oil pan modifications ideas? (for road racing) - Third Generation F-Body Message Boards
Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Thread Tools Search this Thread
Old 02-13-2009, 12:55 AM   #1
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Iv looked at many after market pans manly road race style pans since this is the type of pan i will need to run. i plan on using a oem stock pan and modify it to suit my needs, modified oem pump and modified pickup depending upon design of the pan. - just looking for ideas, plans, pics, tips anything of that nature would be great
FueledSoul is offline vBGarage Page   Reply With Quote
Old 02-13-2009, 11:24 AM   #2
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: oil pan modifications ideas? (for road racing)
Why don't you just buy an aftermarket road race oil control pan? If you fabricate one yourself and make some miscalculations, you will have an engine good for a boat anchor or the like.
paul_huryk is offline vBGarage Page   Reply With Quote
Old 02-13-2009, 11:37 AM   #3
J91
J91's Avatar
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
I would get the proper pan for the proper job. Ever look into anexternal resivoir system, I hear they work quite well. I am planning on getting one for my car.
J91 is offline vBGarage Page   Reply With Quote
Old 02-13-2009, 05:39 PM   #4
FueledSoul's Avatar
i plan on running a oil accumulator, screened windage tray, rear main pan baffle and crank scraper. im just going to cheap out and build my own pan its simple and easy - just looking for ideas for stop, go and high cornering G's to keep the pick up in oil with out starving it
Old 02-13-2009, 08:18 PM   #5
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
a dry sump setup would be cool
//<86TA>\\ is offline vBGarage Page   Reply With Quote
Old 02-13-2009, 08:39 PM   #6
FueledSoul's Avatar
No doubt!
iv looked into it. . . pricey, like i said keeping it on the cheap but effective side
Old 02-13-2009, 11:25 PM   #7
FueledSoul's Avatar
Old 02-14-2009, 04:25 PM   #8
FueledSoul's Avatar
This seems like a good deal only thing is will it work with a 3rdgen
http://www.midwestmotorsportsinc.com...5120K&line=MWM
Old 02-15-2009, 10:00 AM   #9
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
i bought a canton road race pan came with the oil baffles and such nice piece better then trying to piece one together casue u would still have to buy baffels screens and scraper too that kit didnt have any of that and u would have to be precise on the scraper as not to hit the crank good luck though
tom86iroc is offline vBGarage Page   Reply With Quote
Old 02-18-2009, 11:41 PM   #10
FueledSoul's Avatar
Got any pics with your pan installed?
Old 02-18-2009, 11:47 PM   #11
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
If you are going to buy an aftermarket oil pan there are a couple on considerations to keep in mind.
1. It will have to clear the k-member if you have the stock one and not a tubular one.
2. There will need to be enough clearance between the oil pan and the k-member if you are using the stock exhaust routing.
1989GTATransAm is offline vBGarage Page   Reply With Quote
Old 02-21-2009, 06:34 PM   #12
FueledSoul's Avatar
all things considered thats what i want to fab my own so it suits my needs and application
Old 02-23-2009, 07:26 PM   #13
tom86iroc's Avatar
Car: 1986 iroc
i dont have the canton in the car yet as i havent finished my new motor but it will fit stock exhaust and clear a factory k member from what the website says i have a different k memeber and im gonna be runnin hooker LT's so won't ahve any problems
Old 02-23-2009, 09:53 PM   #14
1MeanZ's Avatar
Car: 2xIROC, GTA, Z28
Engine: TPI 355s and 383s
Transmission: TKO 600 / T56 / 2xWCT5
Axle/Gears: 3.54, 3.27, 3.73, 2.73
Quote:
I strongly recommend just buying a pre-made pan. Go to Canton's website, they offer a road race style pan that will work with the stock crossmember and crossover exhaust. I'm running the 15-244t with long tubes. The canton pans have bungs for oil temp sensors, trap doors, windage trays, crank scrapers, you name it. I love mine and am glad I got it. I auto-x the car and I run 1-2 HPDE "open track day" and wanted to make sure I didnt run the engine out of oil. At 3000+ rpm around the right handed sweeper at Nelson Ledges the oil pressure gage never moved.
1MeanZ is offline vBGarage Page   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Clicking noise B_Dubya Transmissions and Drivetrain 3 08-26-2015 06:09 PM
[VA] Oil Pan Gasket and 2 K&N Oil Filters Navy8125 Engine/Drivetrain/Suspension Parts for Sale 4 08-21-2015 10:32 AM
1987 LG4 Love and Hate MY87LT Transmissions and Drivetrain 12 08-17-2015 09:43 AM
FS: AFR 195s, Forged pistons, crank 89mulletbird Southern California Area 0 08-10-2015 11:16 AM
Knocking - Thrust Bearing? gwade12 Tech / General Engine 1 08-08-2015 09:17 AM
Go Back   Third Generation F-Body Message Boards >
Tags
baffle, boat, body, design, fabricate, ford, ledges, modifications, nelson, oil, pan, pans, race, racing, road
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
