[MO] Need Front End Parts For 92 Firebird Base With Ground Effects
Want a title? Post!
Car: 1992 Firebird Base
Engine: LH0 3.1L V6 191 CI
Transmission: TH700-R4 4-Speed Automatic
Axle/Gears: Stock
I need front end parts for a 1992 Pontiac Firebird Base V6 WITH Ground Effects.
The parts I'm looking for are as follows.
1 Front Bumper Cover with metal mounting brackets
The other Air Dam pieces that go with the piece shown below
Both Driver and passenger side fender ground effects
There are more parts I want but these are the most important. I'm gonna wait to see what this costs me before I go after anything else.
Last edited by powderedwater67; 02-02-2015 at 09:03 PM. Reason: Removed obsolete information.
1 Post
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Re: Need Front End Parts For 92 Firebird Base With Ground Effects
I have the hood hinges, marker light, and horn $30 shipped. I may possibly have a 91/92 air dam as well but would have to check.
Want a title? Post!
Axle/Gears: Stock
Here's a link to my thread about fixing up this car. It should help any sellers understand what I need better.
https://www.thirdgen.org/forums/memb...-firebird.html
Engine: 4++,350 & 305 CIs
I have the fender (GM), inner fender liner, vertical metal parts for the bumper cover and should have some other random parts that it looks like you may need.
I just parted a 91 T/A
I'm in central IL
I'm in central IL
Want a title? Post!
Axle/Gears: Stock
UPDATE:
I found a passenger side front fender ground effect for $85 that I'm thinking about getting IF I can find one for the drivers side.
If you have a drivers side front fender ground effect piece, or you would like to sell me both, LET ME KNOW!
It doesn't have to be perfect. The one I found has small tears here and there but at least it's a ground effect. Just don't sell me something that's like, half broken off though.
Also if you have any air dam pieces I'd like to look at those as well.
And the answer is yes. I can pay for it, just don't bleed me.
Want a title? Post!
Axle/Gears: Stock
BUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUMP!!!!!!!!!!!!!
I have a bumpercover from the same car as the fenders.
Its in better shape than yours but it does have 2 tears on the bottom.
If you're interested, its cheap.
Want a title? Post!
Axle/Gears: Stock
@TTOP350 - Sent PM
Terrell351
06-13-2021 01:13 PM
