stb with dual snorkel air cleaner?
Car: 1986 Z-28
I've been wondering if this is possible? Any one have a pic? I'd like to make a set of them if it can be done. Thanks.
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
Re: stb with dual snorkel air cleaner?
anything is possible
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
I think the Kenny Brown STB would allow some room to maybe put your pipes either over top or perhaps tuck under... Maybe if you ran the two pipes directly out either side, then ran them towards the front you could have enough room to make it work...
That pic is from a Nova, I think something like that would work great if you didn't want to use your air dam in the front... Otherwise, maybe some smaller pipes and run them over top?
It's only plastic/rubber hoses... Your options are limitless in this situation.
Go nuts
Go nuts
Car: 1985 Camaro
Engine: 350 bored 40 over
Transmission: 700-R4 Race prepped
I have the hotchkis STB on my 85 Camaro and I have the TPI dual snorkel set up, with a lift off fiberglass hood. It fits without any mods, just measure carefully on the placement of the brace, but it works just fine.
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Here's a pic of my home made 14" x 3" duel snorkel air cleaner. Its made out of alum. and has a K&N filter.
Auggie
Auggie
on my car i cut out the scoops on my twin turbo hood. then i took my aircleaner and got another one just like it. cut the air intake "arms" off each one. then took my bottom pan of my air cleaner and filled the original hole.
i next took both the arms and put them so they would meet up to the opening on each scoop and marked it. then i cut out the intake holes on the pan and welded the arms on fliped upside down than original because the angle makes them clear the Ac pump and Altenater and bring them to the scoop openings. i will try and get pics.
i hope you can understand what i meant
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
Here is one I modified to work on my Camaro. I had to modify the "ear" pieces.
For some reason it will not upload the picture of the whole brace.
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
Why don' you modify some sort of tube off the intake, to go to the stock dual snorkel aircleaner, and remove the baffles from the bottom, I have one of those now, and several snorkel setups, if you need some.
Hotrodboba400
12-10-2019 07:07 PM
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
