[NJ] Need lower A pillar/kick area
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I need a rust free drivers side A pillar/kick panel area from a car. I can make the patch panels, but it will save me time if I can get a cut from a car. I need this area; Pink lines show the cut area.
Let me know what you have. Somewhat time sensitive, I need soon as possible since I am in the middle of working on it and I need to get it back together. I only found this much rust after I got into it.
Car: 91 Camaro RS
Engine: 305 TPI conversion.
Re: Need lower A pillar/kick area
I've got a parts car I'm cutting up. I'll take pics of what I have and post tomorrow
Car: 92 Firebird
Engine: 4.8 LR4
No, thank you. I need something rust free, there is a lot of rust in the pictures you are posting and mine isn't nearly as bad as yours show.
Car: 91 Camaro RS
Alright I have another car let me check it and post pics.
Fighting the same rust spot on my latest project car. The only hint of rust on the entire car. Judging from the frequency of rust repairs in this area (lots of rust repair threads show the same hole) I'd expect it'll be hard to find a rust free donor car. It'd be nice if the aftermarket would start producing more patch panels. Even so the bulk of that panel is flat in the area that needs to be cut out and replaced, so it's not too difficult to fabricate.
Car: 92 Firebird
Engine: 4.8 LR4
I can make a patch, but there are so many different thicknesses of metal in this area and getting a cut for the 3 different patches I need out of it is just easier. I fixed the other side already, but this side is more extensive. I am also building the car at the same time, so I can just keep going with other parts of the project until I get what I need.
Car: 91 Camaro RS
I have another parts car here. I'll get pics and send them if it will work we can go from there
Car: 92 Firebird
Engine: 4.8 LR4
Bump on this. I would settle for mostly just the rocker area at this point
Car: 91 Camaro RS
Man I got tied up over the holidays. I'll check that car and if good I'll get pics. Give me a day or two
