Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Lifted Camaro
Old 04-17-2006, 02:12 PM
tarvis's Avatar
Lifted Camaro
my buddy has an 83 camaro v6 and he doesnt want to front the cash to do the engine transplant, and hes become really attached to this car, so he doesnt want to sell it either...so he wants to do the next best thing, LIFT IT...ok well i know alot of you are probably against it, but were going to do it either way, so any help with info would be great...especially working wiht the macpherson strut...anyone know anybody who has done it to this style camaro before??...pics wanted, posts wanted, any info wanted...thanks
travis
Old 04-17-2006, 03:31 PM
ChevyMetal305's Avatar
Car: 1985 Camaro Berlinetta
Engine: 305 4 Barrel LG4
here are some pics...NOT MY CAMARO!!!
Old 04-17-2006, 03:49 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I've seen similar camaros at shows. I'm guessing they put the body on a S-10 frame.
I think it looks pretty cool
Old 04-17-2006, 05:57 PM
tarvis's Avatar
hmm...well i would like to keep in on the camaro unibody construction...anyone know anybody who makes a kit for this kinda thing?...or maybe a way to extend the macpherson strut or maybe buy a longer one??...
Old 04-18-2006, 01:23 AM
midnightcamaro's Avatar
dude if u jack up that car and its not on a s-10 frame u better never take it off roading. i dont think all the flex if gonna be good on the car with a unibody setup. yea and im not so sure about the strut i dont think u wanna start cuttin and makin the strut longer. u can round up an s-10 frame cheap anyways. then it would be no prob to lift. oh by the way why the hell are yall wanting to jack it up.
Old 04-18-2006, 02:35 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
So... he doesn't have the money to do a simple engine swap, but he can afford to do major fabrication work on the suspension?
Old 04-18-2006, 08:46 AM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
Old 04-18-2006, 09:41 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Anyone else notice the front end on that camaro in the pics was fiberglass pin on?
I also agree with Apeiron. You can't simply buy some 2" or 3" body lift mounts like a truck and go to town. It would take some custom work and a new frame to do the job right.
I dunno... call me crazy but I can't see a V6 turning over tall mud tires very easily with the little 2.X gear it probably has. There is a reason for mudders to put huge gearing in there to offset the tire diameter height.
Old 04-18-2006, 03:04 PM
tarvis's Avatar
well, im going to do all the fabrication, and obviously im going to have to ask sombody else...thanks for your critisism...im looking to make it work...not change my mind...also im in california, i dont have a very good option to change out the motor
Old 04-18-2006, 04:56 PM
krisb410's Avatar
Why did you even post
We all have individual tastes and ideas. So what if there not the same as yours, If you don't like his idea then just go about your business.
Maybe he just plans on showing it and off roading?
Man how bout giving the guy some help, If you can't help then move along.
Old 04-18-2006, 07:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I could care less what he does with the car. It has nothing to do with taste, and everything to do with common sense.
Old 04-18-2006, 09:12 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
Engine: Rebuilt Vortec Headded 358SB 9.5:1
Transmission: 700r4, corvette servo, Transgo kit
Axle/Gears: 3.23 POSI
travis
Ok, You are wanting to keep the car a v6 and just for some reason lift the car??? if im getting at this corectly????
Drop the lower A arms down, make mounts to lower all your stuff like 3"s and get taller springs and longer struts..
Old 04-19-2006, 10:20 AM
tarvis's Avatar
awesome...well my friend is into offroading and wants to..thanks though...to drop the a arms, is it going to be just like the thing they have on the 2wd trucks??
Old 04-19-2006, 10:27 AM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Tarvis, a v6 RWD car isnt going to be a very good wheeler. You could probably trade the thing for a 4 cyl Bronco and you'd have a much better starting point for less cash. Something to think about. I mean, if he's attached to it, fine. But what about going to the junkyard and getting an engine there? You could probably do that for only a few hundred bucks.
Old 04-19-2006, 10:43 AM
Engine: 383 SBC
Mine wasn't really critism. It was just pointing out the fact you will need to swap out frames. It has been done many times in magazines so search google and you should have plenty of hits. Car bodies on truck frames have been done to death, so you won't really had to figure stuff out on your own at least.
I just wanted to point out the reason why mud trucks have 4.x+ gears usually is the fact they have 36+" tires, so that evens out the ratio. If you try turning a 36" tire with a 2.77 or similiar, heck even a 3.08 or 3.27 you're not going to get anywhere. It'll be for high speed useage not low end, which would be crazy on that size of tire. For mudding you don't want high speed you need the grunt to get moving off the muddy start line. Hope that makes sense.
Personally I wouldn't even try to attempt it on a unibody. I've seen mud trucks with big blocks generate enough body roll and torque to twist regular truck frames. You're just asking for a world of hurt if you try getting serious on a unibody if you ask me. Maybe if you were just doing it looks/car shows it would be ok. I still wouldn't want to rely on custom steering pieces on the front though on the road. I dunno something about angling would really make me scared. Course this is the fabrication board so you're open to do whatever you want. It's your friends car.
Old 04-19-2006, 11:35 AM
305q_ta86's Avatar
Transmission: 5 spd
Fireturd, remember tarvis said his friend cant do a swap, so having too much power wont really be an issue here.
On that note, neither would too little gear be an issue, because with that v6 he wont be going anywhere anyway..
Old 04-19-2006, 07:11 PM
tarvis's Avatar
i know, haha im not worried about gearing the biggest tire he would be running is a 30-31 inch mud tire....we wont be wheeling too hard, just doing it for fun and laughs
Old 04-19-2006, 07:38 PM
Engine: 383 SBC
Well if you have a 3.08 gear, a 700-r4, and a 31 inch tire you'll get 55 MPH at about 1300 RPMs in OD.
In first gear you would beable to drive about 20 mph at 2000 RPMs.
At 3000 RPMs in OD you would be running 128 mph.
Old 04-23-2006, 03:56 AM
83 Crossfire TA's Avatar
I think most are actually done on full size blazer chassis… and if he can’t do an engine swap I don’t see how he’s going to swap a whole chassis and drivetrain.
Old 04-26-2006, 02:30 AM
fbodyguy86's Avatar
Car: 92 camaro rs
the s10 standard cab shortbed has a 108 wheelbase the same as the camaro and the s10 blazer so just get a 4x4 s10 and drop the camaro body on the frame and hook up the trans and tranfer case and your off and mudding
Old 04-26-2006, 03:55 AM
f-bodies have a 101" wheelbase... the K1500 blazers have a 106" wheelbase, the K5's I think are shorter then that...
Old 05-17-2006, 03:29 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
its easy to change the wheelbase on a leaf sprung chassis im sure, cut the brackets off and weld them up further. you need a half ton chassis like the k5blazer or k1500 to take the twisting of an off roader. i know a guy who did this very thing, i think he used a short wheelbase 80's k1500. he channeled the camaro so you dont see the frame so much. it sounds pretty easy. everything is stock k1500 so you can get a lift and stuff for the truck.
Old 05-17-2006, 04:05 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Originally Posted by ChevyMetal305
I think I bought that same car once in the "hotwheels" series when I was little
Old 05-17-2006, 04:52 PM
fitbmxseries1's Avatar
Car: 1988 trans am GTA
Engine: 350 tpi
that doesnt sound easy to me! i think this would cost way more to do then an engine swap........ and this would take way more time to do. and its not that practicle of a offroad vehicle
Mdubpugh (01-19-2022)
Old 05-17-2006, 06:16 PM
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
I don't think so, just welding/cutting materials. move the spring mounts or shorten the frame, shorten the driveshaft using a piece of angle and C clamps to keep it straight then weld. I have to agree it's not practical, sounds like fun though.
JCwhitney sells extra high lift coil springs which raise 3-4" and believe me it's more like 6" if your V6 car has old saggy springs. The high lift coil springs should allow you to run at least 31" tires with fender trimming. You might have to elongate the upper strut mount holes to get the alignment close with those big springs. It sounds like you just wanna have some good fun with it so I wouldn't worry about the unibody holding up to offroad use, if you've seen a grand cherokee body it's the same style unibody junk and guys wheel those pretty good. Subframe connectors.
Old 05-30-2006, 11:04 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
anything you do is going to be harder than an engine swap. that only takes a weekend.as far as cost goes you get what you pay for. you may be able to jack it up but is it going to last? is it going to be safe? its not going to be practical anyway you look at it. stock is practical. you jack it up you loose the handling, you change the engine you're going to use more gas.
as far as the unibody goes i wheeled a cherokee for years and its "unibody" was a fully boxed frame that went from bumper to bumper. not the same as a firebird thats not meant to have the constant twisting forces from offroading.
Old 05-30-2006, 01:49 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
This thread isnt dead yet?
Old 05-30-2006, 03:11 PM
Engine: 350 tpi
one thing that is for sure is that if your gunna build one you stick it on a frame of another vehicle, no way your gunna use it on the unibody of a firebird or camaro, my cars roof is cracking from just normal driving, can you imagine the flexing pics of a f-body car? the actual car would flex i wouldnt be suprised if you shattered all your windows out!
Old 05-31-2006, 11:53 AM
1983Fbody's Avatar
Engine: 415
I was supposed to install a hitch on a cherokee a couple of weeks ago and we decided not to do it because the "frame" was really thin sheet metal, thinner than an fbody in the rear "frame rail" area. They wanted to pull a heavy bass boat with it, I think the hitch could have pulled right through the frame unless some kind of huge washers were put in place to distribute the load a bit and we didn't feel like cutting a hole in the frame to install the washers then boxing it back up. While it might be stronger than an fbody because it is fully connected front to rear and more of a rectangular shape and better design with more supports, it's not any different in manufacture.
A seperate frame would actually flex more than a unibody, the floorboards and transmission tunnel act as one giant crossmember. Compare this to a ladder type frame and there is actually more potential to twist. The ladder frame isn't as likely to start cracking or buckle doors, etc. because the rubber body mounts allow some give. The best thing to do would be to install subframe connectors on the unibody then attach it to the 4x4 frame.
Old 06-02-2006, 11:13 PM
Beachmonkey6's Avatar
Car: '88 GTA
Engine: L98 -350TPI
Thats the main thing about unibodys... they dont twist like other frames do. I used to have a '90 cherokee with 32in tires and it was an excellent offroading vehicle. But im guessing your doing this more for show than for offroading?
Old 06-12-2006, 06:38 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
Mere words cannot express my disapproval of this so i will instead use a simple, universally recognized symbol.....
Old 07-03-2006, 11:38 PM
yallwatchthis's Avatar
Car: 84 Z28
Engine: 355 vortec, super victor, 13.5:1cr
Transmission: 'glide
Axle/Gears: 7.5" 10 bolt/4.56 gears
I will agree with most about impracticality.....however this sounds like an extremely fun and goofy mod for someone with lots of time on their hands to do. Good luck on it and send lots of pics of your progress.....I, on the other hand, will stick to makin' mine hook hard and go straight real fast.
Old 07-04-2006, 04:00 AM
Xophertony's Avatar
Car: 1988 Trans-Am GTA
Engine: 5.7L TPI
Transmission: WC-T5
Axle/Gears: BW 3.27
NOT MY CAMARO, saw it on craigslist!
it has been done. EVERYONE that i ahve seen has been on a truck/SUV frame. it will be next to impossable/totally impractiacl to lift the car by traditional means. you will go broke trying. it will just cost too much. pure and simple.
LT1Formula
20
11-14-2015 12:02 AM
gta90
09-15-2015 04:00 PM
NWAsonoma
08-18-2015 05:45 PM
happyhapka
08-15-2015 04:42 PM
anesthes
08-08-2015 09:37 PM
Quick Reply: Lifted Camaro
