A/C hose clamp/bracket for 82 Z/28
I had to replace the A/C lines in my 82 Z and received the longer hoses that go across the radiator shroud instead of the one that routes over the alternator bracket. I see there are 2 clamps that attach the lines to the shroud. Does anyone have a parts car that still has these on it for sale? Thanks.
Tom
Tom
Car: 1988 Camaro
Re: A/C hose clamp/bracket for 82 Z/28
I got them from a '84 Z28. I need to locate them. I pulled the engine out alittle over a mo. ago and put all the little parts in a couple of boxes, but I have them for sure.
Here is a link to my part out thread. 4th picture down shows the clamps
https://www.thirdgen.org/forums/exte...84-camaro.html
How does $12 shipped sound for both clamps
Yes I will take them. Thanks! Also is the high pressure A/C line still intact? I see it's disconnected from the condensor but can't tell from the picture if it was cut off or removed by the fitting. If it's intact I would like to buy that as well. Thanks again.
Tom
Tom
Car: 1988 Camaro
Yes sir, the AC line is still intact. It was took loose at the fitting. I will get you a pic of the line and bracket later tonight.
Car: 1988 Camaro
PM sent.
Car: 1988 Camaro
I need your zip code to figure shipping on the AC line
Pac J
05-17-2020 10:44 AM
2012sergen11
10-13-2015 07:38 PM
