I am not against loud at WOT just don't want highway drone and upset neighbors when I fire this beast up. Moving out of town soon so I can fix the second part myself lol.
Re: Convince me to buy a single 4 inch exhaust for my 421
Whats the compression?
What cam?
I had a 4" on my 383 with a 6" case ultraflo round muffler. It was very loud lol only way to keep it relatively quiet is to add a few mufflers. One bullet in the I pipe region, and then a big one in the stock muffler location.
What cam?
Mike Jones custom cam:
Intake lift: .582
Exhaust lift: .589
Duration:
intake: 240
Exhaust: 242
110 centerline
I am not totally sure of compression but memory says north of 10 to 1 but not by much. I run it on 93 octane with no problems
Intake lift: .582
Exhaust lift: .589
Duration:
intake: 240
Exhaust: 242
110 centerline
If you like your magnaflow I would get this one 4" in dual 3" out magnaflow muffler. I have heard them they are not crazy loud and sound really good. You can also add a 4"
https://www.summitracing.com/parts/mpe-12594/overview/
You can also add a 4" bullet like this one after the merger to quiet it a little more
https://www.summitracing.com/parts/wlk-24217/overview/
Case Exterior Length (in.): 22.000 in.
Overall Length (in): 28.000 in.
Thickness (in): 5.000 in.
Width (in): 11.000 in.
Based on that statement alone, have you considered Holley's dual 2.5" system?
At 4" vs 2 x 2.5" you have about 80% less cross sectional area but at almost 10 sq/in (2 x 2.5") that may be more than enough to support your estimated 500 HP. The easier part is in the choice of muffler. 500 HP needs more than 1000 CFM before the exhaust starts to erode output. And 1000 CFM mufflers are rarely on the quiet side. Two 500 CFM mufflers on the other hand, can easily be found in just about any style/shape/ sound that you need.
Yes skinny Z I have but $800 and the fact I will have to rebuild my y pipe is why I am looking at 4 inch single. I can use my already built Y pipe with the 4 inch single from Hawks is $450 add $200 for mufflers and I can save alot of money. I wish they would hurry and release a steel version.
Car: 1992 Z28 Camaro w/70k
Engine: 427 w/4" Mufflex Exhaust
Transmission: 700R4 3500 stall
Axle/Gears: 4.10:1
When I put my 406 in, I kept my 3" Flowmaster exhaust on, my SLP Shorties w/ 1-5/8" primaries.
Ran between 12.9 & 13.1 @ around 106. I had 308 rwhp. I thought it was weak, then I invested in the Hooker LT Headers, 1-3/4" Primaries, 3" collectors into the single 4" Magnaflow muffler. Similar cam, now run 437 rwhp & 11.9 @ 117.
I'm not sure I didn't catch your Carb size (or TB capacity) relative to CFM. I've got 850, I should probably go a bit more.
I went with 4" because its unique, I've gotten several compliments on it. On how it sounds and how it looks. Though I've had some people wonder "WHY ONLY THE SINGLE EXHAUST, I WOULD HAVE GONE TRUE DUALS"
Well, that's their preference, I really don't care. I have absolutely no regrets.
Its got an awesome idle, I've never heard the WOT because I've never been behind it to know if its too loud. I recommend it!
Axle/Gears: 4.10:1
I don't know the individual part number of my muffler that came wth my kit. But it is a single-in-single out 4" Magnaflow. See straight through it.
This is the kit I have...
https://www.mufflex-performance.com/...lowmaster.html
Axle/Gears: 4.10:1
Wouldn't hurt to plug the 1050 back in if you got the 4". I'm tempted to get a Dominator 1050 or something of the sort to see if I find any gains (or lose streetability)
Axle/Gears: 4.10:1
Ok, i guess not extremely similar, but ive got..
Intake lift: .565 with 1.5
Exhaust lift: .580 with 1.5
Duration:
intake: 247
Exhaust: 253
110 centerline
Duration:
intake: 247
Exhaust: 253
110 centerline
Axle/Gears: 4.10:1
I think a key to my improvement was the headers. Shorties with 1-5/8 primaries were good for my 350 but a bit small for the 406 and AFR 1054 heads. 1-3/4 Hooker LTs probably a huge increase
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
4" exhaust is loud. Real loud.
3.5" exhaust is more than adequate for your power level. Hawks (Stainless Works) sells 3.5" kits and it fits very well. I bought mine with a hidden turndown tailpipe because showing exhaust under the bumper is sooooo 1980's.
Absolutely. An engine has to breath. As an example, back to back testing at the track showed that with my mid 12 second 355, uncapping the muffler (I've a cut out placed right at the turn before the muffler) in the 1/8 mile, there was a 1 1/2 MPH improvement in trap speed. No tuning or other changes. That says something there. (Mostly that my muffler is a total cork)
As for the hidden tailpipe, I had to rotate my exhaust tip down to make room for the trailer hitch (yes, a trailer hitch). After the hitch was removed, the tailpipe was more or less frozen in the turned down position. That's why my racing buddy nicknamed my car "the leaf blower". (and it's true).
That's the one thing about the BlackHeart arrangement I don't care for. The exhaust tips.
4" is not that loud cruising but WOT is. my 355 with afr 1054 big solid roller and just under 11-1 comp hooker super comps with a mufflex Ypipe 3" to 4" and a maganaflow muffler https://www.youtube.com/watch?v=oTDO0vNQjMM https://www.youtube.com/watch?v=Rs182oyqM0o
