a/c delet
1 Post
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
a/c delet
please don't flame
is this what I'm looking for to accomplish getting rid of A/C
http://cgi.ebay.com/ebaymotors/chevy...Q5fAccessories
Car: 86 Camaro
Engine: 350 LT1
Re: a/c delet
Yes sir, they make aftermarket ones for like 140 er so on hawks. Not 100% sure if it will fit a camaro since its for a s10. You'll need a delete pulley too, or you might be able to just get a smaller belt, someone correct me if im wrong on that.
1 Post
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: a/c delet
Look for one for a Camaro. They're direct bolt-on, not like the S-10 one. They're not very difficult to find, and, junkyards sell them cheap. My entire conversion cost about $10, and that was just for the cans of primer and paint to paint the box.
I didn't need a delete pulley, (you might not either), because my car has v-belts.
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: a/c delet
I'm in the process of putting on of these in my Camaro. The blower motor housing will need some "tweaking" to fit properly, but can be done. It's been detailed pretty nicely in this thread:
https://www.thirdgen.org/forums/fabr...want-c-so.html
As far as the belt, you should be able to just use a shorter one with a slightly different routing if your alternator is on the top passenger side. If your A/C compressor is on the top passenger side, you may need to pick up an A/C delete pulley.
2012sergen11
10-13-2015 07:38 PM
